risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Fri Jun 05, 2015 8:33 am Post subject: Berg 4 Qt Sump Turbo Drain - Tap or Weld? |
Currently running a Scat 2 Qt. Sump which comes with thicker bosses on the sides to tap for turbo drain etc.
Looking at upgrading to the Berg 4 Qt. Sump. Is there sufficient wall thickness to tap for a 1/2 NPT fitting or should I just weld on an AN fitting?
Looking at the pics of the Berg sump, there does not appear to be any extra material cast in for tapping holes, like the Scat sump has.
If anyone has pics of their turbo drain on a Berg sump, please post up. |
jason Samba Member
Posted: Fri Jun 05, 2015 12:28 pm Post subject: |
I have one that I'll try and remember to look at. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Jun 05, 2015 1:14 pm Post subject: |
I would just have bung TIG welded on, placed where you want it and move on....
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Fri Jun 05, 2015 3:01 pm Post subject: |
Do you have a universal case with type 3 block off plate? That would be the best oil return, above the oil level. _________________ foam cowboy hats aren't good helmets. |
jason Samba Member
Posted: Fri Jun 05, 2015 5:27 pm Post subject: |
The front and rear are about 5mm thick and the sides are 8mm. |
risk Samba Member
Posted: Mon Jun 08, 2015 10:21 am Post subject: |
jason wrote: |
Thanks! |
Chip Samba Member
Posted: Mon Jun 08, 2015 8:00 pm Post subject: |
tripicana wrote: |
Do you have a universal case with type 3 block off plate? That would be the best oil return, above the oil level. |
Too high for most hide a way type headers. And on the wrong side. |
risk Samba Member
Posted: Fri Aug 14, 2015 10:25 am Post subject: |
I ended up tig welding some bungs on, rather than trying to tap. Worked out great.
The front and rear walls of the sump are much thicker than the sides. They would have tapped fine, but the side was a little thin for 1/2" NPT.
