Terminatez Samba Member
Joined: June 07, 2015 Posts: 340 Location: Sun Valley, CA
Posted: Sun Jul 19, 2015 11:37 am Post subject: |
busdaddy wrote: |
Terminatez wrote: |
I don't have size 14 rims and I can't find them new online (I want them with hub caps)...should I switch to 15? |
If this is your bus it has 14" stock wheels on it right now:
Clean them up (powdercoat?) and get whatever everyone is recommending in the last few pages of the tire thread in the FAQ's, Hankook RA08 seems to ring a bell but check first as availability and quality changes. |
Seriously, you can tell from the picture? How so? (Actually curious and not being sarcastic).
Also, I'll try and see if they're safe because I think more than 2 of the wheels (we have 5) have been hit (came from a different bus) and they might not be straight. On 1 of them you can see a bad dent, which I will have to replace entirely. _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
I don't think I've ever seen an engine in worse shape. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jul 19, 2015 11:47 am Post subject: |
Terminatez wrote: |
Also, I'll try and see if they're safe because I think more than 2 of the wheels (we have 5) have been hit (came from a different bus) and they might not be straight. On 1 of them you can see a bad dent, which I will have to replace entirely. |
It's not hard, they look like stock wheels and there's not many other wheels with a 5X112 bolt pattern, stock wheels only came in 14"
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jul 19, 2015 11:54 am Post subject: |
busdaddy wrote: |
Terminatez wrote: |
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search |
I'm glad they're the stock ones, now to just figure out and see if they'll work or if should buy other ones. I know for a fact 1 is going to be replaced. _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
Posted: Mon Jul 20, 2015 4:18 pm Post subject: |
Finally decoded it.
Here's a link to the vw-mplate website
and here's from all the pretty buses
Code: |
Decode Results:
Production Date: August 27, 1971
Exported To: USA, Washington D.C.
Designation: VW Campmobile
Engine KW (BHP): 50 (68); 49 (66)
Transmission Type: manual
Engine: *
Transmission Code: -
Extras Code: 609/517
Paint / Interior
Paint Scheme: Pastel White
Paint Codes: L90D
Paint Notes: Code only used on Westfalia campers
Interior Scheme: dark beige
Interior Material: leatherette
Interior Notes:
Options
A02: Specifications for the USA / Speedo in miles, Sealed beam headlamps, Rear window defroster, Back-up lamps, Side marker reflectors... (?)
p30:
172: Tubeless steel-ply tires (?)
507: Vent wings in cab doors
aeromech wrote: |
Posted: Mon Jul 20, 2015 5:16 pm Post subject: |
Well done!, now you can change your signature line to "1972 Westfalia P30 hardtop Campmobile" _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Jul 20, 2015 10:27 pm Post subject: |
Nice!
It looks like I'm going to have to buy a new set of wheels. What do you guys think?
aeromech wrote: |
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
Posted: Tue Jul 21, 2015 5:36 am Post subject: |
I took my wheels that looked like that to my Les Schwab and had them blasted and powder coated. Any decent tire shop should be able to tell if the wheels are true
Dump those tires though and get some LT tires.. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
Posted: Tue Jul 21, 2015 4:32 pm Post subject: |
Lil' Lulu wrote: |
Dump those tires though and get some LT tires.. |
Planning on dumping those tires. LOL _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
Tcash Samba Member
Posted: Tue Jul 21, 2015 5:02 pm Post subject: |
I don't see anything wrong with the wheels you have aside from the need for a sandblast and paint or powdercoat, if you are concerned there's many prettier ones in that classifieds link I posted earlier.
Tcash, can you get 8 ply or LT tires that fit those and don't funk up the gear ratios? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jul 21, 2015 10:12 pm Post subject: |
busdaddy wrote: |
Tcash, can you get 8 ply or LT tires that fit those and don't funk up the gear ratios? |
I really want to stick to the 14s because they're small and I think look best on buses.
I'll get them sand blasted and see what's up.
I'm excited, I was able to find a set of both door handles, sliding door handle, ignition, rear hatch and engine door set with all of them working on 1 key! _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
Posted: Sat Aug 01, 2015 8:33 pm Post subject: |
So had my engine checked, and it's no good :/
What are my options? Any kits available? None of the sheets are good :C
What websites can I look a type 4 engine parts
aeromech wrote: |
Posted: Sat Aug 01, 2015 9:16 pm Post subject: |
Your engine looks to be a 2.0L in case you don't know. You need to decide on things like running hydraulic or solid lifters and what kind of cam you want, stock or somewhat upgraded. Putting money into the heads are where you really get dividends. |
SGKent Samba Member
Posted: Sat Aug 01, 2015 9:23 pm Post subject: |
my suggestion would be to set a budget for the engine first. It is easy to get $4000 - $5000 into a type 4 engine. Once you have a budget it will determine what quality rebuild or refresh you can do. The more you take it apart now to see what you have the greater the odds that you will have a basket case before you even get started. When you are ready to begin disassembly and rebuilding it will go smoother if you wait. Then you can clean and inspect everything at one time. If your budget is unlimited then by all means read up on it and get started. If you will be farming the work out, by all means do not take it apart. Many mechanics will not accept a basket case project. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Aug 02, 2015 12:23 pm Post subject: |
Wildthings wrote: |
Nice. I didn't know, the car is currently at my uncles shop, so he's the one putting work into the bus. He's going to continue taking the engine apart and cleaning it to see what else he can find. I will have a list of what he comes up with for the engine and I'll post it here for your guys opinions. I don't think he's going to recommend what type of part I should get which is where I will need your guys experience to help me choose out what type of heads, cams, etc I should go towards. After I get the list, I will also post my budget. At the moment, I'm looking at somewhere close to $4k-$5k as SGKent posted. My budget may go higher, but as of right now, I am allowing "$4k-$5k" so if option go over to $7k, feel free to recommend. _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
Posted: Sun Aug 02, 2015 2:31 pm Post subject: |
Sounds reasonable, make sure Uncle follows the books for dismantling and doesn't throw anything out.
You may also not like the way that 2.0 gets along with the transmission ratios, if there's any budget left over the transmission might need some. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Aug 02, 2015 3:18 pm Post subject: |
busdaddy wrote: |
You may also not like the way that 2.0 gets along with the transmission ratios, if there's any budget left over the transmission might need some. |
Personally I would balance the engine within a gnat's ass and stick with the lower gear ratios, unless going fast it where it is at for OP. He might also want to run a high viscosity index synthetic oil like a 5w40 or 5w50 to keep the oil temps down at the high revs. Depending on where one drives, being able to pull a 6% grade at 65 MPH may count for more than being able to cruise the flats at 75 mph. |
Posted: Sun Aug 02, 2015 3:29 pm Post subject: |
Wildthings wrote: |
busdaddy wrote: |
The lower ratio isn't the problem so much as the stock 2.0 has a somewhat narrow powerband and runs out of torque at some very inconvenient shift points. Of course if you are getting serious about the cam, heads, carbs and exhaust you can prevent all of that and build something that pulls almost up to the redline and possibly down lower as well, it doesn't have to be a race monster, but there's ways to improve certain aspects of it's power curve, anything's possible with enough $ or at least some careful thinking and research ahead,. Now's the time for that _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Aug 02, 2015 4:11 pm Post subject: |
I'm no mechanic, so I understand like 2 words from those replies. LOL
But I will see what uncle comes up with, and compare that to the information I have here. And of course many many questions _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
Tcash Samba Member
