64 Karmann Ghia gears grinding
gavino
gavino is offline
PostPosted: Sat Jun 13, 2015 6:55 pm    Post subject: 64 Karmann Ghia gears grinding Reply with quote
Okay, well I'm 16 years old and I've had my '64 Ghia for about 2 months now. It was running fine until about 2 days ago it started grinding really bad when switching from first to second and even then it doesnt switch into second. After a while I noticed it only happened when turning right. My dad took it out and he seemed to be immune to the grinding and it never happened to him but everytime I did it, it grinded. I think the reason being is that he was going very slow when switching from first to second. For the time being I guess I have to go super slow on right turns (which is tough to remember) or go in first until the car has finished turning. While it is still driveable.... it really is very very annoying and feels dangerous. When the grinding did happen I had to switch it back into first then again to second. I understand I could double clutch and it works but the point is before this wasnt a problem, and now it is. So I'm sure there's something that went wrong mechanically that hopefully I can fix that will make it work fine again. Keep in mind it ONLY happens when turning right and going from first to second, never under any other circumstances. Please be detailed with responses as I am new to cars... THANK YOU!
Eric&Barb
Eric&Barb is offline
PostPosted: Sat Jun 13, 2015 8:11 pm    Post subject: Reply with quote
Adjust for proper amount of clutch pedal play.
Have you checked the transaxle gear oil level or better yet changed it?
Check that all three transaxle rubber mounts are in good condition and not cracked thru.
In Stereo, Where Available!
Eric&Barb
PostPosted: Sat Jun 13, 2015 8:17 pm    Post subject: Reply with quote
Search around and get this manual ASAP. Used condition will be even less $$.
http://www.amazon.com/Volkswagen-1200-Workshop-Man...hop+manual
John Moxon Premium Member
John Moxon is offline
PostPosted: Sun Jun 14, 2015 12:56 am    Post subject: Reply with quote
Yep your clutch pedal should only have 1/2" > 3/4" free play. If it has more you need to adjust the free play by tightening the nut on the cable where it runs through the arm on the far right in the picture:
John.
My 1958 Karmann Ghia
c21darrel
c21darrel is offline
PostPosted: Mon Jun 15, 2015 1:56 pm    Post subject: Reply with quote
and when done adjusting the clutch...adjust the shifter, check coupling under the backseat too. 3rd, there is a nylon ring the shift shaft runs thru, its under the handbrake in tunnel. Confirm that one is there and in good condition.
Thats about all you can do, if condition persists...it may be trans time Crying or Very sad
GhiaBuild
-Zodiac-
-Zodiac- is offline
PostPosted: Mon Jun 15, 2015 2:11 pm    Post subject: Reply with quote
Or learn to drive it like dad Wink
agree with all of the above, I had problems with mine too - Eventually I adjusted and replaced everything mentioned (besides the trans mounts..and the trans..)
Goodluck!
1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives.
Bruce
Bruce is offline
PostPosted: Mon Jun 15, 2015 5:29 pm    Post subject: Reply with quote
I think you might be tagging reverse when going into 2nd. Turning right has nothing to do with it except that on a right turn you might be leaning to the left, and unknowingly pulling the shifter to the left.
Spend time searching "shift rod bushing" here on the Samba. You need to replace yours because it is worn out. The procedure is the same on Beetles, so search the Beetle forums.
Bikerchris
Bikerchris is offline
PostPosted: Tue Jun 16, 2015 3:15 pm    Post subject: Reply with quote
Ditto with paying attention to avoid that reverse. I know it may sound a bit silly. Sometimes when I am at a stop and shifting into first I have to tug up a bit on the shifter...the opposite of pressing down when going into reverse.
