Ofir Samba Member
Joined: September 26, 2005 Posts: 460 Location: Israel
Posted: Wed Jun 17, 2015 11:46 am Post subject: After how many miles the heat riser got clogged? |
After how many miles the heat riser in the dual port manifold got clogged?
How often need to remove the manifold and clean/open the heat riser?
Thanks |
Danwvw Samba Member
Posted: Wed Jun 17, 2015 11:52 am Post subject: |
I think they usually clog more over time. Perhaps 10 years! Usually they are good for the first and second rebuild. Kind of depends on gas you use! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Wed Jun 17, 2015 12:09 pm Post subject: Re: After how many miles the heat riser got clogged? |
It also depends on if the engine is burning oil, and/or how rich the jetting is. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Ofir Samba Member
Posted: Wed Jun 17, 2015 12:26 pm Post subject: |
After I opened and cleaned my heat risers with drill and clutch cable which were completly clogged, how many miles I can expect till it will be clogged again?
It took me hours to remove most of the junk in there, I believe it was never cleaned in the last 40 years!
My engine doesn't burn oil, I used 95 RON fuel.
Now that the heat risers are open and function, what's the difference I'll notice? |
bluebus86 Banned
Posted: Wed Jun 17, 2015 12:55 pm Post subject: |
I got a single port motor and the manifolds are hard to comeby these days. they not only get clogged, but also rust out, then they are shot.
I have driven a lot with the manifold heat raiser totally clogged and cause of my weather condition I have not had icing problems. I imagine in cold climates the problems are worse.
My last manifold on my 1300 motor where clogged and rusted, they had pin holes after cleaning. I got a replacement manifold and cleaned it but noted rust pits on the inside, so I elected to block off the heat raiser with a solid gasket and run without manifold heat, seeing as I never had a problem before with totally clogged manifolds. this way I hope to not have them rust out internally. It was hard enough finding the correct used manifold now, I'd hate to be searching for replacement ten years from now.
I am in preservation mode now. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Howard 111 Samba Member
Posted: Wed Jun 17, 2015 1:36 pm Post subject: |
Ofir, you may not notice any difference. But it's purpose it to help warm the manifold and carb faster on a cold startup. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
Danwvw Samba Member
