Looking for a tow hitch for my 81 vanagon
domromer
domromer is offline
PostPosted: Thu Jun 18, 2015 6:36 am    Post subject: Looking for a tow hitch for my 81 vanagon Reply with quote
For some reason I'm not finding much. I need a tow hitch with a two inch receiver for towing my little 12ft sailboat and hooking up a bike rack. I'm hoping someone here can point me in the right direction.
The only one I found was on the go westy site but it say's not compatible with the air cooled vanagons.
1981 Aircooled Vanagon
https://www.flickr.com/photos/dsrphotography/
http://www.dustybootsphotography.com/
syncrodoka
syncrodoka is offline
PostPosted: Thu Jun 18, 2015 6:39 am    Post subject: Reply with quote
Have you seen burley's bumper hitch?
domromer
domromer is offline
PostPosted: Thu Jun 18, 2015 6:59 am    Post subject: Reply with quote
Holy cow. $395....yikes!
djkeev Premium Member
djkeev is online now
PostPosted: Thu Jun 18, 2015 7:04 am    Post subject: Reply with quote
PM me, I know of a used one.
Dave
Ghia
Vanagon
Beetle
danfromsyr
danfromsyr is offline
PostPosted: Thu Jun 18, 2015 7:11 am    Post subject: Reply with quote
quality costs $$$ ya gotta pay to play
you can always get the cheaper one that hooks to the eyelets on the bumper brackets. but it's not rated for as much pull/tongue.
I had a friend want one for his Bay bus. sure we can work it out.
gave him a materials list, had him measure cut, I welded and then mounted..
took him/us all day.. still cost more $ than he'd have preferred..
domromer
domromer is offline
PostPosted: Thu Jun 18, 2015 7:23 am    Post subject: Reply with quote
I'm not towing more than 500lbs. So I'm fine with cheaper.
danfromsyr
PostPosted: Thu Jun 18, 2015 7:33 am    Post subject: Reply with quote
cheaper, just put a 2in ball on it.
http://www.etrailer.com/Trailer-Hitch/Curt/C11657.html?feed=npn&gclid=CPDu2OW6mcYCFYSQHwodyawAzQ
http://www.amazon.com/11657-Class-Fixed-Trailer-Hitch/dp/B001C6MD3I/ref=pd_sxp_redirect
domromer
domromer is offline
PostPosted: Thu Jun 18, 2015 7:49 am    Post subject: Reply with quote
It looks like that curt only fits 90 and up vanagon.
danfromsyr
PostPosted: Thu Jun 18, 2015 7:50 am    Post subject: Reply with quote
tow loops are all the same..
looks like they list it as 90 and up only.
watch your tongue weight..
w/o a drop down lower support bar (to engine cradle) they can twist if given a heavy load.
syncrodoka
PostPosted: Thu Jun 18, 2015 7:51 am    Post subject: Reply with quote
For a cheap hitch with a 2" receiver you are going to have to fire up your welder and DIY. Hopefully your structural welds are good.
Westified
Westified is offline
PostPosted: Thu Jun 18, 2015 8:31 am    Post subject: Re: Looking for a tow hitch for my 81 vanagon Reply with quote
I have a hitch you can have for free, just pay the shipping from Miami. It is identical to the Curt hitch Danfromsyr has the link to. I have towed a 2100 lb Boston whaler 16 miles to the dealer and back. I wouldn't recommend that much weight. I only did that once. My 1.9 floored could only do 50 mph. Usually just tow a 15 ft aluminum skiff, boat, motor and trailer weight 800 lbs no problem. Hauled the skiff to the keys and Everglades numerous times. You can bolt a 2x2 inch sleeve into the ball mount hole for a bike rack. Yakima used to sell the sleeve. PM me if you are interested.
You can probably use this to adapt it for bike carriers but I am not sure you could tow a boat with it. http://www.amazon.com/Swagman-RV-2-Bumper-Adaptor/...NXFZJBS2CP
1984 Westy Wolfsburg, owned since 1987.
Dana Champion
Dana Champion is offline
PostPosted: Thu Jun 18, 2015 10:02 am    Post subject: Reply with quote
I had a shop fabricate a hitch for my '81 Westfalia back in '91, so I could haul a small Coleman tent trailer to Mammoth Mountain. Ready made hitches were not as common back then. If all else fails have one made, "custom like"
domromer
domromer is offline
PostPosted: Thu Jun 18, 2015 6:15 pm    Post subject: Reply with quote
Is there a reason these hitches don't have receivers? Is it an issue of clearance?
0to60in6min
0to60in6min is offline
PostPosted: Thu Jun 18, 2015 6:29 pm    Post subject: Reply with quote
how about this one...
http://www.van-cafe.com/home/van_1299275510577/pag...eiver.html
domromer
domromer is offline
PostPosted: Thu Jun 18, 2015 6:31 pm    Post subject: Reply with quote
Says doesn't fit air-cooled.
hdenter
hdenter is offline
PostPosted: Thu Jun 18, 2015 8:14 pm    Post subject: Reply with quote
The other problem with the Go Westy/Van-Café receiver hitch is that it is braced to the engine or the mustache bar. If someone taps you in the rear the blow is transferred directly to your engine. Not a good idea in my book!
Hans
'84 sunroof vanagon
'85 weekender
'96 golf
'07 Passat Wgn
danfromsyr
PostPosted: Thu Jun 18, 2015 8:21 pm    Post subject: Reply with quote
it's so that you don't over load it and use it for a purpose that it isn't designed to handle.
this is a class-I hitch. very light weight utility use..
a bike rack on one of these in a receiver will create far too much cantilevered leverage and twist the tow loop eyelets.
some have added a 2" receiver to the class-I hitch, but you are on your own for safety and practical application there. no warranties and no safety assurances. also it's all on you if there's a failure that damages or kills someone elses property/self
your options are
$ used
$$ cheap class-I
$$$ DIY
$$$$ custom
