Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
Posted: Mon Aug 24, 2015 4:15 pm Post subject: |
Didnt get as much done this weekend as id hoped, Leb is still plugging away at the paint removal.
got the new moustache bar in, much straighter than the one we took off:
Center pin ring folded over: Took SGKents advice, got the dremel with this bit:
did a little of this:
and a little of this:
BTW: SGKent-thanks for reinforcing the safety goggles..I always wear them, but there was metal filing EVERYWHERE! got a few shards in my finger, but better there than in my eyeball.
and got this:
so now this fits:
i also put a 27mm socket on the tight ball joint, and it wrenches around just fine, so this weeks agenda includes putting the center pin back together, and reassembling the front end.
Well, im going to fight with brake lines before I put the spindles back on..so anyone in the northeast, if you try to buy brake lines, you may find they are sold out, cuz i am horrible at bending them and will most likely go through several on each side. _________________ Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
https://www.thesamba.com/vw/forum/viewtopic.php?t=771024&highlight= |
Yarkle Samba Member
Posted: Sat Sep 05, 2015 6:28 pm Post subject: |
Well, as usual, plan vs actual struck again, so we fiddled with this and that.
"Deluxe trim removal" We found the best thing was to wiggle it , up or down, and tap it with a jewelers rubber mallet. Once you get it "started", we tapped from the top while pulling from the bottom, and it came right off.
we then started fiddling with the engine, removing tin and whatnot to clean it and start with the leaky seals.,, missing tin and pushrod tubes.
this guy showed up to help..we call him "trucka"
I had originally planned on doing the engine work on the ground, then grew a brain and got a pep boys engine stand and the vwalley yoke adaptor.
I dont know about the grinding of spot welds referred to in Glenn Rings thread, maybe the pep boys one just fits perfect? You do have to drill it tho.
Caleb and myself each grabbed a j tube and hefted it up onto the stand, then
I marked it with a silver sharpie:
then drilled it out with a 1/2 inch bit. dotn be a dork liek me and try to drill all the way through both sides, didnt line up quite right..shoudl have lsitened to Trucka
went through 2 dewalt bits, but now its on there..
Yarkle Samba Member
Posted: Sun Sep 06, 2015 9:14 am Post subject: |
DOWH!! I said refer to this thread in the flywheel thread, and hadnt posted these yet..
then we started cleaning...yuck:
looks like someone upgraded the collar and pressure plate and fork to the 71 style at some point
we tried the WD 40 degreaser..useless, sprayed like four layers on it:
scrubbed, scraped, wiped..and it barley touched it..we then switched to the GUNK gel, and it was like using a firehose..it just dissolved that stuff right off.
then caleb wiped it down:
Caleb approves:
as does Trucka
then we celebrated
Brian Samba Moderator
Posted: Sun Sep 06, 2015 10:17 am Post subject: |
Degreaser is one hell of a thing man. Looks like progress though. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Yarkle Samba Member
Posted: Sun Sep 06, 2015 10:44 am Post subject: |
that gunk gel is crazy good. The WD-40 stuff and the mostenblockers didnt do anything. the gunk pro just disintegrated it..Caleb is doing the outside of the tranny right now, and that was filthy nasty, but stuff was already dripping off of it.
Yep, progress! a little bit on several fronts, but its still progress!
EDIT:
found this, wasnt thrilled--Trucka was so shocked it knocked his goggles off!
looking for advice in this thread
http://www.thesamba.com/vw/forum/viewtopic.php?p=7812383#7812383 _________________ Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
Tcash Samba Member
Posted: Sun Sep 06, 2015 3:05 pm Post subject: |
That is a later Transaxle. Run the numbers off it.
Trans ID
Looking Good
Tcash |
Yarkle Samba Member
Posted: Sun Sep 06, 2015 3:08 pm Post subject: |
so that ding out of the crank and the bent washer arent a big deal? Flywheel is OK?
Caleb is still degreasing the outside..the inside came off alot easier than the inside, so we cant really read the numbers yet..well, cuz he hasnt cleaned that part of the trans yet. ill go scrape it now
EDIT: 002301103F with a big 3 underneath _________________ Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
Tcash Samba Member
Posted: Sun Sep 06, 2015 5:12 pm Post subject: |
It is easier if you keep everything in one post
Yarkle wrote: |
K, well...the endplay was .003:
but then i found this: i thought these ddint have these spacers? and why is it so deformed?
flywheel:
One dowel is stuck in flywheel BTW
it dirty
crank
K..so...
flywheel usable?
crank Ok?..doesnt seem to move around or push in and out..I dont know where that divot came from
should that spacer have been in there? why is it so bent up? |
Tcash wrote: |
Question: Is there a groove for an O-ring on the inside of this hole?
They may have had to machine the end of the crank and added the shim to make up for the material cut off. If not the pins stick out too far and the gland nut bottoms out on them and the flywheel remains loose.
That should be a soft iron gasket not a metal shim to stop oil leaks. The end of the crank looks to beat up for an O-ring to seal against it. I would use both, soft iron gasket and O-ring.
The shim got bent when the pin pulled out of the crankshaft (crank) with the flywheel.
The one pin should not have come out with the flywheel. You need to have an oversize pin installed. Or have it drilled for 8 dowel pins.
At this point I would take the engine and flywheel to a competent VW machine shop and see what they can do for you.
I don't remember. But can you put a O-ring flywheel on a non O-ring crank?
Good Luck
Tcash |
airschooled Air-Schooled
Posted: Sun Sep 06, 2015 6:44 pm Post subject: |
That bent shim was a .005" end play "increasing" shim for builds that don't stack up correctly. It is included in engine rebuild gasket sets, so some people think you have to use them. You only use them if you can not get large enough end-play with available shims. This doesn't mean shims you have, it means you can use it if your end play is REALLY so tight that the three smallest shims aren't small enough. Always three shims, NEVER less. It bent when the dowel pin passed through it.
I have your PM, going to respond from the computer later…
www.airschooled.com |
Yarkle Samba Member
Posted: Sun Sep 06, 2015 8:04 pm Post subject: |
Hmmm..well, there arent really alot of "VW shops" around here..Really, there arent any I'm aware of thatd I'd call competent..this is the land of the rust.
Theres one VW guy who seems to take on projects, but doesnt finish them, and another one who doesnt know the difference between bus and type 3 heater boxes, so im a little leery of going there.
I was hoping to get the bus on the road just so Caleb can drive it to school a bit before the snows fly, so would it be Ok to just put it back as it was, with a new spacer and seal, and see how it goes for now? (20 mile round trip, so we arent talking huge mileage here.)
if it leaks, i can pull it again If i have to and fix it for good? probably with a new crank, id imagine.
Im asking for suggestions here, so fire away. I think i can get the flywheel checked out without a problem, just not sure if anyone really would be up to the crank issue.
It looks like someone already "fixed" it, which could be part of the problem..odd they didnt clean everything up..
The flywheel did have an O-ring in it.
The clutch didnt appear oily, and the flywheel wasnt too bad it was mainly the inside of the bell housing (some of which could have been tranny fluid) and the inside of the case around the seal.
Most of it looked like old buildup.
I keep falling into the Sarlacc pit of while its apart, i should fix that, but it would be nice if he could drive it some while hes still in school.
But, if im going to be courting disaster by doing that, please tell me , cuz theres no guarantee even if i just slapped together the engine tommorow, itd be ready before it snows.
Tcash: IF I can patch it together for now, what is the right part for the soft iron gasket? that isnt whats on there now? _________________ Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Sun Sep 06, 2015 8:37 pm Post subject: |
you need to discard that shim and reset your end play. problem is, that giant chunk out of your crank will never allow that o-ring in the flywheel to seal. either way, I think you will have a bit of a leak
the only thing you can do is get that black piece of shit seal out of there and hope you get a decent quality orange/red seal.
depending on the size of your gland nut washer, you can put juuuusssst a little bit of RTV on the dowel pin heads before you send it home for good. this will hopefully stave off any leaks past the o-ring
also get a proper flywheel seal installer. trying to pound on in is like pissing up a rope. you need the installer to help keep the seal with the centerline of the crank. 99% of the time the crank centerline is off, so putting a seal in "straight" won't help. the seal needs to follow the centerline of the crank and flywheel _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Sep 06, 2015 8:46 pm Post subject: |
Yarkle wrote: |
Tcash: IF I can patch it together for now, what is the right part for the soft iron gasket? that isnt whats on there now? |
Only the VW gods can answer how well it will turn out if you go the hurried route. I have had incredible successes in a hurry, and I have been completely left out to dry in a hurry. Only you can say if the results and risk are worth it.
I will say, that cleanliness is next to godliness when diagnosing and preventing future leaks. I think a main seal replacement and transaxle input shaft seal are both necessary here. Your spotless end play of .003" will now be an unacceptable .008" because the shim is mangled, so you'll need a shim set. Aircooled.net sells packs with all the different sizes. It's handy, because a new .024" will be thicker than a high milage shim labeled .024".
I often sound like a broken record on this, but some aftermarket pressure plates don't fit in the VW flywheels properly. The flywheel has a "shelf" around the outermost inch that should hold the pressure plate centered. The problem is, new pressure plates are a few thousandths too small, so they do not center themselves. You will need to do your best with a micrometer, measuring around the edges, or use conical bolts to get it started, then replace them with the correct bolts BEFORE tightening the plate down. Still then, check for centered-ness.
Skills is right about the black seals, I have never been able to keep one dry. Try the Elring German reddish orange seal.
The inner seal is actually a graphite-impregnated o-ring, available from most parts shops, PN: 021 105 279, fits T1 ACVW engines from 66ish, onwards.
http://www.autohausaz.com/pn/021105279 _________________ Learn how your vintage VW works. And why it doesn't!
Yarkle Samba Member
Posted: Mon Sep 07, 2015 9:16 am Post subject: |
thanks Fellas!
K, i think what im going to do is have Caleb take the flywheel to the machine shop after school one day and see what they think, and ill order the:
o-ring seal
shims
soft gasket (what part # is this?)
red seal (actually i think i already bought one and i already planned on the trans input seal)
big washer for gland nut per skills suggestion
Ill fiddle with it today or tommorow or the next day and see if i cant figure out what shims i need, as im sure ill need some random combination as opposed to what comes in a regular set.
any other ideas? suggestions?
if it leaks, well, winter project. No guarantee itll be ready before snows and salty roads even if i dont tackle this particular sarlacc pit , we'll see.
Yarkle Samba Member
Posted: Mon Sep 07, 2015 11:02 am Post subject: |
I did this as another reply instead of an edit to alert watchers. cuz i need advice!
K, with no black seal, no oil, no shims, no soft gasket, end play is .041.
I think Tcash's suggestion of the metal gasket is a good idea, as theres been some sort of shenanigans going on in there, and it might be necessary to clear the dowels.
It looks like the soft gasket is .005, plus .003 so that plus a .0095 + .0095
+ .0141 puts me at .0411
does that seem right? or do i want to use a .0126 for the last one to give me .039 total,
damn, this is hurting my head.
if i get the flywheel resurfaced, cleaned up, will that effect endplay? _________________ Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
Tcash Samba Member
Posted: Mon Sep 07, 2015 2:25 pm Post subject: Flywheel installation |
I'll have Caleb take the flywheel to the machine shop after school one day and see what they think
Have him take the Dowel Pin that came out and have it mic'd. Get a new one the same size. Grind it down to the same length as the old one and install the ground end into the crank hole.
If you can loose the shim. But if you must use it. Use one of these. Use one to check end play and a new one for final assembly.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-5092
First put the flywheel on the crank without the shim. With the flywheel installed the dowel pins must be recessed in the flywheel holes. If they are even with the flywheel or protruding, you need the shim. Or the gland nut will hit them and not be able to secure the flywheel to the crank.
Another option is to stuff a rag around the crank and grind down the dowel pins slightly.
The flywheel must not rock when pushed against the crank by hand. If it rocks it needs machining or the crank needs machining.
1. Have the machine shop mic the dowel pin that came out. Get a new one grind to size.
Clean the pin hole so it is shinny. Install the new pin with red loctite.
2. Have the machine shop check the flywheel mounting surface. You may need a new flywheel.
I would not machine the clutch surface unless it was absolutely necessary.
I. not many machine shops know how to do it correctly.
II. if it is german I would make it last as long as I can.
Bruce wrote: |
Things to check:
The depth of the disc surface from the mounting face on your flywheel should be 21.0mm. Every used FW I have measured was out of spec. What happens is that clutch shops don't know this spec, so what they do is take their grinding wheel down to touch the disc surface, then they zero their machine. After they've cleaned up the disc surface, they take a reading on how much they removed. Then they move up to the shelf and remove the same amount. (some shops are so incompetent they don't even do this) The problem this creates is that the disc surface has been worn away over the years, and the depth has increased. When the shop grinds your FW the way I described, they are preserving that wear for the FW's next life. After it's been reground a few times they can get quite far off. Last time I had my FW reground, it was off by .75mm. The guy at the clutch shop was reluctant at first, but I was eventually able to get him to do it right. I only use original VW 30+ year old flywheels.
The next thing to check is the disc thickness. A few years ago there was a batch of discs on the market that were too thick. I can't remember what the thicknesses were, so you will have to do some investigating. |
3. Clean everything so it is shinny.
4. Set end play.
With soft iron gasket if needed. Use old gland nut for checking.
http://www.aircooledtech.com/end_play/
5. Final assembly. (No dowel gasket)
Install flywheel shims.
Install flywheel seal. Oil inner lip.
Install the O-ring in the flywheel dry. No sealer
Apply loctite flange sealant sparingly to flywheel mating surface. (crank is beat)
Fit flywheel to crankshaft.
Slide washer on gland nut. Smooth edges out.
Apply red loctite sparingly to gland nut and install.
Install flywheel lock.
Install torque tool.
The general consensus is to torque the gland nut to 350 ft lbs. If anyone wants to debate this please do it in another thread.
Confirm end play.
6. Final assembly. (With dowel gasket)
Install dowel gasket. (no sealer)
Confirm end play. |
Tcash Samba Member
Yarkle Samba Member
Posted: Mon Sep 07, 2015 3:05 pm Post subject: |
TCash, you put the "swag" in volkswagen!
just to confirm, cuz im a little fuzzy:
1. the dowel flywheel gasket is what you are calling the soft iron gasket?
2. at the machine shop, im not sure what Caleb should tell them--I think its
should he tell them the flywheel mounting surface must be 21mm?
3. he should just bring in the dowel and say "make me this?"
(I have to send him cuz My work schedule doesnt jive with the few machine shop around here..im a mailman so now i gotta work late-catalog season)
Ill get the stuff i dont have once I get paid, so itll be a few weeks probably before everything shows up, especially if i need a new flywheel... but ive got plenty to do in the meantime.
Caleb is still battling the transmissiion grease, and ive been removing the engine accoutrements.
Thanks for all the help and advice, sambanistas!
What Caleb started with: (and thats with a can of degreaser already)
what he ended with just now:
his getup..wearign one or two size too small shirts his mom wont let him discard, and his czech gas mask
What i started with:
what i ended with (Trucka isnt sure I know how to put this back together--he might be right--but my Samba friends do!)
Tcash Samba Member
Posted: Mon Sep 07, 2015 6:32 pm Post subject: |
Yarkle wrote: |
I don't know how much swag I have. But thank you.
Forgot to mention. There are 8 holes, but 4 of them will line up.
Email them this quote.
Bruce wrote:
Things to check:
He could. There are two diameters you can buy. 8mm - 11/32", they may need to be shortened, but the diameter should be the same.
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Tue Sep 08, 2015 9:34 am Post subject: |
lil-jinx wrote: |
Could he not use a hard bolt for a dowel,just cut off the head and the treads and cut to to length. |
I'm not so sure about that. The precision required of the crank-to-flywheel fit is not something we went to mess around with when we hit a 4,400 RPM shift to get our ass out of the way of a drunk driver. Think about fifteen pounds of cast iron spinning that fast. It MUST be true and tight. _________________ Learn how your vintage VW works. And why it doesn't!
