Paulbeard Samba Member
Posted: Sun Aug 09, 2015 11:13 am Post subject: |
The latest ECU for the Tiico requires new injectors that have a groove that not all of them have: sending any eBay purchases to him for cleaning makes sense but would he be able to machine the grooves if I can't find the right ones? I can ask him but I wondered if anyone had experience with this. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
IoWesty Samba Member
Posted: Mon Aug 10, 2015 5:22 am Post subject: |
As an aside, when replacing the rubber hoses, what do you use to cut the fuel lines to proper length? Will a utility knife work, ot is there a better way? |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Posted: Mon Aug 10, 2015 8:47 am Post subject: |
Paulbeard wrote: |
The latest ECU for the Tiico requires new injectors that have a groove that not all of them have: sending any eBay purchases to him for cleaning makes sense but would he be able to machine the grooves if I can't find the right ones? I can ask him but I wondered if anyone had experience with this. |
Probably not, judging from his website it looks like he only cleans. I'm wondering what the significance is of the groove. I'm guessing the injectors are a different impedance. Or another way of asking... What difference will machining a groove make? Are they being held differently? Sounds like more information/research is needed. I'd be looking for exact part numbers to work with/cross reference.
IoWesty wrote: |
The best tool one can have to cut rubber hose is the same tool plumbers use to cut small diameter pvc pipe. This can be found at any of the big box home centers. Here's a visual, just as an example:
http://www.amazon.com/Dawn-Industries-T100-Origina...ose+cutter
djkeev- That's good turn around time actually, if you consider most of the time spent was sitting in the mail going back/forth between you and Mr. Injector.
-Kevin _________________ 1986 Westfalia Weekender Wolfsburg, RJE 2.3
1985 Tin Top, Subie 2.2 + 5MT
Floppy Mirrors no more: http://www.thesamba.com/vw/forum/viewtopic.php?t=653018&highlight=
Remove the front spindle nut with ease: https://www.thesamba.com/vw/forum/viewtopic.php?t=679567&highlight=
Remove the rear wheel bearing housing without messing with the big 46mm nut: https://www.thesamba.com/vw/forum/viewtopic.php?t=679507&highlight=
-Nec Spe, Nec Metu |
Posted: Mon Aug 10, 2015 12:28 pm Post subject: |
61Scout wrote: |
Paulbeard wrote: |
-Kevin |
It's to accommodate a clip, best I can tell. Some people use hacksaws (!) to git'r done. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
tjet Samba Member
Posted: Mon Sep 14, 2015 6:13 am Post subject: |
I just sent in my injectors below.....
Note, the post office had a problem with the Mr. Injector address (no record on file). I sent them anyway....
tjet Samba Member
Posted: Wed Sep 23, 2015 5:14 pm Post subject: |
Just got my injectors back. I shipped them last Monday
Check out the before & after
Note, I didn't send them the busted injector in the other pic...
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
bluebus86 Banned
tjet Samba Member
Posted: Wed Sep 23, 2015 6:45 pm Post subject: |
My original injectors worked kinda ok until I replaced all the fuel lines last month. I dropped an injector on the porch & the impact killed it (see injector 1 on the spreadsheet).
Looking forword to getting this van back on the road with the rebuilt injectors
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3417 Location: OR & CA (Oregon/California)
Posted: Wed Sep 23, 2015 7:09 pm Post subject: |
so.. is there any difference from send them out to be cleaned and calibrate versus getting the rebuilt from VC or GW?
thanks |
tjet Samba Member
Posted: Wed Sep 23, 2015 7:16 pm Post subject: |
The price. Came to $74 w/ship.
Mine were ugly & I figured at least one was beyond repair, but all were ok to fix |
Posted: Wed Sep 23, 2015 10:19 pm Post subject: |
tjet wrote: |
Mine were $78 and came back with test sheets and candy. Glad there are people like this out there… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
tjet Samba Member
Posted: Thu Sep 24, 2015 2:49 am Post subject: |
Paulbeard wrote: |
tjet wrote: |
Mine were $78 and came back with test sheets and candy. Glad there are people like this out there… |
So I guess they were able to modify your injectors and added the grooves?
Note, the green candy is sour |
Posted: Thu Sep 24, 2015 7:36 am Post subject: |
tjet wrote: |
Paulbeard wrote: |
tjet wrote: |
I think I have the correct pre-grooved ones, from the fuel rail assembly I bought and returned the rest of. The new one arrived from Germany yesterday, looking minty fresh. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
jwallis Samba Member
Posted: Sun Mar 06, 2016 5:54 pm Post subject: Re: Mr. Injector feedback... |
Just got mine back from Rich at cruzinperformance.com.
Steps he does: http://cruzinperformance.com/injsteps.html
which include replacement of screen and pintle (hopefully standard for any rebuild).
Total cost is $19/injector + return shipping ($10 for me, several states away).
Very nice working with him. He just had shoulder surgery so his turnaround right now is a little slow but I imagine he'll be back at it once he's done with rehab. I told him to take his time as I'm in no hurry, shoulder health is more important than any dumb injectors.
Recommended. _________________ TheVanTracker.com - Kill Switch + GPS Tracker + Door-open alerts, made specifically for the Vanagon!
50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
Popsvan Samba Member
Posted: Sun Mar 06, 2016 7:32 pm Post subject: Re: Mr. Injector feedback... |
Does anyone have any real feel changes other than the flow tests provided? I want mine rebuilt have the new rails, just have to pull and ship. Just wondered if anyone installed the rebuilt and noticed a performance ( that sounds silly on a Vanagon) or a temp, idle difference?
Thanks _________________ Rory
Louisa VA
87 Westy Automatic |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Sun Mar 06, 2016 7:46 pm Post subject: Re: Mr. Injector feedback... |
I noticed a better idle and a more even from pull from the lights and on the freeway right away when I had my injectors rebuilt. Vanagon injectors definitely benefit from being cleaned and I consider it money well spent.
I did not use Mr. injector though. |
Posted: Sun Mar 06, 2016 7:51 pm Post subject: Re: Mr. Injector feedback... |
syncrodoka wrote: |
Thank you I look forward to getting this done. _________________ Rory
Louisa VA
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Sun Mar 06, 2016 9:29 pm Post subject: Re: Mr. Injector feedback... |
He has done about 20 for me and no problems so far. Some of them tested bad so I had him trash them instead of sending them back. I keep a rebuilt set here if any one needs to do any testing. |
