ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Mon Jun 29, 2015 5:12 am Post subject: IRS camber change |
Does anyone know what camber change an irs suspension goes through as it's compressed (or when the rear is lowered)? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Jun 29, 2015 8:56 am Post subject: |
Should go to slight negative camber... Not nearly as sever as swingaxle...
mark tucker Samba Member
Posted: Mon Jun 29, 2015 9:12 am Post subject: |
I made some excentric bolts to counteract that action. |
ALB Samba Member
Posted: Mon Jun 29, 2015 1:16 pm Post subject: |
I knew that it wasn't nearly as much as a swingaxle, Dale; I'm hoping someone knows how much. For example, what's the difference from standard ride height to lowered 2"?
Mark- Would you be able to take a pic of those? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
pdub Samba Member
Posted: Mon Jun 29, 2015 2:42 pm Post subject: |
Hmm, well I turned my torsion bars down to raise mine as far as I could with stock CVs and I had no noticeable change in camber. |
Posted: Mon Jun 29, 2015 3:00 pm Post subject: |
no I dont do pics. they can be machined with a offset & then a tube slid over them to bring back to size add some antiseeze between.there are other ways of doing it also.it also can be used to affect toe at the same time so that has to be checked while your doing it. |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Tue Jun 30, 2015 1:40 am Post subject: |
I had my car down two inner splines for a short period, and the top of the tire was inward about a half an inch more. The two splines was quite low, and I ended up going back up two splines in the end. What's a half inch over a 25 inch diameter tire, maybe 4-5 degrees? |
