VWDog Samba Member
Joined: June 24, 2005 Posts: 617 Location: Ladysmith, BC
Posted: Mon Jun 29, 2015 6:57 pm Post subject: Help! Pop top to luggage rack seal 79 Westfalia |
Stupid question probably, or one that could just be dealt with by common sense(which I apparently have none of regarding this)…..but how is the joint between the side seal and the flat seal(the one over the top on the lifting top) supposed to look? I have it like this at the moment, but before doing the other side I need some input from people more in the know. From what I gather from the very poor directions sheet from WCM they want me to cut the "pinch welt" 1" back from the end. Then the rubber "o" seal at the back will tuck " under the extrusion you previously installed so that you will have a good seal and appearance". Clear as mud in my eyes because I can only see the round seal binding up as one closes the roof. Any hints to elaborate how this joint is accomplished? Pics would be great too!!
Here is what I have now to get some glue surface. It is not yet glued. Pardon the blurry pic…
Many thanks for your input!! I need to finish this Westy _________________
1970 Lotus White Single Cab 2015- , 1979 Sage Green 2014-2015, 1978 Dakota Beige Westy 2012-2015, 1978 Neptune Blue Riviera 2012-2017 , 1970 Neptune Blue Bus 2010-2012, 1970 Deluxe Savannah Beige 2010-2012, 1985 Iltis 2010- , 1962 Single Cab 2010-2013, 1975 Brasilia? Bay/Split Kombi from Brazil 2008-2011, 1985 DoKa 1999-2009, 1971 Bus 1999-2000, 1968 Double Cab 1991-1998, 1965 Ghia 1987-1991, 1970 Westfalia-bought by Mum and Dad in 1970, sold by me in 1993 why-oh-why :_(
VWDog Samba Member
Posted: Tue Jun 30, 2015 7:47 pm Post subject: |
Well so much for getting any info. To tie off this thread in case anyone else happens to be in need….Turns out by fluke I had a Bus Depot one on hand and used that like I have seen here when doing a search. I highly recommend the BD one!! No glue and matching profiles. Easy-peasy _________________
crushie Samba Member
Joined: September 23, 2011 Posts: 878 Location: alberta
Posted: Tue Jun 30, 2015 8:21 pm Post subject: |
I feel your pain. I also found zip info on the seal joint and just went off the cuff. Not exactly sure how it's supposed to fit. It seems though that the roof sections don't line up perfectly so having a joint that seals well and looks proper may not be an option. So if you line up the two joints on the long section of the roof, they don't then line up with the luggage section. You end up with some weird looking joints. _________________ 1974 VW Combi 1800 Auto. Weber 32/36 |
Posted: Tue Jun 30, 2015 8:22 pm Post subject: |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51131 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jun 30, 2015 10:16 pm Post subject: |
The sad deal with this issue is it's uncharted territory, the OG seal had a sweet 45 degree welded seam, reproducing it in modern materials with home methods is going to be a challenge regardless of how you choose to join them. The OG seal was much more rubber like on the pop top edge and less like the hardish vinyl on the "as close as it gets off the roll" stuff supplied now.
Props to Ron at BD for at least making an effort to find something close, it's far better than nothing at all, maybe some urethane to glue it together would help, just make sure it has a drain hole at the lowest points. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
VWDog Samba Member
Posted: Wed Jul 01, 2015 7:08 pm Post subject: |
I didn't use any sealant or glue. If you are 7' tall and 4 feet away it looks like I left it a little long, but when it is up it matches the pop top seal. I will see how it looks when I get the Westy off the jack stands and cut more off if necessary
Here is the profile of the Bus Depot seal
mr matt Samba Member
Joined: May 26, 2005 Posts: 819 Location: southeast Pa
Posted: Sun Sep 29, 2019 11:47 am Post subject: |
VWDog wrote: |
I am putting this seal on currently, little confusing as there is a difference in this seal top vs bottom.
One side of the seal has more of a bump where it slides on the roof, the other side is more flat.
Which goes up? I am putting the more flat side up, but read somewhere that someone put theirs on upside down and could not fully close the pop-top..
Unfortunately he did not say which way was up.
THanks! _________________ 1955 3-fold semaphore Oval beetle
1971 Convertible beetle
1977 Westfalia, FI, Berlin interior |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Sun Sep 29, 2019 2:59 pm Post subject: Re: Help! Pop top to luggage rack seal 79 Westfalia |
wow! thanks for doing that!
SO maybe I am putting it upside down ( of course) , if it works for you, and the top closes fine, will flip it now while the top is off & resting on my workhorses.
Mine is also from Bus Depot. _________________ 1955 3-fold semaphore Oval beetle
