Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Posted: Thu Jul 16, 2015 3:45 pm Post subject: |
It's formulated for high altitude use, and has a low volatility behaviour that will make it run like crap on the street. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379 |
Posted: Thu Jul 16, 2015 6:00 pm Post subject: |
Boolean wrote: |
It's formulated for high altitude use, and has a low volatility behaviour that will make it run like crap on the street. |
That sounds like something that someone who has never used it would say. Granted if you do not need that high of an octane number, it would be a total waste, and "could" allow your engine to run to cold. However, if you need that octane, it works great, and at a far cheaper cost then race gas. I don't run it in any of my VWs because premium is all that I need, but I have used it when it was quicker to dump in 5 gallons, than hit a gas station on the way to work. Did my car run any different, NOPE. However, that is all that I use in my dirt bikes and mini buggy. Of course, all of their motors are a little pumped up _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
ac509 Samba Member
Joined: September 20, 2012 Posts: 160 Location: moved
Posted: Thu Jul 16, 2015 6:02 pm Post subject: |
i only come to this website for the laughs and it never fails to bring satisfaction. _________________ Dumber people are doing harder things everyday.
No one questions a 73' Volkswagen?
I have a '73 Volkswagen and it is nowhere near 73' long! |
ac509 Samba Member
Posted: Thu Jul 16, 2015 6:14 pm Post subject: |
Multi69s wrote: |
ac,
glad we could be of service |
heck yeah.
i have ridden in cars running on avgas (good thing airplanes never have to run on the ground since it is only formulated for high altitude - how do they get into the air?!?!?). i have driven cars on E10 for years and years and over 400,000 miles. same injectors, same fuel pump, same fuel lines. i have friends that run E85 daily. how can we have so much conflicting information?
i truly don't understand... _________________ Dumber people are doing harder things everyday.
Posted: Thu Jul 16, 2015 6:39 pm Post subject: |
Well, gas aircraft engines actually run like crap on the ground...
Especially at idle and lower throttle settings.
Now, this is acceptable to some.
Congratulations. _________________ I strive for perfection. Excellence will not be tolerated!
Build thread here:
RTope13 Samba Member
Joined: July 10, 2012 Posts: 106 Location: North Ogden, Utah
Posted: Fri Jul 17, 2015 9:30 am Post subject: |
I'll just throw this in there. here in my area of Utah; i use 88 octane Ethanol free gas. there are stations out there. Depending on where you are they could few and far between but this link may help you find them wherever you are.
http://pure-gas.org/
I saw an immediate difference. 4-5 MPG better. well worth the .25 a gallon more here. |
vwsb74 Samba Member
Posted: Fri Jul 17, 2015 11:05 am Post subject: |
Can you mix premium with 100 octane ethanol free gas? I'm asking coz I found 2 stations near me selling ethanol free _________________ 74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢 |
Posted: Fri Jul 17, 2015 12:29 pm Post subject: |
Yes you can, but do you really need to. What are the specs of your engine? Size, cam, CR and carburation. If you do not need a high octane number, then why waste the money. Remember, octane does not give you horse power, it just give you the ability to make more (higher CR, more cam, and more ignition advance). _________________ 69 road Bug 2110
My builds
vwsb74 Samba Member
Posted: Fri Jul 17, 2015 5:23 pm Post subject: |
Multi69s wrote: |
Yes you can, but do you really need to. What are the specs of your engine? Size, cam, CR and carburation. If you do not need a high octane number, then why waste the money. Remember, octane does not give you horse power, it just give you the ability to make more (higher CR, more cam, and more ignition advance). |
I have high cr engine . 170hp. _________________ 74 super beetle
2014 Honda odyssey
2180cc 48IDA clone
Zundfolge1432 Samba Member
Posted: Fri Jul 08, 2016 4:26 pm Post subject: Re: Ethanol Free Fuel |
Yes I'll revive this thread per Everetts's urging. Ethanol is crap, its a political tool used to subsidize the corn industry.
Last edited by Zundfolge1432 on Fri Jul 08, 2016 6:27 pm; edited 1 time in total |
T Hollis Samba Member
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sat Jul 09, 2016 5:58 am Post subject: Re: Ethanol Free Fuel |
LOL Good luck with that list as it is not kept up to date _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Sat Jul 09, 2016 7:51 am Post subject: Re: Ethanol Free Fuel |
60ragtop wrote: |
LOL Good luck with that list as it is not kept up to date |
Still accurate in my area. |
Posted: Sat Jul 09, 2016 6:42 pm Post subject: Re: Ethanol Free Fuel |
T Hollis wrote: |
60ragtop wrote: |
Also accurate here. We have a choice here |
mark tucker Samba Member
Posted: Sat Jul 09, 2016 7:40 pm Post subject: Re: Ethanol Free Fuel |
so cant the bars subsidize the corn holers and industry at the same tyme? and it seems to me that a lot of aeroplanes have adjustable carbretters so they can leen them out or richen them up for the changes latitude's..oops altitudes...attitudes.... witch our bugs dont usualy have. so if you tune the av gas for your bug it should be fine...if you can tune it as in have the ability. just like racing fuel, it needs to be tuned for it.
As far as the ethanol free....I think they charge for it around hear. |
