obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2940 Location: East Northport, NY
Posted: Thu Jul 02, 2015 4:01 pm Post subject: Muffler and exhaust noise |
I'm currently running this exhaust:
http://www.busdepot.com/352000
When it first went in, I loved it because it was markedly better than my crappy 4 tip EMPT GT style muffler.
Now that it's a few years old, it constantly sounds like it is "popping" or that the engine is missing - though it's not.
I'm considering going back to the factory type exhaust.
http://www.busdepot.com/071251053can
Does anyone know of a diagram which illustrates which pieces I need? I know there are quite a few pieces. I would prefer to avoid using the cat if possible. But either way, I suspect the correct exhaust will "level out" my bus' exhaust note.
Thanks! _________________ Mike
1964 Beetle
2001 Eurovan Camper |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51146 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 02, 2015 4:21 pm Post subject: |
So the crossover pipe connects both of the beater boxes, then on the end of the crossover pipe the elbow turns the exhaust 180* then is the cat delete pipe (anyone have a p/n?) follows by the clamp and muffler and lastly the tail pipe?
Is this a specific hanger strap?
I don't see either the strap or delete pipe listed in bus depot. _________________ Mike
1964 Beetle
oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Thu Jul 02, 2015 4:30 pm Post subject: |
Are you sure you don't have an exhaust leak somewhere? I have the same muffler on my Bus, and I was getting similar symptoms to what you are saying, especially the popping noise when I released the throttle. I pressurized my exhaust system and found I was leaking between the exhaust manifold and the head on the passenger's side. I repaired it, pressurized the system again, and found I was leaking on the driver's side as well. Not from the seal, but from the weld between the exhaust manifold flange and the pipe itself. No more popping. My muffler is almost new, so I can't say how it will sound in a few years. Just wanted to throw my experience out there. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
Posted: Thu Jul 02, 2015 4:59 pm Post subject: |
Oscar, I thought it may have been. But it sounds like there's something inside the muffler. It has been suggested that perhaps one of the baffles has broken loose. I checked around, and so did my mechanic after I came up entirely befuddled.
Busdaddy, I took to BusDepot, armed with your post, Google and my Bentley.
Does this look like the parts I need? Minus that crossover pipe which is apparently NLA. This might be the time to put on my new heater boxes too...
1964 Beetle
Posted: Thu Jul 02, 2015 5:15 pm Post subject: |
Seems you have most of it covered, you'll still need a handfull of 8mm bolts and nuts to hold it all together. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Thu Jul 02, 2015 7:53 pm Post subject: |
would you humor me and double check your valves some morning when they are cold? Be sure to lay a straight edge across them to see if any are significantly higher or lower than the other. That weird pop can also be a valve starting to give trouble.
That said, don't pay too much on a cross over pipe. When they come up for sale as onezee twozee everyone wants and arm and a leg. When they appear in mass they end up lying around unsold. The elbow comes as original and Dansk. Some of the folks with the Dansk have had them split. The originals in good condition are hard to find. NOS German VW of both parts show up occasionally. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jul 03, 2015 7:29 am Post subject: |
Barring something acute and catastrophic, they were just checked.
I suppose something could have been left loose. I'
Ill pop the cover off one morning to see if something is awry.
Check the video I just shot of it running:
1964 Beetle
Posted: Mon Aug 21, 2017 1:44 pm Post subject: Re: Muffler and exhaust noise |
Was cruising through NYC yesterday and the muffler slid out of the CAT delete pipe and was hanging down through the Mid Town Tunnel... Besides my sounding like a racecar, it wasn't a cool experience. I was worried the muffler had fallen off altogether but couldn't see it behind me. There is a slip fit joint there, with a flange, where a donut ring creates a seal and a clamp binds the two together. The clamp is good, and I presume the issue occured because I recently replaced my muffler strap which was loose/bent after the engine work this past winter.
That all aside, the donut is trashed and I still have a decent exhaust leak (and subsequent loud noise)
Since I had a hard enough time finding the clamp, I assume noone will sell just a donut - if I was even able to find one.
Can I make a ring from epoxy putty, like a JB Weld putty? Or should I just cut and weld the CAT delete to the muffler? _________________ Mike
1964 Beetle
