67ctbug Samba Member
Posted: Tue Oct 10, 2017 2:37 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
I just broke all the stitch welds by bending it... _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
xzener Samba Member
Posted: Tue Oct 10, 2017 3:00 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Is the gas on a regulator? If so, what psi is it set to? The welds still look as though they are on the verge of blow through. Try adding a little more speed to the wire.
Should look more like this...
_________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Tue Oct 10, 2017 3:04 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
You should be able to bend the metal as if it were never two pieces. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
c21darrel Samba Member
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Tue Oct 10, 2017 3:15 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
67ctbug wrote: |
I just broke all the stitch welds by bending it... |
Increase your shielding gas. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Posted: Tue Oct 10, 2017 3:21 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
CiderGuy wrote: |
67ctbug wrote: |
Increase your shielding gas. |
Just found out I'm out of it... But I've had the same tank since January so it's expected. Gonna get more on Friday or Saturday. I'll do what you guys said to the dials. The gas is set to around 20 psi. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Wed Oct 11, 2017 1:35 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
You can tell when there is no shielding gas just by looking - if the welds are dull and porous this is a sure sign _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Sun Oct 15, 2017 2:37 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
If you're getting holes in you're welds you need more wire. Increase wire feed a little. The arc is burning through faster than the wire can fill it. _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
Posted: Thu Nov 02, 2017 3:48 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
I used the same settings, same gauge steel, and all the same other things, but they look so drastically different!
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
xzener Samba Member
Posted: Thu Nov 02, 2017 5:42 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Those top picture welds are beautiful. Is the metal on the car thinner? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Thu Nov 02, 2017 5:48 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
The hole in the top piece is where I cut the patch from... Same gauge, same settings, same everything. If anything the car has thicker metal that I'm welding to. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
xzener Samba Member
Posted: Thu Nov 02, 2017 5:51 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Where are you clamping the ground cable? I would try and get it as close as your top picture was. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Thu Nov 02, 2017 5:52 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
It's where the washer bottle usually sits. I'll try to get it closer tomorrow. I cant think where to put it since the front apron is curved. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
xzener Samba Member
Posted: Thu Nov 02, 2017 5:54 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Right above where the trunk lip is. Should be a very good location. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Thu Nov 02, 2017 5:55 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Alright, I'll try there. I'll have to grind some paint. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sat Nov 04, 2017 11:12 am Post subject: Re: Eastwood 135 MIG on sale for $200 |
Interesting... 22 gauge steel and no holes. But I try to do the Same on my car and I fail miserably
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sat Nov 04, 2017 11:46 am Post subject: Re: Eastwood 135 MIG on sale for $200 |
I stand corrected...
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Exaktaphile Samba Member
Posted: Sat Nov 04, 2017 1:59 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
I have the same welder and just finished replacing the bottom 6-inches of the car. You just need a little practice on scrap.
Also, hold the nozzle with your free hand (wearing glove and resting against the car) to stabilize the torch and help put the wire exactly where you want it. Use your nozzle hand as a gauge to control the stickout and help avoid snail-like blobs.
For 22gauge like you're using, I'd set amp and wire feed knobs both at 3 and C with 1/4" stickout and make very small adjustments from there. Turning the knobs a full setting is far too big of an adjustment; just move it a little bit. An alternative to changing adjustments is to hold your nozzle closer/further from panel to get hotter/cooler welds.
Here's a pic of tacks on my channel.
Posted: Sat Nov 04, 2017 3:02 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Thanks for the tip man I'll try that. Your welds are what I wish mine looked like... _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'73 Dodge W200
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
xzener Samba Member
Posted: Sat Nov 04, 2017 3:52 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Always trim the wire after every spot weld too, and clean the surface your welding with a wire brush. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
