xzener Samba Member
Posted: Sat Nov 04, 2017 3:53 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Looks like it helped getting the ground closer to the area you were working. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
67ctbug Samba Member
Posted: Sat Nov 04, 2017 6:19 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Xzener, yes it did, but it doesn't help I have to use an extension cord. I trim the wire anyway, I get a little glob of wire on the end if I don't. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Braukuche Samba Member
Posted: Sat Nov 04, 2017 7:57 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Just use flux wire and forget the gas. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Sat Nov 04, 2017 8:12 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Braukuche wrote: |
Just use flux wire and forget the gas. |
Why? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sun Nov 05, 2017 9:31 am Post subject: Re: Eastwood 135 MIG on sale for $200 |
67ctbug wrote: |
Braukuche wrote: |
Why? |
You don't have to mess with gas settings, it's more forgivable when it comes to material, if you are welding outside you don't have to worry about the wind blowing your shielding away. I know a lot of guys insist on gas, and you do get cleaner welds, but flux also has its advantages especially if you are having problems with using gas, I'd give it a try, I've used it for decades now with no problems, but to each his own. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sun Nov 05, 2017 12:23 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
I used flux for a year with bad results. My problem isn't the gas, but burning holes. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Exaktaphile Samba Member
Posted: Mon Nov 06, 2017 2:47 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
The little glob on your wire is a sign to turn the wire speed up. Remember to use one hand on the nozzle and keep a constant stickout.
When the wire speed is right, there will be no glob. If the speed is too high, you can feel the wire hitting the bottom of the puddle before it melts (it will push the nozzle away from the work surface). |
Posted: Mon Nov 06, 2017 2:50 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Alright I'll turn up the speed. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Tue Nov 28, 2017 2:29 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
I made a video and this just ain't looking right...
The primer IS weldable. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
c21darrel Samba Member
Posted: Tue Nov 28, 2017 3:14 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Okay, the nozzle is meant to be placed on the metal, it has a 1/4 inch lift on it for spot welding. I'll get rid of that primer. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Wed Nov 29, 2017 2:25 am Post subject: Re: Eastwood 135 MIG on sale for $200 |
You seem to be trying to spot weld either side of a butt weld, so I would forget the spot weld attachment and try and learn to MIG weld first. When I was getting crappy welds I found that I was holding the torch too close (not enough stick out) and not holding the trigger for long enough to give good penetration. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Wed Nov 29, 2017 11:21 am Post subject: Re: Eastwood 135 MIG on sale for $200 |
67ctbug wrote: |
Okay, the nozzle is meant to be placed on the metal, it has a 1/4 inch lift on it for spot welding. I'll get rid of that primer. |
Also an amateur , but I never had a problem with weld-through primer. My guess is you are not getting a good ground with the clamp. It needs to be a clean bare metal connection in close proximity to the area you are working on. |
Figment Samba Member
Joined: October 27, 2016 Posts: 218 Location: Connecticut, USA
Posted: Wed Nov 29, 2017 12:36 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
It's a spot-welder, but it uses a wire feed? Why would spot-welds need filler?
(unless this is a vocabulary thing and we're confusing "spot weld" with "plug weld"?)
I'll second Mellow Yellow... go back to a normal MIG setup and learn to manipulate the current/power and speed/feed settings. _________________ '71 Ghia coupe |
Posted: Wed Nov 29, 2017 2:57 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
It's a mig welder with a nozzle used to make plug welds. My other nozzle disappeared _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Wed Nov 29, 2017 5:02 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
That tip could be a nice little tool for you one day. At this point i would go get a normal mig tip for your set up and practice mig welding in the traditional way. Build your skills, good welding is something you can hear, you don't even have to see to know you are getting good penetration. If you hear bacon sizzling you are doing it right. If you hear inconsistent arcing something is wrong. 90% of panel replacement welding are tacks. Tack, wait, tack, wait. Move to the farthest side, tack, wait, tack, wait. Repeat. Or....sizzle, wait, sizzle, wait. _________________ GhiaBuild
1967 DC build
Posted: Wed Nov 29, 2017 5:27 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
I think that's the plug-welding tip Eastwood sells. You have no use for that right now.
c21darrell is right - get a new proper tip. You want to watch the weld being formed.
The type of questions you're asking indicate you need to stop getting in a rush and do some reading and youtube. |
Posted: Wed Nov 29, 2017 5:34 pm Post subject: Re: Eastwood 135 MIG on sale for $200 |
Alright, I'll swing by a store and get a new welding tip. I have tried adjusting settings, but the suggested setting is E-4... 4 being the wire speed. Well when I set that wire speed. I hear the motor trying, but the wire doesn't come out. If I bump it up to five, it works fine. Maybe the machine is messed up. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
