chromecarz00 Samba Member
Posted: Sun Jul 12, 2015 10:23 pm Post subject: 1st and 2nd gear in 3rd 4th gear slot |
Went to drive my 69 after a few days and it seems like the whole gearshift had shifted because I can't get into 3/4 gear. I've been searching and wasnt able to find anything on it. Thoughts? |
Brian Samba Moderator
Posted: Sun Jul 12, 2015 10:42 pm Post subject: |
Did you change anything? Your shifter could have gotten out of line. Is it hard to go to the 3/4 side or just nothing at all? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
nickfancher1 Samba Member
Joined: February 03, 2014 Posts: 282 Location: Phoenix, AZ
Posted: Sun Jul 12, 2015 10:46 pm Post subject: |
Change the coupler bushing for she shifter rod under the backseat. Also change the shifter bushing inside the tunnel under the shifter. Also adjust the shifter by loosening the 2 bolts and moving the shifter around so it is about in the middle then tightening them back up. _________________ 1970 Beetle |
Posted: Mon Jul 13, 2015 12:11 am Post subject: |
Haven't touched it, no. Impossible to get 3/4. I'll try loosening it and bring it back to center and see what happens. |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Mon Jul 13, 2015 7:47 am Post subject: |
Sounds like the hockey stick rotated in the new shift coupler.
When you reinstalled did you install a safety wife to keep the set screw from spinning? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Bruce Samba Member
Posted: Tue Jul 14, 2015 11:21 am Post subject: |
In the pic below is the late shift rod coupler. The steel part with the set screw is just crimped into the sheet metal cage. This crimp is known to come loose. When it does, the bushing can rotate in the cage. If it rotates, 1st gear will be where 3rd used to be or vice-versa.
I think this is what's happening to your car.
In every Beetle that has this coupler, the steel bushing must be welded to the cage. Even if your bushing is tight now, it will loosen up. Welding is good preventative maintenance.
airschooled Air-Schooled
Posted: Tue Jul 14, 2015 12:30 pm Post subject: |
I can't say for certain what your issue is, but I did have a fine-shifting car one evening, and the next morning I had no third gear, and I found a bad shift coupler. The odd thing was, it shifted perfectly fine until I let it sit overnight.
Anything is possible...
www.airschooled.com |
Posted: Tue Jul 14, 2015 1:11 pm Post subject: |
I was able to remove the two screws, recenter it and get it working.
Thank you all for your support and insight. |
Posted: Tue Jul 14, 2015 5:13 pm Post subject: |
which two screws?
the bolts that mount shifter to tunnel? or? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Tue Jul 14, 2015 5:14 pm Post subject: |
Yep those are the ones! |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Tue Jul 14, 2015 6:20 pm Post subject: |
Those are 'bolts' - not screws.
Good semantics go a long way for us who help you to understand what it is you are describing.
Nice to have a working gearbox eh? _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
kamesama980 Samba Member
Joined: June 22, 2014 Posts: 323 Location: Columbus, IN
Posted: Thu Jul 16, 2015 7:40 am Post subject: |
I agree with that definition. It describes the item in question. Unfortunately I've heard a lot of (major and official) places define a bolt as a faster that has a nut on the end to hold it in place while a screw is threaded into what it's holding together regardless of the end being tapered. I'm not as much a fan of that definition since you can take a bolt (with a nut) holding something together, remove the nut and thread it into something directly and suddenly it's a screw. calling it something different based on how it's used doesn't sit well with me because what do I call them sitting in a box on the shelf? _________________ -Russell
"You don't get to blame me for how I fix what you break"
1970 VW Beetle
1994 Pontiac Firebird
2001 BMW R1200C
2003 Subaru Baja |
Posted: Mon Jul 24, 2017 10:44 pm Post subject: Re: 1st and 2nd gear in 3rd 4th gear slot |
Having this issue again. I'm thinking I can make do with the same solution of readjusting and tightening the bolts, but does anyone know a more permanent solution or what could be causing it? |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Tue Jul 25, 2017 4:11 am Post subject: Re: 1st and 2nd gear in 3rd 4th gear slot |
chromecarz00 wrote: |
If the problem happened suddenly, my first guess would be the shift rod bushing broke, especially if there seems to be more side-to-side slop in the shifter. |
Posted: Tue Jul 25, 2017 1:27 pm Post subject: Re: 1st and 2nd gear in 3rd 4th gear slot |
It's always had a bit of side to side slop, so I'm not sure what's the normal amount. I was able to fix it last time by just adjusting the bolts on the shifter. It didn't look any more worn or broken with the quick look I took. Any advice? |
Bama Dave Samba Member
Posted: Tue Jul 25, 2017 1:40 pm Post subject: Re: 1st and 2nd gear in 3rd 4th gear slot |
Sounds like the shift rod bushing is kaput...probably not even there anymore. _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
Posted: Tue Jul 25, 2017 1:55 pm Post subject: Re: 1st and 2nd gear in 3rd 4th gear slot |
Actually described this issue wrong. I can't get into first without lifting reverse lock and second gear is tough to get into. I'm sure that doesn't change the prognosis though.
Is there a difference between super beetle bushing and regular? |
Posted: Tue Jul 25, 2017 2:26 pm Post subject: Re: 1st and 2nd gear in 3rd 4th gear slot |
No. Look here: http://www2.cip1.com/ProductDetails.asp?ProductCode=C24%2D111%2D701%2D259%2DASET _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
