Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jul 14, 2015 7:14 pm Post subject: |
Aluminum is still very soft... _________________ In Stereo, Where Available! |
stale air Samba Member
Joined: August 23, 2007 Posts: 5148 Location: Senoia Ga, formally NorCal
Posted: Tue Jul 14, 2015 7:39 pm Post subject: |
rkeyworth wrote: |
Ive never seen cork gaskets for the sump plate. Poster must have switched engine areas and was thinking of valve cover gaskets. |
I just misspoke. I said cork, but meant paper. _________________ WANTED: Henry Veale Santa Rosa plate frames
RandyV Samba Member
Joined: November 23, 2019 Posts: 357 Location: So Cal
Posted: Sat Jun 19, 2021 5:56 pm Post subject: Re: Leaky Oil Screen assembly |
Hey gang.......Any updates/suggestions for similar per my dilema below...
#1.) Changed oil on my new '56 (40hp 1200). I pulled plate & screen too but immediately noticed 3 of the cap nuts came off, but the other 3 (literally every--other one) came off with the stud.
#2.) Noticed some silicone used in the previous owners oil change. (Never a good sign)
#3.) Cleaned all surfaces & did a legit change
#4.) ONE of the studs had the dreaded nut/stud that will not tighten ---- i.e. STRIPPED CASE THREADS!
So I recall those stepped studs where you could "up" the size into the case, but as a couple of suggestions looking to get those 3 that the studs come out squared away (Maybe just RED LOCTITE those in??? or should I step those too??)
Or.........any better more modern solution all around? (I'm in the machine tool world so I have access to any size tap I need)
TIA |
sunroof Samba Member
Joined: October 06, 2006 Posts: 1746 Location: Winnipeg
RandyV Samba Member
Posted: Sun Jun 20, 2021 12:41 pm Post subject: Re: Leaky Oil Screen assembly |
Indeed, although I'm a fan of utilizing existing good holes while I can.
I have access to HeliCoil so will definitely do at least the bad hole + the 3 that have loosed their studs since I want to preserve the case's finite-life holes as efficiently as possible.
Without doing another oil swap & measuring myself right now.....Anyone know the thickness of the threaded part of the case there??
M6 x 1.0 inserts at the standard 1.5x thread diameter would be approximately 3/8" thick (more like .360" actually so just under 3/8") but I could also possibly get some 1x diameter inserts too.
TIA (y) |
