kamzcab86 Samba Moderator
Posted: Thu Sep 17, 2015 9:34 pm Post subject: |
mtwesty84 wrote: |
Love your setup kamzcab...have you had any issues running that ARB 50 on your setup with Solar? Wishing you had a bigger battery? |
No issues so far. The 100W panel tops the battery up within an hour of full sun hitting it. Parked at Laguna Seca for 4 days in August, the system never gave me any cause for concern.
I do wish I had more amp hours in the battery, but more for a margin of error, so to speak, and for potential system expansion (i.e. more electrical gizmos). The battery was already in place when I decided to replace the ice chest with an ARB, so I gave it a chance and it's been working well. When the battery dies, I'll get one with more amp hours.
mtwesty84 wrote: |
Wondering where you found the parts to convert the GW city water to Andersen hook-up? I am looking at doing the same thing with SAE 2 connectors. |
I mis-typed earlier: They're 45-amp Anderson Power Pole connectors (not 40). I bought the connectors (10-pack because I knew I'd screw up installing them without the special tool... and I certainly did) and mounting plate (aka clamp) at Amazon:
http://www.amazon.com/s/ref=nb_sb_noss_2?url=searc...ole+45+amp . The plate was mounted to a small piece of Plexiglass I had in stock, which was screwed to the GW hookup after removing the water connection.
I don't like SAE connectors (have had too many go bust), but I know a few Westy owners out there use this in the city hookup: http://www.amazon.com/Luggage-Electrix-PTB-001-Sad...+connector . _________________ ~Kamz
2016 Golf GTI S
Hnoroian Samba Member
Joined: October 27, 2013 Posts: 535 Location: Bakersfield
Posted: Thu Sep 17, 2015 10:06 pm Post subject: |
I'm glad this thread came up. But a question for all of you, I've been having a difficult time finding the pros and cons of having a acr vs a standard solenoid to distribute the power, I am looking for a simple reliable setup to do two batteries. I have noticed in the diagrams that people have used either one or the other and some have used both. Can someone please send me the right way, I am thoroughly enjoying the diagrams _________________ Stupid people do stupid things. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Fri Sep 18, 2015 7:40 am Post subject: |
Hnoroian wrote: |
acr vs a standard solenoid |
One of the pros of an ACR is that it allows batteries to charge when the vehicle is not running, like if you're using a solar panel or another charging source other than the alternator.
This is important to me since my van sits all winter. I can plug trickle charger into the outlet of my garage, hook it up to my auxiliary battery, and keep both that and the starting battery charged up for when the van comes out of hibernation. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Fri Sep 18, 2015 8:21 pm Post subject: |
That definitely helps, now I've got to decide how I want to spend my money and would it be worth it for my situation... Thanks guys, I'll be keeping tabs on this thread _________________ Stupid people do stupid things. |
Jamo7 Samba Member
Joined: September 25, 2014 Posts: 124 Location: Seattle
Posted: Mon Oct 03, 2016 9:41 pm Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
Hi there,
I could use some feedback on my proposed aux battery set up as shown below. (I apologize for bad handwriting and cell phone pic. I hope you can read it!)
Primary questions:
1) The Blue Seas Circuit Wizard app recommends 4AWG for my ACR/battery connections based on my input of 65 amps load and bundling the three 4AWG wires together from the aux battery to be located under the drivers seat to the sink cabinet location of the ACR. Does 4AWG sound sufficient? Is this overkill?
2) The ampacity of the 4AWG wire given the length and bundling I specified was 73.5A. I thought to put in a 70A fuse to protect the wire (Blue Seas AMR or MIDI) Is this the right reasoning? Is 70A a sufficient fuse?
3) In the installation photos I’ve seen, the fuses are placed near the ACR. I have read elsewhere that fuses are to be placed near the batteries. Given the size of the group 41 batteries in the battery boxes, it will be easier to place and check the fuses in the sink cabinet nearer the ACR. Will this be ok given the wire gauge and fuses shown?
4) The Blue Seas 2.1A USB and 12V socket panel that I am interested in purchasing for the back seat carries a 15A circuit breaker. I use the 12V cig liter and a 2.1A dual USB outlet next to it in the front. Should my USB circuit as shown in the drawing carry a fuse of 30A, or is 15A sufficient?
5) I saw the other day the recommendation for 12AWG wire for a Propex. Online the draw is specified at 1.4A. Is a 5A fuse sufficient? What are other people using?
That’s all the questions I can think of. If I have miscalculated my load, then I will recalculate my ACR wiring gauges.
Thanks for all your feedback!
James _________________ '84 Westy 2.1 wbx |
lucianosanchez Samba Member
Joined: May 04, 2016 Posts: 212 Location: Ventura County
Posted: Tue Oct 04, 2016 11:54 am Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
I've bookmarked this topic because I plan on doing this on my van soon. I didn't even know where to start but now I do. Those diagrams are very helpful. Thank you all! _________________ 1983.5 Aussan Brown Westfalia | 2016 to 2020
1983.5 Beige Westfalia | 2019 to Current |
Stephenmarklay Samba Member
Posted: Tue Oct 04, 2016 12:32 pm Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
Jamo7 wrote: |
Hi there,
[diagram]
Primary questions:
2) The ampacity of the 4AWG wire given the length and bundling I specified was 73.5A. I thought to put in a 70A fuse to protect the wire (Blue Seas AMR or MIDI) Is this the right reasoning? Is 70A a sufficient fuse? With the information provided yes.
4) The Blue Seas 2.1A USB and 12V socket panel that I am interested in purchasing for the back seat carries a 15A circuit breaker. I use the 12V cig liter and a 2.1A dual USB outlet next to it in the front. Should my USB circuit as shown in the drawing carry a fuse of 30A, or is 15A sufficient? I would use a 15A. I don’t know the length of 10AWG wiring but if you have say 10 feet 30 amps would be pushing it.
5) I saw the other day the recommendation for 12AWG wire for a Propex. Online the draw is specified at 1.4A. Is a 5A fuse sufficient? I would use a 3 What are other people using?
James |
See my comments above. _________________ 1985 Westfalia. Project 2017. |
kjono09 Samba Member
Joined: April 03, 2014 Posts: 191 Location: Seattle, WA
Posted: Tue Oct 04, 2016 1:58 pm Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
So the key to my circuit is this awesome on - delay relay that let's me charge both batteries from the alternator 8 seconds after start. This coupled with an 80 amp battery relay makes this circuit truly awesome. You do not want both batteries always starting the car and handling all of the startup transients.
Amazing product!
http://www.3rdbrakeflasher.com/my-link-ezp-15.html _________________ 84 Retro-Westy GW 2.2L (Vincent)
67 Bug 2007cc (WBX in progress) (Davey)
Submariner |
jokeraus Samba Member
Posted: Wed Oct 05, 2016 8:13 am Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
above the trans install. wiring diagram is mia
_________________ 88 Vanagon | Build Thread |
Posted: Thu Oct 06, 2016 9:10 am Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
So know I have learned the right way of doing this and have all the tools to make custom battery cables the right way.
http://www.thesamba.com/vw/classifieds/detail.php?id=1978362 _________________ 84 Retro-Westy GW 2.2L (Vincent)
Submariner |
kbeefy Samba Member
Joined: March 10, 2006 Posts: 600 Location: Central Oregon
Posted: Sun Oct 09, 2016 5:48 pm Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
Excellent Cocktail napkin diagram!
I think 4ga is overkill for most of it. 8ga will do fine. Maybe 4ga from your starting battery to your aux battery just to be safe. But I don't think a group 41 would ever support that sort of charge amperage, nor would your alternator. 70A fuses are overkill. You will never see 70A of charge current unless you add alot more batteries and a serious battery charger. I would say that 30A is plenty, both charge and load side. _________________ 86 syncro CHC, NorthWesty subbie 2.5, decoupler, locker, custom interior, 225/75r16 Duratrack's on CLK's, Toyo cabin heater, ARB fridge, 300w Zamp Solar, Gowesty bumpers/skid/rails, Fiama awning
'86 Syncro Westy. Stock for now.
2000 F350 7.3 CC LB 11' Northland Cabover
2006 Subbie OBXT
2002 Tacoma DoubleCab 4x4
1969 Mustang Basket Case 351c/FMX/9
http://kbeefy.blogspot.com/ |
LemonCove Samba Member
Joined: July 29, 2010 Posts: 324 Location: Henderson, NV
Posted: Mon Oct 10, 2016 10:20 pm Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
Top" Layout with batteries on pass side, Propex relocated under access lid (original VW rear heater removed).
Middle: Shows 2 Costco/Interstate Group 27 Marine lead acids, onboard ProMarine charger, compartment for Bostig ECU and BlueSea ACR,
vents in fascia (storage for jack and folding shovel under lid/behind propex).
Bottom: Finished appearance _________________ '88 Bostig Westy |
brownbetty Samba Member
Posted: Sun Mar 04, 2018 10:56 am Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
In reference to the three battery setup of smurfpike, is it necessary or recommended to include another blue seas acr between #2 and #3 batteries? _________________ 1984 Vanagon Gl Wolfsburg camper
Look out! He's got a towel!! |
jimf909 Samba Member
Posted: Sun Mar 04, 2018 11:12 am Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
jokeraus wrote: |
This is Vanagon nirvana for me: adds functional storage to vacant space; puts the batteries in a safe, central location while keeping them more accessible than putting them between the frame rails under the van.
Well done!
Someday I’ll make the cut. _________________ - Jim
Abscate wrote: |
smurfpike Samba Member
Posted: Thu Apr 19, 2018 2:34 pm Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
brownbetty wrote: |
In reference to the three battery setup of smurfpike, is it necessary or recommended to include another blue seas acr between #2 and #3 batteries? |
I ran battery 2 and 3 in Parallel so I did not think I needed a blue seas acr. _________________ 1965 Ottinger Tribute Overland Bus
IG @otter.the.overland.bus
FB Ottertheoverlandbus
IG Westyrestorations
FB WestyRestorations, parts and accessories
1987 Syncro "Big Red", Full restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=606596
1978 Westy Camper, Full ground up restoration, restoration thread http://www.thesamba.com/vw/forum/viewtopic.php?t=593413 |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Thu Apr 19, 2018 6:37 pm Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
smurfpike wrote: |
brownbetty wrote: |
I ran battery 2 and 3 in Parallel so I did not think I needed a blue seas acr. |
The problem with that is although this is fine when the (hopefully identical) batteries are new and in good condition - when one of them starts to fail (a shorted cell is the usual scenario) then both the good and the now bad battery will be over-charged, and the complete failure of both will be imminent. An extra ACR now is cheaper than two new batteries in the not-so-distant future. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Thu Apr 19, 2018 7:20 pm Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
fxr wrote: |
smurfpike wrote: |
brownbetty wrote: |
The problem with that is although this is fine when the (hopefully identical) batteries are new and in good condition - when one of them starts to fail (a shorted cell is the usual scenario) then both the good and the now bad battery will be over-charged, and the complete failure of both will be imminent. An extra ACR now is cheaper than two new batteries in the not-so-distant future. |
That is good to know, thanks I will do this next time. _________________ 1965 Ottinger Tribute Overland Bus
andersjohanssen Samba Member
Posted: Sun May 27, 2018 10:03 am Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
I am about to set this up in my van. The relay is so that my batteries will isolate when the car is off so that my ProSport battery charger can charge the batteries individually.
Will post pics after. Tell me what you think.
eyemtrees Samba Member
Posted: Sat Jun 23, 2018 1:21 pm Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
Hi all, I've just got a third hand vanagon with a GoWesty Solar Panel and Zamp Solar Charge controller behind the driver's seat. Looking at the diagram before trying my panel for the first time, I see there should be a fuse between the panel and the controller, just as there is between the controller and battery. I can't see one on the panel's long cord/wire. Is it built into the panel in those little boxes on the back of the panel itself? |
coqcitywesty Samba Member
Joined: February 20, 2018 Posts: 401 Location: Coquitlam, BC
Posted: Tue Jul 03, 2018 1:58 pm Post subject: Re: Aux Battery & Accessory Setups: Pictures & Diagrams |
Okay, so my install is pretty much complete - the list of items used to create the install is as follows - all from Blue Sea Systems unless noted:
ACR - 7610
Switch Panel - 4315 (USB 1045 - Voltmeter 1733)
50A Breaker - 7139
50A Circuit Breakers - 7157
Battery Switch - 9001E
On-board Charger - ProMariner 12
Fridge - TF49 with RMW install kit
LED House & Reading Lights - Acegoo (Amazon)
So far everything works as planned with the actual wiring gymnastics undertaken by a colleague using the diagram I provided. Giving credit where due, I did use a lot of the previous work by Hodakaguy and others on this forum (thanks folks).
Wiring Diagram:
Switch Panel (controls power to each load + monitors battery health):
Group 27 Kirkland DC (120 AH) + wiring install (and yes, ACR is grounded)
LED House Lights + LED Galley Light (house lights are controlled by a rocker switch installed above sliding door)
LED House Lights On (daytime)
TF-49 Install using RMW install kit
ProMariner Installation
Reading Lights (we typically sleep in the bottom bunk, so this works for us - they double as a night light with the blue led rings)
All in all, things are working well and I am pleased with the results. Questions or comments are welcomed.
