Front torsion bars dust cover?
khalimadeath
khalimadeath is offline
PostPosted: Tue Jul 21, 2015 8:08 pm    Post subject: Front torsion bars dust cover? Reply with quote
Where can I buy the dust covers that go on the outside of the arms that cover circular area where the bars slide into. The new arms I got didnt come with them..
ToolBox
ToolBox is offline
PostPosted: Wed Jul 22, 2015 9:12 am    Post subject: Reply with quote
Off your old arms.
Tcash
Tcash is offline
PostPosted: Wed Jul 22, 2015 9:25 am    Post subject: Reply with quote
Is it #2?
thanks to jerseylooker
http://www.jerseylooker.com/FicheDump/EarlyBaywindow/EarlyBay-Main.html
http://www.busdepot.com/211405129a
Good Luck
Tcash
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jul 22, 2015 1:52 pm    Post subject: Reply with quote
that part #33 N116041 was probably NLA 30 years ago. Off an old one is the only way. Maybe get a hold of folks who rebuild them and they can pull them off no good cores.
"There are no great men, there are only great challenges that ordinary men are forced by circumstances to meet." - Adm William F. Halsey Jr
Caveat: I am not telling you what to, or what not to do. When a suggestion is offered, it is wishing you the best, and is based on my experiences as a mechanic, automotive machinist, and from racing in the era your bus came to life. My only goal is to share what has been learned on my path. Smile
1971 (sold)
1977
Wildthings
Wildthings is offline
PostPosted: Wed Jul 22, 2015 2:01 pm    Post subject: Reply with quote
Maybe something in the way of a freeze plug from you FLAPS.
Yarkle Premium Member
Yarkle is offline
PostPosted: Wed Jul 22, 2015 6:36 pm    Post subject: Reply with quote
Do these actually have a function? its not like dust can get into the arm from the outside AFAICT. Looks pretty solid to me.
1973 VW Bus [o____o] "the Thing" thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=8272498#8272498 1.7 914? engine with weber progressive clone (soon to be 72 dual carb setup)
1969 VW Bus deluxe 221 -belongs to the boy
"Weld Busler" Bus rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=630499 1600SP
1967250s
1967250s is offline
PostPosted: Wed Jul 22, 2015 8:39 pm    Post subject: Reply with quote
They are not actually dust covers; they are bushing clamps and usually come with urethane bushing sway kits.
http://www.bus-boys.com/bbswaybr.htm
http://www.socalautoparts.com/product_info.php/aftermarket-sway-bar-clamp-kit-bus-stock-p-16863
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D211%2D498%2D101%2DA2
'72 Elm Green Deluxe
SGKent is offline
PostPosted: Wed Jul 22, 2015 8:44 pm    Post subject: Reply with quote
Are we all talking about the same part? The part some of us believe he is describing is the small round cover that pops into the arm in this position. It is a dust cap and it is NLA. They should have been installed in the replacement arms. If it is that part send them back on their dime and ask for a set that is complete.
1971 (sold)
1977
khalimadeath
PostPosted: Tue Jul 28, 2015 7:47 pm    Post subject: Reply with quote
Yes sorry I was late on this post.. But that IS the piece I am talking about. I got new arms and only one of them had that piece. I assume the others were lost in whatever cleaning system they have to clean them and they didnt bother to replace it.
Wildthings
PostPosted: Tue Jul 28, 2015 7:53 pm    Post subject: Reply with quote
Call your supplier and see if they have any spared laying around. As I already posted you might be able to get a freeze plug that will work from your FLAPS.
Bannedwagen
Bannedwagen is offline
PostPosted: Thu Oct 29, 2015 2:22 pm    Post subject: Trailing arm dust cover removal Reply with quote
How are these dust caps removed?
I have the end of a torsion ?bar? broken off inside my trailing arm and need to get it out. I see that removing the cap will give me access to the broken piece but I'm not sure how to remove the cap. Can't find how to in my Bentley either. The arm is out of the beam so I can get a long bar or pipe and hammer it out unless it'll be damaged. Thanks
68 squareback
68 deluxe bus
67 type 1
66 type 1
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Thu Oct 29, 2015 8:10 pm    Post subject: Re: Trailing arm dust cover removal Reply with quote
That's what I'd do. Tap it gently from the inside to see if it will pop off from the outside.
Bill
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
LivinInnaVWBus
LivinInnaVWBus is offline
PostPosted: Sun Nov 01, 2015 2:14 pm    Post subject: Reply with quote
http://www.vintagev-dubs.com/shop/leaf-spring-control-arm-caps-56-79-bus/
I just got a set along with their HD grub screws and genuine VWOB torsion leafs.
khalimadeath
PostPosted: Tue Nov 03, 2015 10:34 am    Post subject: Reply with quote
Awesome! Gonna order some asap, ill have to get new screws too.
khalimadeath
PostPosted: Thu Dec 08, 2016 9:12 pm    Post subject: Re: Front torsion bars dust cover? Reply with quote
SO.. I am going to bump my old thread as I ended up not ordering these. I attempted to place my old caps back on but after smashing my finger with a hammer doing this I gave up. I went off roading this last weekend and went through a lot of snow and mud. There is now a lot of dirt and mud in and around these ares with no covers.. so the inside of the arms are exposed and dirty. How bad is this? Best way to clean it?[/code]
The United States Constitution
(c) 1787. All Rights Reserved
1970 Bus Westfalia
1964 Kombi
BayAllTheWay
BayAllTheWay is offline
PostPosted: Thu Dec 08, 2016 10:20 pm    Post subject: Re: Front torsion bars dust cover? Reply with quote
a) I bet you bought them at Vintage Vdubs, as mine came from them with these removed. Thanks! Regardless, I asked them after 17 phone calls to try to get a hold of someone what was the deal, and finally he agreed to send me the little bolt-on covers pictured above.
b) They are half baked, complete sh*t and don't keep anything except, perhaps, marble sized rockes from getting in there.
Unfortunately I wasn't concerned about rock marbles getting in there, but grime and grit and other such sh*t.
</rant> dont' order from Vdubs if you did, and don't order those things if you're thinking about it. Find some original ones; maybe Nate at Wagenswest can hook you up.
Good luck,
khalimadeath
PostPosted: Thu Dec 08, 2016 10:33 pm    Post subject: Re: Front torsion bars dust cover? Reply with quote
Good luck,
Thanks for the tip I will not order them then.. I have the OG ones but I cant get them to fit in the new arms..
1970 Bus Westfalia
1964 Kombi
Wildthings
PostPosted: Thu Dec 08, 2016 11:23 pm    Post subject: Re: Front torsion bars dust cover? Reply with quote
Some RTV silicone should work well enough.
I don't think much of the plastic caps that have a tab sitting under the lock nut. Having the lock nut come loose because the plastic fails, followed by the grub screw backing out, could ruin anyone's day.
busdaddy
busdaddy is offline
PostPosted: Thu Dec 08, 2016 11:25 pm    Post subject: Re: Front torsion bars dust cover? Reply with quote
I agree, a smear of RTV or JB weld would seal it up better with no risk of the bolt coming loose.
SGKent is offline
PostPosted: Fri Dec 09, 2016 7:57 am    Post subject: Re: Front torsion bars dust cover? Reply with quote
and what Mike said
X3
1971 (sold)
1977
