JFW Samba Member
Joined: August 06, 2018 Posts: 33 Location: Hølen, Norway
Posted: Thu Aug 29, 2019 2:05 am Post subject: Re: Replacing/redoing interior panels/door cards? |
Hi guys!
Quick follow up on this thread: Are there any DWG/DXF files for the door cards and interior panels available out there? I've been dooing my best google-fu to no avail. Considering just making some myself (files + cards/panels).
Truls |
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1145 Location: Northern Nevada
Posted: Mon Sep 02, 2019 2:59 pm Post subject: Re: Replacing/redoing interior panels/door cards? |
SyncroHead wrote: |
On Saturday morning I followed the wetting and flattening process described above on the driver's door panel which was pretty warped. Added just a little bleach in the water to help prevent unintended "organic growth" while wet.
I bagged it and laid it on the concrete garage floor as described but left in all but one of the plastic attachment clips. Used assorted sized and shaped wood to cover the entire panel everywhere but avoiding the clips. Another layer of plywood on top of that to distribute the weight, then a grid of 2x3 above that, before 3-layers of concrete blocks. Probably about 500lbs on this door panel right now. |
I'm happy to report that after 6.5 days, I unstacked the "block press" and found my panel very flat. Just a little on the moist side, since it spent all that time flattening inside a plastic bag. I laid it out flat again, with no bags this time, and re-stacked the block press again. Left it another day to dry.
I unstacked the blocks again and found it sufficiently dry. I coated the surface with accouple applications of Watco penetrating teak oil finish to repel future water and left it another day standing in the open air. Finally, got to pop it back into place yesterday, then (oops!) removed it again to install the door pocket. Fortunately, I'd only popped the panel on and hadn't started with the stuff that needs screws. Now it's installed and looking very good! Happy to report this method worked well!
I'll report back if it starts to re-warp in time...
Thanks so much to JordanVW for writing the original procedure on the Vanagon email list and to joetiger for finding it and copying it here.
Regards,
Jim Davis _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Sep 03, 2019 11:57 am Post subject: Re: Replacing/redoing interior panels/door cards? |
Great to hear! The Vanagon List Archive is still a great source for info. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Joe Cole Samba Member
Posted: Sun Mar 22, 2020 12:32 pm Post subject: Re: Replacing/redoing interior panels/door cards? |
Did anyone ever come up with dwg/dxf or Ai files for any of the panel/door cards?
I only know 5 people with a cnc machine and I own a shaper origin. I guess I can flatten my least warped door panel and copy it but a clean AI file would be amazing. |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Mon Mar 23, 2020 7:29 am Post subject: Re: Replacing/redoing interior panels/door cards? |
Joe Cole wrote: |
I made one for a late sliding door. Just have to find it in my archives. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
JFW Samba Member
Posted: Fri Jul 10, 2020 2:06 am Post subject: Re: Replacing/redoing interior panels/door cards? |
In regards to CAD files for the panels. The topic is covered here now: https://www.thesamba.com/vw/forum/viewtopic.php?t=738392
Truls _________________ --------------------------------------------------------
1986 Caravelle C Reimo camper (AAZ TD)
1989 Caravelle C Syncro (JX TD, 2xdifflocks, PS)
Museum director.
Bicycle framebuilder.
Thinkerer. |
jcannon Samba Member
Posted: Mon Apr 26, 2021 4:41 pm Post subject: Re: Replacing/redoing interior panels/door cards? |
For those who want to make new hardboard (masonite) for their existing door panels there is a way to make your own pattern if the existing one is too ratty to be usable.
Tape some kraft paper (it comes in rolls) to the door panel indent and cut it so it fills the indent to the edges plus a bit. Use a compass or divider set to 1mm or so and trace the inside of the opening. You now have the outside line of your pattern. Rub your thumb on the clip holes and it will imprint the paper with the exact locations. Do the same for the door handle screws. Cut out your new panels. There should be enough left of the old panels to trace out the openings for the speakers, door latch, window winder or electric switch, and mirror control. As they say, "All too easy".
Next, I have two ways to get the vinyl off the old card. The first is to use a sharp wood chisel, bevel down, and slice (pare) the masonite off beneath the heat seams. You cut just deep enough into the masonite so the vinyl does not get cut. This will leave a small amount of masonite stuck to the vinyl. Sharp means sharp. Your chisel should be able to cut a sheet of paper. Paring the masonite is a one hand affair and it goes quick, if your chisel is sharp. The chrome strip is plastic so no problem there. The seam under the carpeted portion is much wider than the heat seams but will pare of easily. To remove the masonite from the vinyl, toss it in a tub of water. This works really good for a panel you want to trace that is too bad to use but you still want.
If the panel is so ratty it is unusable, like one of mine, soak it in the tub until the masonite falls apart. That is my preferred way. Little labor involved. Make sure you do this after you've traced the openings.
Panel clip holes are 10mm. The chisel was probably 1". If not 3/4. If you can't sharpen a chisel it is a useful skill to develop. Google Paul Sellers. If you are thinking you can buy a new one and they come sharp, good luck. Even the expensive chisels require user sharpening.
If you are doing many Vanagons the dxf and a cnc is preferable. I'm an engineer and it would take me some time to be sure a dxf file was perfect. The pattern takes me 20 minutes and the cards come out perfect. For me it is the fastest way to make one set.
For things like the speakers which work best with nice exact holes, cut them a wee bit small and ftf. (ftf = file to fit)
I'm more of a convertible person and have had several of the early '50s Karmans. To buy panels is very expensive. They are almost unfindable for tracing, so the paper was my process. For those you need to offset the clip holes.
This works for flat glass too, if you need a pattern. Paper in the opening, run a compass/divider around the edge and poof! Measure the gasket to get the offset. |
1971BugGuy Samba Member
Joined: October 16, 2004 Posts: 426 Location: Ontario, CANADA
Posted: Mon May 03, 2021 2:13 pm Post subject: Re: Replacing/redoing interior panels/door cards? |
Made my own door cards out of Masonite and sewed my own covers. Installed new Kicker speakers in the stock speaker grills, added new door pulls and window cranks. FYI, Ford Taurus window cranks offer more than twice the clearance over the speaker as the VW ones. Unfortunately I was unable to locate new door release escutcheons so I had to reuse my fatigued old ones.
[/img] _________________ Only a fool or a child would judge a project before it reaches its completion.
1971 Super Beetle
1986 Vanagon Westfalia Weekender |
DuncanS Samba Member
Posted: Mon May 03, 2021 2:42 pm Post subject: Re: Replacing/redoing interior panels/door cards? |
Very nice. |
jlrftype7 Samba Member
Posted: Mon May 03, 2021 5:08 pm Post subject: Re: Replacing/redoing interior panels/door cards? |
1971BugGuy wrote: |
[/img] |
I can show you much worse door handle escutcheons, so you’ll feel better about your very decent ones....
It’s a Brown Plastic Trim thing.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Mon May 03, 2021 8:46 pm Post subject: Re: Replacing/redoing interior panels/door cards? |
Wow, that interior looks amazing. That was a serious labor of love and you are a well balanced detail freak. I even like that you turned on your map light for the one picture. That is one loved Vanagon and she's in the right hands. A tip of the hat across the miles... _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Mon May 03, 2021 10:08 pm Post subject: Re: Replacing/redoing interior panels/door cards? |
Wow, beautiful interior details! Nicely done. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Posted: Sun May 16, 2021 8:12 am Post subject: Re: Replacing/redoing interior panels/door cards? |
IdahoDoug wrote: |
Wow, that interior looks amazing. That was a serious labor of love and you are a well balanced detail freak. I even like that you turned on your map light for the one picture. |
Thanks for the accolades. (My map light comes on when the door is open. It's not something I did intentionally)
1971 Super Beetle
