Engine removal on a 1968 bus
DonkeyDong68
DonkeyDong68 is offline
PostPosted: Wed Jul 22, 2015 10:44 am    Post subject: Engine removal on a 1968 bus Reply with quote
is there any good threads or websites that will help you with a step by step
removal of a engine ...thanks in advance
Tcash
Tcash is offline
PostPosted: Wed Jul 22, 2015 12:08 pm    Post subject: Reply with quote
Disconnect the battery and pinch the fuel hose off right below the gas tank.
You need a Repair manual.
Bus service manual+Bus repair manuals
Good luck
Tcash
[email protected]
Samba Peckerhead
PostPosted: Wed Jul 22, 2015 12:10 pm    Post subject: Reply with quote
remove:
wires
accel and heater cables
heater box to bus bellows
remove rear apron
remove bumper (if you want extra space)
remove and plug fuel line
remove 4 engine to trans nuts
support transmission
jack up engine
remove mustache bar/ bar mounts
jack engine s'more
pull engine rearward
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
