Motor Identification
VWNewbie666
VWNewbie666 is offline
PostPosted: Sun Jul 26, 2015 4:34 pm    Post subject: Motor Identification Reply with quote
I am just familiarizing myself with my 1973 VW Bus. I am trying to identify what motor is in my van, and I was wondering if anyone could point me in the right direction as to how I could identify what I have?
Brian
Brian is offline
PostPosted: Sun Jul 26, 2015 4:35 pm    Post subject: Reply with quote
On the top of the motor, there should be a number. Then look here: http://www.thesamba.com/vw/archives/info/engine_letters.php
Now lets see some pictures of it Very Happy
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
VWNewbie666
PostPosted: Sun Jul 26, 2015 5:15 pm    Post subject: Reply with quote
This is my only pic of it so far.... but it makes me smile hahah
lil-jinx
lil-jinx is offline
PostPosted: Sun Jul 26, 2015 6:07 pm    Post subject: Reply with quote
I see why you're smiling.nice bus
1968 Dune Buggy
1974 parts bus
richparker
richparker is offline
PostPosted: Sun Jul 26, 2015 6:09 pm    Post subject: Reply with quote
Automatic?
__________
71 Westy build
Adventure thread
65 Deluxe Build
VWNewbie666
PostPosted: Sun Jul 26, 2015 6:19 pm    Post subject: Reply with quote
Automatic?
Yes, it's an automatic. I have heard it is rare to have a 1973 Automatic imported to Canada, but I am unsure. There are some issues, I need a throttle cable guide tube, the correct adjustment linkage for the transmission, and lately it has been stalling. Other than that it is in pretty great shape!
Tcash
Tcash is offline
PostPosted: Sun Jul 26, 2015 7:03 pm    Post subject: Reply with quote
I'm smiling too. Welcome to TheSamba!
Engine number location
Tcash wrote:
Here is a little information. Good Luck
Pictures would be cool.
How to post photos/How to post a photo in the Forums
Pronunciation (Samba) English
I am thinking of buying a VW van
Cleaning+Rodents+Hantavirus
Up in smoke... Bus fires... don't let it happen to you!
M-Plate Location
M-Plate Decoder Volkswagen Type 2 Bus
Bus VIN / Chassis Numbers
Type 2/Bus Owner's Manuals
Bus repair manuals
Bus parts manuals
Early Baywindow Bus Parts Book
Late Baywindow Bus Parts Fiche
Type 2 Wiring Diagrams
Model and Year Variations
Type 4: Secrets Revealed
Distributor Parts & Specifications
PARTS INTERCHANGE MANUAL
Youtube Videos
There is a ton of information located at the top of the Forum section.
Wildthings
Wildthings is offline
PostPosted: Sun Jul 26, 2015 9:41 pm    Post subject: Reply with quote
Any stock Type 4 engine case can be built up to any stock engine size, so the engine number on the case tells you very little excepting how the engine was built at the factory. The size doesn't matter for most things less than a complete engine overhaul anyway. For tune up info, you need to tune for your present fuel system and distributor and not for the factory parts that likely wore out and were tossed a couple of decades back.
VWNewbie666
PostPosted: Mon Jul 27, 2015 4:32 pm    Post subject: Reply with quote
Hmmmmm, I don't see a number there.... here are some pictures. What do you think?
Tcash
Tcash is offline
PostPosted: Mon Jul 27, 2015 5:08 pm    Post subject: Reply with quote
Look for that CD number on the top of the engine where the parting line is.
CD = a 1973 1700cc - dual carb., automatic transmission
The fan housing could have been put on another engine though. You need to find the number on the engine case.
The 233 number is the Vin#. The same number should be on the dash on the drivers side, visible from the outside.
Tcash
busdaddy
busdaddy is offline
PostPosted: Mon Jul 27, 2015 5:17 pm    Post subject: Reply with quote
Yep, can't trust the number on the shroud, it's either down deep in the goo between the shroud and breather tower (here's one with the shroud removed for clarity):
Or on top of the case near the front (bellhousing) just inboard of #3 cylinder:
VWNewbie666
PostPosted: Mon Jul 27, 2015 6:54 pm    Post subject: Reply with quote
Well as you can tell I am very very new to the VW scene. I have been trying to find the number stamped into the block but so far I haven't located it. I did however find a wire that wasn't connected to anything... thoughts?
busdaddy
busdaddy is offline
PostPosted: Mon Jul 27, 2015 7:04 pm    Post subject: Reply with quote
Oil pressure idiot light, don't leave home without it.
Look around nearby for a blue wire with a green tracer or stripes.
VWNewbie666
PostPosted: Wed Jul 29, 2015 5:55 pm    Post subject: Reply with quote
Okay I have not been able to locate the number stamped on the block. I have however determined that it is a type 4 motor. I am trying to now narrow down the year. Is there any key identifiers? I was told that it was a 2.0 litre, any way to confirm that?
Wildthings
PostPosted: Wed Jul 29, 2015 6:06 pm    Post subject: Reply with quote
You can tear it down and see, until then the build info is just not important. Even if you have the original engine for your year, the cam is likely different by now and maybe the style (flat, domed, or dished) of the pistons plus other things was well.
As I said earlier:
"For tune up info, you need to tune for your present fuel system and distributor and not for the factory parts that likely wore out and were tossed a couple of decades back."
Quit worrying if you have a 1700, 1800, 2000, or other and just drive it, the numbers on the block (or lack of them) likely mean little.
VWNewbie666
PostPosted: Wed Jul 29, 2015 6:11 pm    Post subject: Reply with quote
The concern I have Wildthings is not to do with the size of the motor, instead I am simply trying to identify it so I can get replacement parts as needed. I have a leaky fuel pump, and I want to replace it. The fuel pump I bought was supposed to fit this year bus, but it definately is not the right one. At this point my concern is not regarding the size, it is simply knowing what I have so I can read more about the motor and of course know what type of parts I need to buy as future issues potentially occur.... for example distributor cover.
Wildthings
PostPosted: Wed Jul 29, 2015 6:38 pm    Post subject: Reply with quote
If the block is set up for a mechanical pump, then the size of the engine doesn't matter, having a mechanical pump would likely limit your engine to being either a 1700 or 1800, but non US 2000 blocks were often set up for mechanical fuel pumps as well. The same with most any other part on the exterior of the block. Most 1700 parts will fit a 2000 engine just fine and most 2000 parts will fit a 1700 just fine. There are three different federal exhaust systems used over the years plus California systems, but so long as the system you have fits your engine, just buy parts that match.
Most engines (just are yours is) are hodge podges of parts from varies years and models at this point in time. Knowing the piston diameter and crank stroke isn't going to tell you much until overhaul time, at which point you don't want to be buying parts until you have torn the engine down to see exactly what is in there.
busdaddy
busdaddy is offline
PostPosted: Wed Jul 29, 2015 6:57 pm    Post subject: Reply with quote
As WT's says "size doesn't matter", there's only one "type 4" fuel pump and the same distributor that fits a 36 HP 1200 from a 56 bus could have been fitted to yours, the numbers on the carb and the distributor are what you need for service parts and that's how you determine tune up specs and adjustements as well. The only other thing to do is pull off a rocker cover and see if it looks like it has hydraulic valves, that's one more thing that doesn't indicate displacement but requires different adjustments.
VWNewbie666
PostPosted: Wed Jul 29, 2015 6:58 pm    Post subject: Reply with quote
Here are some pictures of the fuel pump I need to replace, but I can't find any pictures online of this particular pump. Have you seen a pump like this before?
busdaddy
busdaddy is offline
PostPosted: Wed Jul 29, 2015 7:01 pm    Post subject: Reply with quote
Here's the modern version, many vendors carry it: http://airheadparts.com/vintage-vw-parts/carburete...21127025-a
