FrankenVanagon?
Calicub
Calicub is offline
PostPosted: Wed Jul 29, 2015 8:54 pm    Post subject: Thanks for the tips all! Reply with quote
She's a federal! Engine bay sticker shows egr & door jam sticker calls out federal as well.
82 Westy
Calicub
Calicub is offline
PostPosted: Tue Jul 28, 2015 10:03 pm    Post subject: Reply with quote
Thanks all for the input, I'll get some photos up as soon as I can. Hopefully tomorrow.
82 Westy
shadetreetim
shadetreetim is offline
PostPosted: Tue Jul 28, 2015 7:13 pm    Post subject: Re: FrankenVanagon? Reply with quote
Calicub wrote:
The double relay has 11 pins, but the airflow sensor appears to be a CA part, the coil looks to be a CA part, but the fuel filter is a cube & not the bosch "can."
After 33 years of who knows who touched it service, there is no telling what mash up of parts you will continue to find. I wouldn't look at the parts to decipher which model you have. As has been posted, add some pictures and the collective can help you figure it out.
Good luck with your new Vanagon.
Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'10 Wrangler 3.8 6SP Manual
'12 Ford E350
'12 Tiguan 2.0T 6SP Tiptronic - Lady Shadetree's
the joker
the joker is offline
PostPosted: Tue Jul 28, 2015 6:52 pm    Post subject: Reply with quote
cali model had that NLA crossover exhaust and funky EGR stuff o2 sensor
you need all the tins and fix your thermo bellow flap system
chk the engine compartment seal
rubbachicken
rubbachicken is offline
PostPosted: Tue Jul 28, 2015 5:11 pm    Post subject: Reply with quote
welcome Smile
enjoy
pictures of the van would be helpful, especially engine and ancillaries
lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182
BerneseMtnDog
BerneseMtnDog is offline
PostPosted: Tue Jul 28, 2015 4:47 pm    Post subject: Reply with quote
The California model will also have an idle stabilizer and ignition amplifier on the left side of the engine bay. I think a Cali model will also have an O2 sensor.
Steve
geodude
geodude is offline
PostPosted: Tue Jul 28, 2015 4:40 pm    Post subject: Reply with quote
There should be a placard (oil filler door on mine) that says what emissions it originally had. Also look on the door jam as it might be there.
1988 GL Camper
1991 Multivan the basket case
Calicub
Calicub is offline
PostPosted: Tue Jul 28, 2015 4:33 pm    Post subject: FrankenVanagon? Reply with quote
Hi All, I'm the proud new owner of an 82 air cooled westy. I'm running into some issues as it's missing many of the lower tins (under the pushrod tubes & by the heater boxes), thermostat & flap assemblies. In trying to figure out if it's a California or federal model, I'm running into conflicting info, I.E. The double relay has 11 pins, but the airflow sensor appears to be a CA part, the coil looks to be a CA part, but the fuel filter is a cube & not the bosch "can."
Any help or suggestions on how to definitively ID & source the correct tins will be immensely appreciated!
82 Westy
