joe comfort Samba Member
Joined: March 18, 2005 Posts: 408 Location: Lake Havasu, AZ.
Posted: Sat Aug 01, 2015 5:06 pm Post subject: A/C wont blow cold 2003 Beetle 1.8 Turbo "S" |
I have a 2003 "S" turbo 1.8 Beetle 6 speed. The fans at the radiator are not turning on when I turn the A/C on. I took it to a shop and was told VW does not release a lot of tech info like the other manufacturers and the problem could not be singled out.
When I turn the A/C on, the fans wont turn on and thus warm air comes out the vents. When the water temp reaches the desired max temp, the fans turn on and the A/C blows cold. R134 is full so that is ok. Maybe a module problem or switch problem??
Has anybody experienced this and if so what is the fix? I really don't want to take it to a dealership $$
Thanks for any help! |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sat Aug 01, 2015 6:20 pm Post subject: |
Could be the Fan Control Module, as that has multiple control functions. But being an electrical part, once you buy it(not cheap) and use it once, it's yours whether it fixes it or not. |
Posted: Sat Aug 01, 2015 6:53 pm Post subject: |
This one is gonna hurt! Living in AZ, I have to get this fixed sooner than later. Thanks for the reply!
Joe |
Posted: Sat Aug 01, 2015 6:57 pm Post subject: |
There is also a temp switch that is under the radiator from what I understand. Getting to it though requires a lot of removal of other parts to get to it. PITA! |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Sat Aug 01, 2015 7:10 pm Post subject: |
Check the fuse on the power distribution panel on top of the battery, the first green 30a fuse from the left (as you are looking at the battery) supplies power to the fan control module, these are notorious for building up heat & will cause the fans & A/C not to work. It can also cause the car to spontaneously combust. If there is ANY signs of distortion or corrosion, replace the fuse panel with a DEALER part, aftermarket ones fail within 3-5 months. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Aug 01, 2015 8:18 pm Post subject: |
Thanks for all the info ps2375 and TDCTDI !! |
