grandpa pete Samba Member
TheDon Samba Member
Joined: July 14, 2005 Posts: 498 Location: Windermere
Posted: Wed Oct 21, 2015 10:22 am Post subject: |
Id bring my armor if I had a secure area to lock it up in when I'm not in it. But I probably won't. _________________
lawn ninja wrote: |
Every time I crush a fat chick I feel like a I save baby kittens and baby kittens are important to everyone. |
TheDon Samba Member
Posted: Thu Oct 22, 2015 7:54 pm Post subject: |
Do I remove the somewhat crumbly tar board or not? I'm torn between the look of the board or board free. _________________
lawn ninja wrote: |
TheDon Samba Member
Posted: Sat Oct 24, 2015 12:25 pm Post subject: |
Got the engine back in and it fired right up. Now to do the cap,rotor, points, and condenser and it will be ready for bug jam. I need to make the marks on the pulley for timing. I will probably make notches in the original pulley instead of getting an after market pulley. _________________
lawn ninja wrote: |
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Sat Oct 24, 2015 5:51 pm Post subject: |
TheDon wrote: |
Do I remove the somewhat crumbly tar board or not? I'm torn between the look of the board or board free. |
Don did you take the tar board out? I got new for mine but I'm thinking of leaving it out I am putting sound reading on the inside. Love your build, great job. How far are you from Bug jam? If you don't mind me asking. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Sun Oct 25, 2015 10:30 am Post subject: |
grandpa pete wrote: |
I'll still be the old guy with the gray hair |
That should.narrow it down... |
TheDon Samba Member
Posted: Sun Oct 25, 2015 1:50 pm Post subject: |
Dake wrote: |
TheDon wrote: |
I left it in. I'll take it out this winter. Once I get the rear parcel tray replaced I'll add fat mat inside.
I'm about 45-1 hour from bug jam _________________
lawn ninja wrote: |
TheDon Samba Member
Posted: Thu Nov 05, 2015 7:33 pm Post subject: |
After bug jam I plan on having the rust in the parcel tray repaired so I can start the interior restore. I'll clean the engine up too. I'm torn between black paint for all of the tins or the hammered metal look.
Side note, I bought a couple boxes of LED outdoor Christmas lights to put on my beetle. I thought it would be fun _________________
lawn ninja wrote: |
TheDon Samba Member
Posted: Sun Nov 08, 2015 5:44 pm Post subject: |
Found a lot of things I was looking for today at bug jam
Got a deck lid for $50, nice and dent free and rust free. Two extra wheels, a radio block off plate, some heater Hose, a Holstein jack and some other misc crap. I need to figure out how to take the jack apart and restore it. Also how in the world do I use it? It only has one spot for the rod to go in to jack up
Looks like this
Clearly not as nice. But the base looks unused and the blue is still nice.
But now I need to do an alternator upgrade since my generator killed itself after a wire came undone from the voltage regulator. Thus toasting it
But now I'm making room in the garage for the interior restore _________________
lawn ninja wrote: |
TheDon Samba Member
Posted: Tue Nov 10, 2015 5:15 pm Post subject: |
I was going to put my new/used deck lid on tonight but I noticed the spring mount was cut out from it
Hopefully I can repair that missing part
And this
This is the chunk missing. I sanded it down and while sanding it smelled just like fiberglass.
I'm pulling the generator out tomorrow in anticipation of my new alternator. _________________
lawn ninja wrote: |
Corney13 Samba Member
Joined: July 06, 2014 Posts: 265 Location: Castaic, California
Posted: Tue Nov 10, 2015 10:52 pm Post subject: |
TheDon wrote: |
And this
I'm pulling the generator out tomorrow in anticipation of my new alternator. |
I have a 1970 decklid that you can salvage the spring bracket out of. I would think you could make it work with the earlier lid. Looks like the support is similar. I cut the vents out of it. You can have it for free. I can cut out what you need and mail it to you. Just pay shipping.
TheDon Samba Member
Posted: Wed Nov 11, 2015 6:08 am Post subject: Re: TheDon's first VW: '64 low n slow |
thanks! I sent you a PM
I need to get a mig welder on the cheap and learn how to weld so I can fix my rust issues. _________________
lawn ninja wrote: |
TheDon Samba Member
Posted: Fri Nov 13, 2015 7:44 am Post subject: Re: TheDon's first VW: '64 low n slow |
I'm not done yet. Still needs more lights and maybe garland. I'm glad LED strings are cheap. Otherwise it wouldn't be possible with my inverter. The box the lights come in says I can put 90 strings k the same circuit. I did the math and the amp draw is pretty low per string which is nice. _________________
lawn ninja wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Fri Nov 13, 2015 9:45 am Post subject: Re: TheDon's first VW: '64 low n slow |
I like your Xmas lights. So your gonna rock it on the road?
I found a mig welder on CL for real cheap. I also cruised pawn shops looking for a welder. I suggest that you locate one that uses shielding gas. Not the flux core type. Post weld clean up will be easier.
Good luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
TheDon Samba Member
Posted: Fri Nov 13, 2015 9:15 pm Post subject: Re: TheDon's first VW: '64 low n slow |
It might be illegal to run with them on. But with half of the crap I see on the road in FL ( monster trucks for a start). I'll probably be ok. _________________
lawn ninja wrote: |
Posted: Sat Nov 14, 2015 5:16 am Post subject: Re: TheDon's first VW: '64 low n slow |
There was a guy that used to be in the Lee road area that had his car covered with lights. Also had two huge wings on top of the car like a Manta ray. |
Posted: Mon Nov 23, 2015 11:27 am Post subject: Re: TheDon's first VW: '64 low n slow |
TheDon wrote: |
I need to get a mig welder on the cheap and learn how to weld so I can fix my rust issues. |
There are several good You Tube video's that explain mig welding ;
if you want a free private lesson let me know when you want to come by .
If you want to know if I know what I'm doing read the build thread for the Sedan Delivery. _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
TheDon Samba Member
Posted: Mon Nov 23, 2015 12:44 pm Post subject: Re: TheDon's first VW: '64 low n slow |
TheDon wrote: |
If you want to know if I know what I'm doing read the build thread for the Sedan Delivery. |
I think you might have a slight idea at whats going on with welding _________________
lawn ninja wrote: |
sovereignsamba Banned
Posted: Mon Nov 23, 2015 12:53 pm Post subject: Re: TheDon's first VW: '64 low n slow |
panama beige here too! underneath all this spray paint somewhere.. This was my grandmas car, you dont see this colour that often, I dont think it was very popular. |
TheDon Samba Member
Posted: Thu Nov 26, 2015 7:04 pm Post subject: Re: TheDon's first VW: '64 low n slow |
Got my new alternator today. I removed all of the old stuff and now to install the new. But I need to redo the wiring I think since my old regulator was in the engine compartment and I have two thick gauge wires that one is for the dash electrical and the other goes to the battery or starter I think.
I bought some 8 gauge wire today but I might just redo the current wire ends and I'm ordering a new wiring harness in a few months to replace my hacked up old harness. _________________
lawn ninja wrote: |
