dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
Posted: Sun Aug 09, 2015 7:13 am Post subject: Fuel Pump Frame Bracket Mount |
I have been wanting to install a new fuel pump as preventative maintenance before road trip season this fall. Everything is original and I knew my rubber mounts needed to be replaced, but it turns out I need to replace everything. I found the complete pump bracket at BD which solves most of the problem.
http://www.busdepot.com/022133500va
The issue I am having is that the bracket that mounts to the frame is so rusted I can't get the screws from the rubber mounts out. I can't tell if there are nuts or if the mounts just screwed into the bracket? Does anyone know where I can get a new or used one of these?
insyncro Banned
Posted: Sun Aug 09, 2015 7:28 am Post subject: |
Cut the nuts off and remove the wasted rubber mounts, sand it or use convertor to seal it, paint it use it.
A piece of flat stock could easily be bent to match and drill a few holes if you want new. |
Posted: Sun Aug 09, 2015 8:51 am Post subject: |
Good to know those are nuts on there. I will need to buy some new ones along with a Dremel to knock this out. |
Posted: Sun Aug 09, 2015 9:22 am Post subject: |
Just a heads up if you are in the market for a Dremel. According to reviews the quality has really gone downhill on the new models. I picked up a German made Proxxon rotary tool for $118 shipped. Looks to be much higher quality. http://www.woodworkingshop.com/product/px38481
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Posted: Sun Aug 09, 2015 9:27 am Post subject: |
Here's where acid might be just the trick. If you've been watching djkeev's thread on his '86, you'll note he uses muriatic acid for corrosion/rust removal of small parts. While muriatic is effective, phosphoric will do the same thing. Or if you really want to go gentle, dunk it in pure vinegar. The point is the acid will eat away at that rust and will make it easier to remove the old/broken mounts. Just make sure to neutralize the piece after the acid. Lots of reading on this, and if you choose to go the acid route then do the research and be safe, it can/will land you in the hospital if used incorrectly. But a quick dunk in a phosphoric acid solution (probably 1-5 minutes) would free that right up and allow you to take a 22mm (IIRC) wrench and take the old mount right off. No fighting, no drilling, etc. Or as insyncro suggests, just fab up a new one real quick.
-Kevin _________________ 1986 Westfalia Weekender Wolfsburg, RJE 2.3
1985 Tin Top, Subie 2.2 + 5MT
Floppy Mirrors no more: http://www.thesamba.com/vw/forum/viewtopic.php?t=653018&highlight=
Remove the front spindle nut with ease: https://www.thesamba.com/vw/forum/viewtopic.php?t=679567&highlight=
Remove the rear wheel bearing housing without messing with the big 46mm nut: https://www.thesamba.com/vw/forum/viewtopic.php?t=679507&highlight=
-Nec Spe, Nec Metu |
insyncro Banned
Posted: Sun Aug 09, 2015 10:56 am Post subject: |
dart330 wrote: |
Good to know those are nuts on there. |
Those were nuts |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
insyncro Banned
Posted: Sun Aug 09, 2015 12:29 pm Post subject: |
OK, not nuts.
My bad
Good to know, gotta check a Syncro mount, I can't remember if they have the same or not, but thought they had to be held to the tank straps with nuts. |
Posted: Sun Aug 09, 2015 3:08 pm Post subject: |
I guess I will try the vinegar trick first since I will have plenty of time waiting on the new bracket from BD. A buddy of mine has been doing electrolysis for his rusty parts and seems to like it. No acid to deal with. I got some spray primer and paint to finish it off once the rotary tool arrives and I sand it down.
I'm new to Houston so haven't found a metal fabricator yet. The bus originally came from Florida, then Chicago and I picked it up in Missouri. Frame is solid but everything bolted to it looks like it lived in saltwater. |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Sun Aug 09, 2015 4:32 pm Post subject: |
Dart, be weary of people around here in Houston. Every time I have paid someone to do something for me here I have gotten screwed. _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Merian Samba Member
Posted: Sun Aug 09, 2015 4:38 pm Post subject: |
yes, be wary or else you too will be weary |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Sun Aug 09, 2015 7:44 pm Post subject: |
The electrolysis setup looks so easy. Will give the vinegar trick a while as I am traveling the next two weekends. If no luck, will switch over to electrolysis. I don't have any big road trip plans until Texas Busfest in October. Skipping Busses Nowhere Near The Arch this year in Sept (really hope it isn't the last year as it is our favorite VW event). http://www.bnnta.com
We really like Houston but the old school VW shop has gone down to part time as the owner is looking to retire. http://smithforeignauto.com
I really need to get the AC fixed so if anyone has a recommendation for a shop that does old cars and R12 I would love to find them. Willing to take it to DFW or Austin. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon Aug 10, 2015 7:11 am Post subject: |
I don't see why you could not use 6mm nuts in place of the stamped threads in the bracket. You could center drill the remnants with a 1/4" drill bit and be done. _________________ ☮️ |
Hybrid VW Samba Member
Joined: May 03, 2014 Posts: 128 Location: Central Oregon
Posted: Mon Aug 10, 2015 9:58 am Post subject: |
Did you get that filter bracket from BD also? I need one for my '85 and Van Cafe' didn't have one the last time I asked. |
Posted: Mon Aug 10, 2015 10:40 am Post subject: |
rsxsr wrote: |
I don't see why you could not use 6mm nuts in place of the stamped threads in the bracket. You could center drill the remnants with a 1/4" drill bit and be done. |
That was the plan if it had nuts already. If I can't get the old bolts out then that is what I will end up doing.
Hybrid VW wrote: |
I will have to take a look when I get home but I believe it has already been replaced. I had the fuel filter done along with all the fuel lines when I purchased it last year. |
Posted: Mon Aug 10, 2015 4:05 pm Post subject: |
Hybrid VW wrote: |
Looks like I have the home-made version. I couldn't find one on the BD website.
Posted: Mon Aug 10, 2015 8:48 pm Post subject: |
Awesome! |
