RidinRetro1973 Samba Member
Posted: Sun Mar 05, 2017 8:17 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Your Bus looks great! I've been following this thread for a while.
Where'd you get your white emblem? Is it pretty good quality? I recently broke the original one on my Westy and I'm looking for a nice replacement. _________________ Instagram - VÄÄN Design Co.
My builds:
'68 AutoStick "Gawaine the Green Knight"
Modern Vanagon Westy Interior |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Mon Mar 06, 2017 10:21 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
RidinRetro1973 wrote: |
Where'd you get your white emblem? Is it pretty good quality? I recently broke the original one on my Westy and I'm looking for a nice replacement. |
Thank you, a little at a time adds up.
As for the emblem, $25 bucks from BusDepot. Seemed solid with a little flex but it definitely could "pop" or break. But being flat on the nose, I believe it'll last a good while. Coloring seems within the mould. Don't forget to buy new emblem tabs to hold it, they're $3 for all 3 you need. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Tue Mar 14, 2017 7:15 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Extreme fuel smells in the cab the last few weeks had me concerned, so to the topics I went looking, for potential culprits.
Just minutes in, led me to finding this dry, worn out fuel filler neck.
A replacement fuel neck will be here tomorrow, along with a new fuel cap. Time tomorrow will tell if my issues were simple enough.
Any ill effects to performance or noticible issues at that, from having a non-airtight fuel system? No telling how much gas sloshes around in and out of the broken sections. _________________ The Bus Barn Ltd. Co.
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Wed Mar 15, 2017 5:56 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
That was a timely post, Sam. It reminded me to check mine, and.... found it has a tear in it too. Grrrrr. And I just replaced the rest of the hose/pipe down to the tank. It probably tore while I was installing the new parts.
So thanks, Sambo! You saved me from a fuel spill the first time I tried to fill up, or from smelling it every mile. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Fri Mar 17, 2017 4:47 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Man they sure don't make things like they use to, and this is one of those situations.
Purchased my replacement fuel neck from BusDepot for around $20 from a well known manufacturer of replacement VW parts. The material is no where are thick and durable feeling, and mine I received was actually not torn but what looked like a "cut" in a non crucial area. I'm not sure if this is the only option for such replacement, but I'd entertain the idea of some other option out there.
For at least the time being, it should be the job.
wcfvw69 Samba Purist
Posted: Fri Mar 17, 2017 5:29 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
SamboSamba22 wrote: |
Welcome to the world of "new" parts being sold for our VW's today. It's rare that I buy a "new" part that is close to as good as the VW part unless it's a NOS one. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri Mar 17, 2017 5:58 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
I ordered one from Wolfsberg West on Wednesday and amazingly, it arrived in today's mail. Good job, WW.
When I opened it, I had the same reaction, Sam. The original one is thicker and more rigid, while the new one is noticeably thinner and very floppy. WW typically only sells the best product available (from my limited experience buying VW parts), so I'm guessing there isn't anything better out there right now.
Has anyone found a better option? _________________ -Kent-
---williamM |
Posted: Sat Mar 18, 2017 6:49 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
So this is what the #24 behind the spare tire/linen cabinet looked like:
Definitely faulty. The culprit of my experienced fuel smells? Time will tell.
On another note, let's jump to the fan shroud openings. This one is on top just left of the fan, the other twist style caps are too large, is this hole an inspection port? Lots of air blows out of this thing.
Also the hose/line that runs from the charcoal canister into the fan shroud, do they make an adapter or connector for this opening? I have hose but nothing air tight to hook it up to, leaving me trying to come up with something. Really wanting to button this thing up, and make sure things are in good working order. _________________ The Bus Barn Ltd. Co.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51146 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Mar 18, 2017 7:14 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
That hole is added when some styles of A/C compressor gets in the way of the OG hole on the LH end of the shroud. Home depot will have assorted caps in the electrical dept, or connect the canister to it and cap the other one. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Mar 18, 2017 10:19 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
this the original hole? |
Yes, but the 12mm nipple has been sawn off, time to get creative with grommets and/or JB weld. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
WildIdea Samba Member
Joined: September 17, 2016 Posts: 928 Location: Black Hills, South Dakota
Posted: Sun Mar 19, 2017 8:24 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
I too was looking to replace my filler neck rubber and all my fuel system lines and ordered a new piece from WW. It arrived as others describe. Really thin and floppy, but not only that, not shaped anything like my OG piece. My original has what looks like a beak inside and a small port that let's air out the top. The new piece is missing all that and basically looks like the upmost minimum to maybe pass as an actual replacement part. I decided my original was in decent enough shape to still run and shelved the new one but can't imagine wanting to ever install it. Mine was just a little dirty and still playable, so I whipped it down with a rag with a touch of gear oil, and put it back on the filler pile and reinstalled. Sorry yours was so cracked, bummer. |
Posted: Sun Mar 19, 2017 8:52 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
WildIdea wrote: |
My original has what looks like a beak inside and a small port that let's air out the top. |
It sounds like yours has the nearly extinct 'bird's beak' in it. I believe it was meant for California vehicles, and it was a mechanism meant to keep leaded fuel from beong pumped into the tank. From what I've heard, most people find parts of the beak floating around in their gas tank after it breaks into many pieces.
That said, I would wonder if the new filler piece will replace it. After installing mine, I found it to be a good fit. But I will be very careful when filling the tank so that doesn't get stressed. _________________ -Kent-
---williamM |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sun Mar 19, 2017 8:30 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Fuel pump pin: can you remove the pin and through-bolt that with a nylock nut
Bird's beak California application. One NOS, one breaking apart as they all do, and that crappy filler neck replacement currently offered:
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Mon Mar 20, 2017 9:12 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Whats wrong with it? Its just missing 10 meters of electrical tape.. _________________ .ssS! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Mar 20, 2017 11:05 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Think they all look like that- [img][/img] _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22460 Location: Escondido CA
Posted: Mon Mar 20, 2017 11:16 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
When I had the motor out in the 77, I cleaned and painted the engine bay, deadened all the gas tank area and did some rust care. Then I crawled my big ass up under there again, sat with some new fuel line, can lube and some dikes replacing all of those suckers. I even got a plastic T for the union in the engine bay to suck the fumes into the manifold. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Tue Mar 21, 2017 4:49 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Wasted youth wrote: |
Interesting on these, my 74 is a California emissions bus but didn't have the birds beak inner section. Didn't see it in the tank two years ago either... _________________ The Bus Barn Ltd. Co.
riverside66 Samba Member
Joined: June 04, 2008 Posts: 218 Location: Sparta, NC
Posted: Tue Mar 21, 2017 6:35 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Interesting on these, my 74 is a California emissions bus but didn't have the birds beak inner section. Didn't see it in the tank two years ago either... |
And I've got a 79 bus that was purchased new here in FL, and it has that bird beak.
Man, I'm with you on the frustration of the newer parts. I got lucky and scored an OEM VW fuel neck from a local vw parts shop. But it's nothing like the original, which is way more robust. Maybe this is VW Brazil?
Fortunately, when I went to replace my original, I noticed that it was just the "beak" section that was ripped, and not the thick outer portion (it was still in great shape) so I kept it. _________________ 1977 Standard Beetle -Sold-
1979 Transporter - "Wheatbread" -Sold- |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Tue Mar 21, 2017 7:43 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
I also have a new filler neck rubber that I have yet to install,thinking when I do install it I will make a support bracket for the filler pipe to take the weight off of the rubber filler neck. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
