busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Oct 19, 2017 7:50 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
SamboSamba22 wrote: |
busdaddy wrote: |
wcfvw69 wrote: |
busdaddy wrote: |
KentPS wrote: |
busdaddy wrote: |
Do you have the rear handle on the inside of your door? |
Rear handle?? Tell us more. Is it a Westy thing?
I installed a door release on the rear hatch, just so I could get out of the back. |
Yes, it's a Westfalia thing, those OTW campers didn't quite reproduce all the little details that made the real deal so nice
https://www.thesamba.com/vw/forum/viewtopic.php?t=142155&highlight=rear+handle
It's easily retrofitted to any bus. |
Wow.. I did not know that! My 'stupid' question is was that an additional door handle along with the one in the normal place? Why was it installed? |
To avoid winding up and slamming the slider after that 3:00 AM pee excursion, you can sneak the door shut and pull the rear latch in without waking the other occupants as well as the rest of the campsite |
The link you provided Bus Daddy, the image shared by TCash of the rear handle looks identical to my bus. I don’t reallly know how one would effectively close the slider without this rear handle with cabinetry. |
Yes it's hard to close the door without a slam if you don't have the rear handle, but that pushmepullyou front handle makes opening it in the dark much easier as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Thu Oct 19, 2017 7:52 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
busdaddy wrote: |
KentPS wrote: |
busdaddy wrote: |
So, for only $15, I can be as cool as a Westy owner??? I'm there!!!
(If we keep this up, we will be to 2million posts by xmas!) _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
wcfvw69 Samba Purist
Posted: Thu Oct 19, 2017 8:13 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
busdaddy wrote: |
You forgot about the 12am pee excursion as well.. The joys of aging. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Oct 19, 2017 8:33 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
wcfvw69 wrote: |
busdaddy wrote: |
You forgot about the 12am pee excursion as well.. The joys of aging. |
Pace yourself, no beers after 10:00, switch to concentrated mixed drinks, it's the stuff that's mostly water that gets you. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Oct 20, 2017 8:28 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
For those of in the 60+/- range, an option to the 11pm, 1pm, 3pm, etc. trek to the smelly Sani-potty...
A great alternative without stumbling around in the cold and trekking thru dog poo is utilizing an empty 5-quart oil container. Not only is it water resistant and high capacity, but it has a big opening for ...well, you figure it out. _________________ -Kent-
---williamM |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Oct 20, 2017 9:15 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Geez. You guys ALL have it wrong. You're supposed to begin the session with a liter of Scotch an hour before everyone has lunch. In this fashion, you can black out by 7:00 pm. Don't drink or eat anything else. I promise you that there will be no midnight trips to the shitter. If you do it right, you will be comatose until breakfast the next day, thus fully rested and ready for the next 300 miles of driving. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sat Oct 21, 2017 7:15 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Wasted youth wrote: |
"Have you had anything to drink "
"Just one osifer" _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Sat Oct 21, 2017 12:05 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
You guys are something else. My previous process has been to maneuver between the walk-thru area, and climb over the passenger seat, using the front passenger door as means of entry and exit, late in the evening and at night.
Though this is feasible, I'd much rather just use the slider for exit, as sometimes I'm lucky to get down from the top bed let alone out of the bus. You fellas with your piss-filled camp site souvenirs, well you guys just go ahead and keep them. "Thanks, it's a Cardigan"...
On ANOTHER note, I managed to replace the sliding door seal, which at $50 from BD, I think it seems like a decent seal, time will tell, but overall fitment was nice and I am thinking I will only need to adhere the rear most portion of the seal, the fatter section to help it clear the door when closing.
On replacing the front cab door seals, the "square" section that goes around the metal arm that reveals itself upon opening the door, how does one go about installing the new seal without cutting it? Thoughts and tips? Everything I've searched pertaining the seals has been in regards to quality, which is good information, but in my case, not the information I seek. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Sat Nov 11, 2017 10:44 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Camped Thursday and Friday, a bit chilly at 38*, do you guys sleep with a heater on throughout the night??
Seen here, among those in the trailer park:
What it was all about was this beautiful hike up Pinnacle Mountain, check out that view of the Ouachita Mountains. Man, Arkansas is beautiful, and this time of year its absolutely perfect for exploring. #visitarkansas
Posted: Mon Nov 20, 2017 7:41 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Hey Sam...
Have you taken your beautiful rig to show to the PO? I'm sure she would be amazed at the change, and appreciative of all your preservation efforts.
I just looked back at the beginning of your thread of it being yanked from its previous resting spot. Looking at it then compared to now is an astounding transformation. _________________ -Kent-
---williamM |
Posted: Sat Dec 09, 2017 10:07 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
KentPS wrote: |
Hey Sam...
I just looked back at the beginning of your thread of it being yanked from its previous resting spot. Looking at it then compared to now is an astounding transformation. |
Ironically, I was cruising down Markham here in Little Rock, and this lady starts acting silly behind me a drive-thru Mexican joint, and after really looking her over, it was Judy, the lady that allowed me to love the bus. Unfortunately it was raining pretty good, so it was brief and we stayed in our vehicles, but I have thought it to show and tell it to her, though I must prepare myself, she's a hoot!
Also, the Brazilian door seals? The passenger seal is nice and fits fairly well, as for the driver? The material is nice, but HOLY HELL I am so sick of slamming my door to get it to shut, I am afraid one of these days I'm going to pull through on the inner handle. _________________ The Bus Barn Ltd. Co.
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Sat Dec 09, 2017 10:15 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
A good cold rated sleeping bag will take you down to freezing point outside.
Nothing on while sleeping. No snuff outs for me. I want to die bouncing my first check. _________________ .ssS! |
Ry-dog Samba Member
Joined: May 31, 2003 Posts: 450 Location: Lunenburg, MA
Posted: Sat Dec 09, 2017 12:26 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Definitely no heat on while sleeping for safety reasons. I have a BN4 which can really heat up the bus fast - I let it run for a while to get it good and warm, then shut it off before getting in my 20-degree bag.. _________________ '70 Westy
'14 Jeep Grand Cherokee EcoDiesel |
Posted: Sat Dec 09, 2017 3:00 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
I've done a fair amount of camping, and the only thing that is difficult to deal with in cold weather isn't really the sleeping bag or clothing. It's breathing really cold air all night. Waking up with a frozen nose and sore throat leads to sickness.
Haven't quite figured that one out yet. Closest remedy I've got is a ski mask. |
Posted: Fri Dec 22, 2017 12:45 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Bagel place came out to light the propane torches on the deck because it was 65F I was the only one outside while there was a ten minute queue for a table inside. Laguna Beach CA...where else?
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Fri Dec 22, 2017 6:59 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Abscate wrote: |
Wimps! I worked outdoors in 10 degree F weather for most of the day yesterday. Of course I freeze on the Cali coast if it drops below 70.... _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
danfromsyr Samba Member
Posted: Fri Dec 22, 2017 7:52 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
that looks like an electric site..
for electric sites we bring a small cube/oscillating electric space heater and set it on the counter or the front table between the seats..
your paying extra for the electricity, might as well be warm.
Abscate wrote: |
Posted: Fri Dec 22, 2017 8:02 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
it amazes me how few VWs I see in the south when we travel for christmas in our vanagon camper. I mean hey guys it's not 98* @ 90% humidity so get out and enjoy.. it's usually decent camping (by NY standards) up to Myrtle Beach, that 1st week of January..
and soooo many of the southern state campgrounds are all electric sites..
not like that in the north or even out west.
Mmmm, cold weather is here, why am I not camping???
Perhaps I could swing the eve of Christmas... |
Abscate wrote: |
Posted: Fri Dec 22, 2017 7:29 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
danfromsyr wrote: |
My thoughts EXACTLY! It’s the perfect time for camping down here, less people, sometimes discounted rates, no humidity, or birds (I mean mosquitos), and the heat. Now it’s officially, I’m just a lazy bum.. _________________ The Bus Barn Ltd. Co.
