Engine revs up when I apply brake pedal
lransburg
lransburg is offline
PostPosted: Sat Sep 05, 2020 4:10 pm    Post subject: Engine revs up when I apply brake pedal Reply with quote
I have a 1971 bus with Westfalia weekender package. When I brake, the engine revs up, and when I release the pedal it returns to normal. The pedal is hard to press, but I’m able to stop. I’ve seen some posts that said their idle decreased when braking, and the problem could be either vacuum line or servo. What about when idle increases when braking? Any ideas?
SGKent Premium Member
SGKent is offline
PostPosted: Sat Sep 05, 2020 4:31 pm    Post subject: Re: Engine revs up when I apply brake pedal Reply with quote
bad booster
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Abscate Premium Member
Abscate is offline
PostPosted: Sat Sep 05, 2020 6:44 pm    Post subject: Re: Engine revs up when I apply brake pedal Reply with quote
The leaky booster is letting in more air into your intake.
Get this fixed so that you can stop, and before the lean running hurts your engine
.ssS!
SamboSamba22
SamboSamba22 is offline
PostPosted: Sun Sep 06, 2020 8:03 am    Post subject: Re: Engine revs up when I apply brake pedal Reply with quote
Check the vacuum lines that run from the intake manifold in the engine bay to the plastic hardline section that goes to the brake booster up on the front beam.
You could very well have a bad brake booster, but sometimes its a hose or piping issue. Stress fractures in the plastic tube can cause surges or bog-down symptoms when present, same with the vacuum hose being 45 yrs old.
Sam
The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL]
