76 Windshield wipers electrical confusion
AtomNJacque
AtomNJacque is offline
PostPosted: Sun Aug 09, 2015 9:20 pm    Post subject: 76 Windshield wipers electrical confusion Reply with quote
Hey all,
I got my 76 Westy in december (its my first aircooled VW) and have gotten almost all the bugs worked out except I cant seem to figure out my windshield wipers. When I use the switch on the column nothing happens. Ive changed the #10 fuse. I am not proficient at reading wiring schematics or doing complicated electrical. But I thought you all could give me some troubleshooting tips on where to start and what to look for.
When i checked under the dash I found this (pictured) unplugged and I cant figure out what it is from/goes to.
Any help for this noob is appreciated.
[/img]
old DKP driver
old DKP driver is offline
PostPosted: Sun Aug 09, 2015 9:41 pm    Post subject: curent track 39 Reply with quote
That plug is for the EGR counter box that is connected to the speedo cable
current track 39 in the wiring diagram.
TURN THE KEY to the on position and flip the wipers on and then go outside and push the wiper arms (gently) and see if they then move.
Next: is finding out if the wiper motor is running and possibly the gear is
stripped.
Wiring info in the Technical section ^^^^^ right upper area.
V.W.owner since 1967
AtomNJacque
PostPosted: Mon Aug 10, 2015 12:38 am    Post subject: Re: curent track 39 Reply with quote
old DKP driver wrote:
TURN THE KEY to the on position and flip the wipers on and then go outside and push the wiper arms (gently) and see if they then move. .
I did this and had no movement.
