a57oval Samba Member
Joined: September 28, 2003 Posts: 202 Location: West Seattle, WA
Posted: Tue Apr 18, 2017 4:49 am Post subject: Re: Subarugears Bus Build |
A huge thanks to Captincanuck for the info on the intake elbow. I picked up the Saturn parts at a local Pick N Pull and it is a perfect fit. I had started on an throttle body reverser with a built in air port but as soon as i saw what he had done I scrapped that idea. Fantastic tidbit of info.
Peter |
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Posted: Tue Apr 18, 2017 6:08 am Post subject: Re: Subarugears Bus Build |
pkrboo wrote: |
And you had the space to use this without a throttle body reverser because the subarugear box pushes the engine back further than normal? |
Correct
a57oval wrote: |
Peter |
Glad it worked out for you. I haven't put to many k's (miles) on mine yet, but the CVs don't appear to be objecting to there new angle that results from the output flanges being further back. Time will tell _________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0 |
lolight70 Samba Member
Joined: August 22, 2013 Posts: 160 Location: West Australia
Posted: Tue Apr 18, 2017 6:35 am Post subject: Re: Subarugears Bus Build |
U can also use the oem early liberty(legacy) intake pipe, its similar to the Saturn u r showing |
Posted: Tue Apr 18, 2017 6:37 am Post subject: Re: Subarugears Bus Build |
Pictures of this past weekends actions;
Finished up the wiring for the cluster. Hope I measured everything correct and this thing still fits in the dash! (Lots of Subaru wiring harness was reused in this project)
Had some water coming in behind the directional from a crack, so fixed that up and installed new gaskets
Replaced the slider nylon block
Finished up the wiring for the BMW power window mod. Installed the switches in a spare ashtray front I had laying around (Need to find a plug for that hole now, and it's proving difficult if I don't want 60 of them)
Installed a clock in the headliner
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
pkrboo Samba Member
Joined: October 09, 2009 Posts: 512 Location: Lincolnshire, UK
Posted: Tue Apr 18, 2017 8:19 am Post subject: Re: Subarugears Bus Build |
captincanuck wrote: |
^I tried to edit that, but it was to old. The elbow was actually from a Saturn (GM). Don't think they ever came to the UK. PN is 24408492 |
what model in particular? just trying to figure out a vehicle from over here that might be suitable. pick and pulls over here dont really run the the same way as over there. _________________ 1979 Sage Green Westfalia P22 |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Tue Apr 18, 2017 8:42 am Post subject: Re: Subarugears Bus Build |
Googling the part number brings up the Saturn L series, so you might look at Opel/Vauxhall Vectras from about 2000-2002 and similar vintage Saab 9-3/9-5 cars. |
pkrboo Samba Member
Posted: Tue Apr 18, 2017 8:48 am Post subject: Re: Subarugears Bus Build |
tristessa wrote: |
cheers thanks, i need to do some research when i get home from work. _________________ 1979 Sage Green Westfalia P22 |
Posted: Tue Apr 18, 2017 9:23 am Post subject: Re: Subarugears Bus Build |
vwwestyman wrote: |
I don't think that nylon block is seated all the way in the track in this picture.
It should be all the way in the track, not rubbing on the outer edge of the top ridge. |
Interesting, I will investigate. Thought there was a lip in the top of the block for this reason. But I could be mistaken. Was pretty deep into the "2-4" by this point in the X-long weekend _________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
pkrboo Samba Member
Posted: Tue Apr 18, 2017 11:52 am Post subject: Re: Subarugears Bus Build |
I have found a couple of possibles here in the UK
AND looking at these now i am wondering if a FI S boot of a VW will also work? _________________ 1979 Sage Green Westfalia P22 |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Apr 18, 2017 4:20 pm Post subject: Re: Subarugears Bus Build |
vwwestyman wrote: |
Interesting, I will investigate. Thought there was a lip in the top of the block for this reason. But I could be mistaken. Was pretty deep into the "2-4" by this point in the X-long weekend |
A "2-4" of Moosehead probably kicks a bit! _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Tue Apr 18, 2017 6:53 pm Post subject: Re: Subarugears Bus Build |
_________________ nothing |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Apr 19, 2017 7:07 am Post subject: Re: Subarugears Bus Build |
lol This is great! _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Fri Apr 21, 2017 3:02 pm Post subject: Re: Subarugears Bus Build |
vwwestyman wrote: |
Good call. Upon closer inspection with fresh eyes you were correct. All good now.
Got my rims back from being power coated and installed the new General Grabbers. "Everything is coming up Millhouse"
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Fri Apr 21, 2017 5:47 pm Post subject: Re: Subarugears Bus Build |
good looking bus. you should be proud _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Ives676 Samba Member
Joined: June 20, 2013 Posts: 274 Location: Rogers, AR
Posted: Fri Apr 21, 2017 7:53 pm Post subject: Re: Subarugears Bus Build |
skills@eurocarsplus wrote: |
good looking bus. you should be proud |
What he said.... Now go score another 2-4....... _________________ If you haven't bled on them, you haven't worked on them.
albe Samba Member
Joined: September 26, 2009 Posts: 8 Location: Groton CT.
Posted: Mon May 15, 2017 5:48 pm Post subject: Re: Subarugears Bus Build |
Thanks for posting all this info! I found a 73 camper, no engine/transmission with a nice bod and a friend getting ready to junk a Subaru due to rot. Feel like I've got a fighting chance of putting this together. Thanks again! |
Posted: Sat May 27, 2017 9:12 pm Post subject: Re: Subarugears Bus Build |
Gauge installed and looking pretty slick if I do say so myself
Cleaned up all the chrome and installed a co-pilot.
Nice to go to the mall in the bus, never a problem finding it Also nice for a nap after I devour a cinnabon and slip into a sugar coma
