modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Wed Aug 12, 2015 5:19 pm Post subject: How to remove broken dowel pins (crank to flywheel) |
I got a great deal on a scat 82 stroke crank with all 8 dowels broken off in it.
The end of it is so mangled i can't see exactly where the pins are(were).
The crank is very hard, the pins are harder.
Two days ago I thought of how to remove the pins.
I tried it today and got all 8 out in 40 minutes.
Now, I'll still have to weld up around the holes and re-cut the back of the crank and use 11/32 pins, BUT, that's doable! Done it several times before.
There are a lot of sharp thinkers around here, so I bet somebody can guess how I did it.
Clue: step one was drill a 3/16 hole through each dowel (carbide end mill) |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Wed Aug 12, 2015 5:44 pm Post subject: |
Core.
Tap to grab.
Slide hammer on tap.
Out.
I've found some dowels were only hardened on outside. Tapped and threaded a bolt in and out they came. |
modok Samba Member
Posted: Wed Aug 12, 2015 5:54 pm Post subject: |
nope. No threads |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Wed Aug 12, 2015 5:55 pm Post subject: |
Drill 3/16 hole, tap, thread, then use grease to push them out?
Genius...
Oops! No threads.... Hmmmm.. |
modok Samba Member
Posted: Wed Aug 12, 2015 5:58 pm Post subject: |
YES! or close enough.
Flooded with heavy gear oil and drove with a short piece of 3/16 drill rod.
A few taps with a hammer, add more oil, few more taps, and out!
Just like a little hydraulic jack! |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Aug 12, 2015 6:01 pm Post subject: |
brilliant. |
modok Samba Member
Posted: Wed Aug 12, 2015 6:10 pm Post subject: |
Thanks. I wasn't sure if it would work, but it DOES!
I think grease would work well too, but I didn't have a needle attachment to squirt the grease into the tiny hole.
safety goggles and heavy gloves are recommended. |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Wed Aug 12, 2015 6:33 pm Post subject: |
Is this something that you are interested in offering as a service. I know someone with a messed up scat 78 that might be interested. Four dowels are broke and four are good but I would take all out for butt grinding.
Ok sickos just tring to describe it.
Dan |
modok Samba Member
Posted: Wed Aug 12, 2015 7:04 pm Post subject: |
If it's worth the shipping and 60 an hour, I don't see a reason against it.
But.....I betcha if you explain it to Jose he can do it too! |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Wed Aug 12, 2015 8:43 pm Post subject: |
Quote: |
Now, I'll still have to weld up around the holes and re-cut the back of the crank and use 11/32 pins, BUT, that's doable! Done it several times before. |
What kind of filler rod do you use for that sort of thing? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Wed Aug 12, 2015 8:46 pm Post subject: |
What do I win?? Hahaha!
I'm such a newb.
Someone here had suggested that method when I was having trouble trying to get my clutch shaft out. It worked like a champ. Amazing.
Think it was Glenn? |
modok Samba Member
Posted: Wed Aug 12, 2015 9:39 pm Post subject: |
theKbStockpiler wrote: |
What kind of filler rod do you use for that sort of thing? |
I can't give away all the secrets. I should have said I have an edm machine at work, which is true, but it isn't plugged in, and doesn't work.
It's all in the technique anyhow. But if you really want to know it's the same filler material used in traditional sub arc to build up steel crankshafts. The secret is......... there is no secret. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Wed Aug 12, 2015 10:27 pm Post subject: |
Any body ever try a pin spotter and a slide hammer?
We had one at the shop where I used to work that worked good, we had to grind them off if they were put in the wrong place.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
morymob Samba Member
Posted: Thu Aug 13, 2015 4:34 am Post subject: |
modok wrote: |
What happens as dowel part has moved & contacts the 'driver' dowel, movement stops, its still in crank , no magnet will pull broken part out of crank?? Try to stick a weld to finish? Maybe just lucky but only broken dowels I've run into were 36hp ones, they r easy to break if u don't slowly & evenly remove fwheel. |
Posted: Thu Aug 13, 2015 5:21 am Post subject: |
I forgot about the 'grease and dowell' trick. Used it years ago to pop bushing out of V6 or 8 crank we were converting. Worked surprisingly well! Got a little messy but it worked. |
esde Samba Member
Posted: Thu Aug 13, 2015 9:44 am Post subject: |
earthquake wrote: |
Casey |
I worry that the ground path would weld the pins into the crank. Then you are worse off than when you started.. |
modok Samba Member
Posted: Thu Aug 13, 2015 5:16 pm Post subject: |
I've never seen a stud welder successfully attach to a large chunk of hardened steel. It could be done somehow, but never seen it. |
VWfinatic273 Samba Member
Joined: November 12, 2007 Posts: 104 Location: Kernersville, NC
Posted: Thu Aug 13, 2015 5:20 pm Post subject: Genius!!! |
Thanks for sharing, this is ingenious!!!! I wouldn't have thought about it but have done similar for other scenarios. I'll put this in the trick bank |
Posted: Fri Aug 14, 2015 4:09 pm Post subject: |
What about using the trick used on broken head studs of welding a washer on the flush stud through the hole of the washer placed on top of it and then welding a washer faced nut on top of that? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
daos Samba Member
Joined: January 01, 2017 Posts: 309 Location: Stockholm, SWE
Posted: Mon Jun 15, 2020 1:40 am Post subject: |
modok wrote: |
so how do you know how deep to drill the hole, given differing dowel pin lengths? |
