kermie Samba Member
Joined: July 24, 2007 Posts: 39 Location: The Netherlands
Posted: Wed Dec 12, 2018 1:53 am Post subject: Re: Lifted busses ( not big meats under stock suspension) |
My favorite bus. Build in Holland by Marco from VW Classics Garage. I believe it sits on a complete T2B chassis welded underneath the original chassis.
_________________ 1962 Campmobile
1964 Swedish Police sold
1965 Double Door Panel sold
1966 Sundail Camper sold |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
veedub Samba Member
Joined: February 03, 2004 Posts: 382 Location: Central Coast, CA
Posted: Thu Dec 13, 2018 8:13 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
_________________ ~slovolks~ |
veedub Samba Member
Posted: Thu Dec 13, 2018 8:14 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
built this years ago, is on the east coast somewhere now _________________ ~slovolks~ |
d-rick Samba Member
Joined: May 14, 2006 Posts: 889 Location: Columbia,MO
Posted: Thu Dec 13, 2018 11:03 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
got this bus with nothing under it at all ,I had a nice early bay beam with new ball joints...so it went in as well as a big nut tranny,rear end clicked one notch... I don't have any shocks yet, need to weld in the rear upper shock mounts ,as they were cut off.
at least this many beers tall
_________________ 1959 mango-trailerbus
1962 single cab *1/2
1966 13 window
1967 panel/camper
1968 cig-panel *1/2
1968 passenger bus *1/2
1969 beetle
1969 dormobile
1978 sage green Westy
1990 DoKa
2002 Golf TDI |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Fri Dec 14, 2018 1:03 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
Is this the one that was driving through some mountain backroads many years ago and twisted up a springplate? It had a Quaife differential as I recall. _________________ nothing |
Posted: Fri Dec 14, 2018 1:08 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
Nope. Answered my own question.
KrisBalfe Samba Member
Posted: Fri Dec 14, 2018 6:05 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
This one will be getting a late bay chassis with a tdi and 6 rib limited slip differential. Unless I stumble upon another syncro to sacrifice. |
Posted: Fri Dec 14, 2018 7:20 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Fri Dec 14, 2018 7:23 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
cdennisg wrote: |
... twisted up a springplate? |
With RGB? |
Posted: Fri Dec 14, 2018 7:49 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
BarryL wrote: |
cdennisg wrote: |
With RGB? |
As I recall, yes.
I can't find the discussion, but I think it had a high torque engine with RGB's and locking diff. _________________ nothing |
klcarrie Samba Member
Posted: Fri Dec 14, 2018 10:01 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
off-road single cab
https://www.thesamba.com/vw/forum/viewtopic.php?t=...db5f4aefa7
? _________________ Pritchin'
Currently looking for:
- Bay Bus Pinion Nut Socket
- 64-67 big nut (rear) drums and brake parts, 46mm axle nuts (Big Nuts)
'55 Wolfburg Pannel Project
'55 Wolfsburg SC Project
'71 Westy |
Posted: Fri Dec 14, 2018 10:15 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
That would be it. That guy has not visited here in many years. _________________ nothing |
Posted: Tue Jan 22, 2019 5:45 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
KrisBalfe wrote: |
Well, I found a syncro. So this will become a syncro. Hopefully the welding will be done by late spring and I will probably have to sacrifice my wife’s bus to build the drivetrain but it’ll be worth it in the end. |
Posted: Wed Jan 23, 2019 1:27 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
KrisBalfe wrote: |
please please please do a build thread on that!! _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
rustybus Shasta Snow Trip Newt
Joined: November 24, 2002 Posts: 919 Location: Arizona
Posted: Mon Mar 11, 2019 11:35 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
I've always dreamed of building a syncro split. Curious to see how it goes. I'm building something sort of crazy. Trying to figure out how to get a bit more clearance, but not too much because I still want to have good handling characteristics at high speed. I need something that can be adjusted up and down I guess _________________ Richard
www.rustybus.com www.shastasnowtrip.com |
Posted: Thu Mar 14, 2019 1:03 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
rustybus wrote: |
I've always dreamed of building a syncro split. Curious to see how it goes. I'm building something sort of crazy. Trying to figure out how to get a bit more clearance, but not too much because I still want to have good handling characteristics at high speed. I need something that can be adjusted up and down I guess |
I’ve been really happy with the bay syncro conversion I did and as rusty as this bus was I’d have been replacing the entire chassis any way, seemed like an easy choice. I hope to keep the lift to a minimum too for handling and aesthetic reasons. I’ll hopefully find some time towards the end of the month to get back to the bus. |
Posted: Thu Mar 14, 2019 2:53 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
KrisBalfe wrote: |
rustybus wrote: |
Cool, looking forward to seeing what you do. _________________ Richard
kombisutra Samba Member
Joined: October 02, 2003 Posts: 4127 Location: San Anselmo, 10 miles North Of San Francisco
Posted: Sat Dec 14, 2019 11:02 am Post subject: Re: Lifted busses ( not big meats under stock suspension) |
zehbeh wrote: |
Reduction boxes IRS. What a cool setup. Do you have any more pictures and details about this? |
Outside of new RGB designs (chain or additional gears) this looks like a survivable solution.
Let's see the KCW entry, or updates on this. |
Posted: Fri Jan 24, 2020 1:38 pm Post subject: Re: Lifted busses ( not big meats under stock suspension) |
How's the reduction box IRS bus doing? Have many miles on it at this point?
How's the syncro split conversion coming?
I'm contemplating some lifted spindles for the Rustybus before Shasta to keep the tires from rubbing the seat stands. Wondering how they will affect the handling, especially at high speed. _________________ Richard
