Starter siezed engine at the end of break-in?!? (kinda long)
shifty6d
shifty6d is offline
PostPosted: Mon Aug 17, 2015 6:55 pm    Post subject: Starter siezed engine at the end of break-in?!? (kinda long) Reply with quote
Ok, this ones new to me. I have my engine on the bare pan and had it all wired for break-in, did the usual pre-start stuff (prime oil sys., pressure check etc.). So my one bonehead move was wiring my alternator to my starter switch post Rolling Eyes which caused the starter to engage again after the engine fired and was given voltage from the alternator. Got that figured out quick and disconnected it without stopping the engine (break-in rpm).
So the next 15-20 mins. go by as expected, no leaks, sounds decent, then at the end when I'm ready to throttle down to idle and shut it off completely it siezes at just under 2K rpm. I try to restart just because I'm curious what happened and the starter just clicks, put a wrench on the crank - doesn't budge!
I'm ready to tear back into the thing to see what happened and have it down to about a long block and start to take the engine loose from the bell housing starting with the starter, it doesn't want to come out so I pry it a bit and it pops out I don't think much of it and continue, get the engine onto the bench and go to remove the pressure plate bolts and the engine turns, all smooth and normal like. I look at the flywheel and about a quarter of its teeth are munched on a bit, but the starter looks normal and spins freely. I wish I had tried to spin the engine over after the starter fought me a bit because I'm thinking that's the whole problem, but the timing of it and fixing the issue has me scratching my head.
'63 Dune buggy stock trans. with 1600 - flywheel/starter/clutch are all 1600
Any ideas?
Dale M.
Dale M. is offline
PostPosted: Mon Aug 17, 2015 7:24 pm    Post subject: Reply with quote
First mistake was not shutting down engine when problem happened..No it would not have hurt break in run, but might have saved you from current headache..
Usually when something is "not right" you should stop.....
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
shifty6d
shifty6d is offline
PostPosted: Mon Aug 17, 2015 7:48 pm    Post subject: Reply with quote
Problem happened at end of break-in when going to idle engine down. If you're referring to the starter being run by the alternator, I heard that distinct noise right away after initial start up and as soon as I did I pulled the wire and the starter disengaged and it sounded normal again.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Mon Aug 17, 2015 10:38 pm    Post subject: Reply with quote
More than likely you seized a main bearing.
Did you check out the size of everything?
Could you have missed a dowel pin on one of the main bearings?
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
FreeBug
FreeBug is offline
PostPosted: Tue Aug 18, 2015 12:58 am    Post subject: Reply with quote
I'm confused, help me get this straight. The engine wouldn't turn over when it was in the car, but turns over now that it's no longer connected to the bell housing?
Is the engine still fully assembled?
Do you have another starter laying around?
DWP
DWP is offline
PostPosted: Tue Aug 18, 2015 3:39 am    Post subject: Reply with quote
I would check the starter again. To me it sounds like the starter was engaged the whole time. Might of jammed "on" Only when you lowered the RPM did you notice it.
DWP
Dale M.
Dale M. is offline
PostPosted: Tue Aug 18, 2015 6:20 am    Post subject: Reply with quote
DWP
This was partially my though with earlier comment...
Dale
jason
jason is offline
PostPosted: Tue Aug 18, 2015 6:34 am    Post subject: Reply with quote
Starter was engaged when you had it revved up, you remove the wire, disengage motor and sound is gone. Did you lower the revs at all? If you didn't it didn't let the weak little solenoid spring pull the gear back. You were sitting their revving on the starter bearing. Starter was free wheeling in on position. Get another starter and check bushing in trans. The munched teeth are probably from your starter when it acted like a motor brake.
shifty6d
shifty6d is offline
PostPosted: Tue Aug 18, 2015 6:56 am    Post subject: Reply with quote
The starter gear freewheeling but still engaged on the flywheel makes the most sense and was my thought also, but the bushing isn't fried and the starter spins free by hand right now, case paint lookes like it never got hot, etc. I'm going to test the starter with power today and see if it sounds or acts funny. Still doesn't explain the partially chewed ring gear portion of the flywheel though, the teeth are mashed on the starter side but only about 1/4 of the way around.
Aerindel
Aerindel is offline
PostPosted: Tue Aug 18, 2015 9:01 am    Post subject: Reply with quote
Sounds like the starter seized and the momentum of the flywheel forced it through a quarter turn, munching teeth as it went.
Homemade woods/street, bug out rail. IRS, Balljoint front end. 1967 1600cc DP, Weber 32/36 progressive, tri-mil quiet pack. Rear only cutting brakes.
http://www.thesamba.com/vw/forum/viewtopic.php?t=630046
jason
jason is offline
PostPosted: Tue Aug 18, 2015 9:31 am    Post subject: Reply with quote
Exactly, those teeth are what stopped a revved motor. Starter is probably good. Gear probably un seized when cool.
shifty6d
shifty6d is offline
PostPosted: Tue Aug 18, 2015 9:33 am    Post subject: Reply with quote
Yeah, starter is junk, shaft has side play and with power it spins at inconsistent rpms. Getting a new flywheel and starter and putting it all back together. I'll post the final outcome when I get there, should be all good by the weekend (fingers crossed).
young55961
young55961 is offline
PostPosted: Tue Aug 18, 2015 9:50 am    Post subject: Reply with quote
Did you check the battery ? Maybe it just low on voltage.
56vwoval
56vwoval is offline
PostPosted: Tue Aug 18, 2015 9:55 am    Post subject: flywheel Reply with quote
Check end play with new flywheel!
Remember guys and girls, you can be right or you can be happy with your significant other! You decide which is right at that time!
Dale M.
Dale M. is offline
PostPosted: Tue Aug 18, 2015 10:15 am    Post subject: Reply with quote
IF you are testing starter out of bell housing be aware shaft is unsupported and is not a valid test.....
IF you are replacing starter consider Bosch SR 17 starter (self supported) from VW Autostick...
Dale
shifty6d
shifty6d is offline
PostPosted: Tue Aug 18, 2015 11:47 am    Post subject: Reply with quote
see below
shifty6d
shifty6d is offline
PostPosted: Tue Aug 18, 2015 11:49 am    Post subject: Reply with quote
Picture of flywheel for those interested :
Dale M.
Dale M. is offline
PostPosted: Tue Aug 18, 2015 12:11 pm    Post subject: Reply with quote
Yeah... Running starter was trying to engage flywheel of running motor...
Dale
shifty6d
shifty6d is offline
PostPosted: Tue Aug 18, 2015 12:27 pm    Post subject: Reply with quote
Sorry, but I'm going to disagree. If that pattern were all the way around the gear then yeah, classic pattern of starter trying to engage running engine, but that pattern is only on 1/4 of the teeth, all others look fine. I think this is the area somehow the starter bound up on the flywheel to ultimately stop the engine.
jason
jason is offline
PostPosted: Tue Aug 18, 2015 1:44 pm    Post subject: Reply with quote
That gear doesn't look too bad to me. Get a new gear installed. Cheaper than new flywheel and you don't have to mess with endplay.
