Mercedes rims on your bay, show me.
ballbag
ballbag is offline
PostPosted: Wed Aug 19, 2015 4:07 am    Post subject: Mercedes rims on your bay, show me. Reply with quote
Let's see some Mercedes wheels on your bays. I have a SRT and I'm unsure whether to use them.
What have YOU got?
I never learned that much at school, but i've taught ladies plenty!!
consvws
consvws is online now
PostPosted: Wed Aug 19, 2015 7:31 am    Post subject: Reply with quote
Red Fau Veh
Red Fau Veh is offline
PostPosted: Wed Aug 19, 2015 11:30 am    Post subject: Reply with quote
The cheap way out. Very Happy
1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote:
Swivel Seat panels are for people with no friends Crying or Very sad
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Wed Aug 19, 2015 12:52 pm    Post subject: Re: Mercedes rims on your bay, show me. Reply with quote
ballbag wrote:
HOLY CRAP
you have the best username on the samba
-Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI
consvws
PostPosted: Wed Aug 19, 2015 4:58 pm    Post subject: Reply with quote
yeah these hubcaps fit a small 5 bus wheel Cool this is an IRS rear end in the '60 panel
Clatter
Clatter is offline
PostPosted: Wed Aug 19, 2015 5:13 pm    Post subject: Reply with quote
5.5 Front 6.5 Rear
Bus Motor Build
What’s That Noise?!?
camit34
camit34 is offline
PostPosted: Wed Aug 19, 2015 11:48 pm    Post subject: Reply with quote
In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD)
Bansheelos
Bansheelos is offline
PostPosted: Thu Aug 20, 2015 12:40 am    Post subject: Reply with quote
Longer studs and spacers.
Just me and my Bus!
http://www.thesamba.com/vw/forum/viewtopic.php?t=540073
ballbag
ballbag is offline
PostPosted: Thu Aug 20, 2015 1:40 pm    Post subject: Re: Mercedes rims on your bay, show me. Reply with quote
secretsubmariner wrote:
ballbag wrote:
HOLY CRAP
Hahahahahahahahaha, cheers mucker. Very Happy
I've been called ballbag since I was about 15 Laughing I use it on all forums Smile
ballbag
ballbag is offline
PostPosted: Thu Aug 20, 2015 1:42 pm    Post subject: Reply with quote
These are what I have;
I'm still debating whether to fit them.
Clatter
Clatter is offline
PostPosted: Thu Aug 20, 2015 2:50 pm    Post subject: Reply with quote
FWIW, My $.02..
My adventure fitting the wheels in the pic above involved a wheel shop.
The Benz uses a smaller stud than the bus.
You can either use adaptor studs or, like i did, take the holes over in the wheels.
The wheels get chucked up in a rotary table and machined over on a mill.
Then, hard inserts are pressed into the wheel with a slight interference fit.
Plenty of people have used the step-studs, but, if you want to do it right, and run with a heavy load,
you are far better off in the long run doing these things correctly.
Step-studs are hoakey.
Again, My $.02...
Bus Motor Build
ballbag
ballbag is offline
PostPosted: Thu Aug 20, 2015 3:07 pm    Post subject: Reply with quote
Cheers mate, I'm only debating it as I got them cheap.
I haven't even tried them yet so, if it's a load of hassle I just won't bother Smile
my59
my59 is offline
PostPosted: Thu Aug 20, 2015 4:25 pm    Post subject: Reply with quote
There is a local bus with 80's benz rims on it. Looks fine but for the 3 pointed star on the centercap. Now if someone were to 3d print same caps with the VW symbol on them I would know just what to do with the light alloy rums from my 300cd....
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
NASkeet
NASkeet is offline
PostPosted: Mon Nov 02, 2015 9:26 am    Post subject: Mercedes wheels on a 1971~79 VW Type 2 Reply with quote
Some of the later model-years of Mercedes cars use M14 x 1·5 mm fixing studs or bolts for the 5 x 112 mm PCD wheels.
I am currently investigating 16 x 6 inch and 16 x 6½ inch Mercedes steel and aluminium-alloy wheels (e.g. 36~39 mm offset) for my 1973 VW "1600" Type 2 Westfalia Continental campervan, on which I would fit either 195/65 R16C or 205/65 R16C commercial-van tyres; these being common sizes these days and of an aspect ratio for greatest fuel economy, for a given external circumference.
I have also come across some 17 x 6½ inch Mercedes steel wheels (38 mm offset), on which one could mount some 215/65 R17C SUV tyres, that would be about 9% larger external circumference than 185/80 R14C van tyres, but I'm not sure whether there would be sufficient wheel-arch & suspension clearance.
http://www.oponeo.co.uk/steel-wheels/17
http://www.oponeo.co.uk/steel-wheel/alcar-kfz-9787#18876839
I have also recently seen, 215/60 R17C commercial-van tyres, on a brand new, 2015 registered, long-wheel-base Vauxhall Vivaro panel van.
Regards.
Nigel A. Skeet
http://www.vwt2oc.net
blacktruck
blacktruck is offline
PostPosted: Mon Nov 02, 2015 1:57 pm    Post subject: Reply with quote
that is a great use for that tech,bundt wheels are like gasburners for bays Laughing
don't get me wrong I will rock them if and when I can Cool
First
First is offline
PostPosted: Mon Nov 02, 2015 6:55 pm    Post subject: Reply with quote
NASkeet
NASkeet is offline
PostPosted: Tue Nov 03, 2015 8:56 am    Post subject: Mercedes wheels for 1971~79 VW Type 2s Reply with quote
Where possible, it might be useful for respondents to give details of:
Mercedes car models & model years to which these wheels were originally fitted;
Wheel size (i.e. diameter & width);
Wheel offset;
Original fixing bolt/stud hole size (e.g. 12 mm or 14 mm);
Original fixing bolt/stud seat type (e.g. hemispherical or conical seat with taper angle);
Tyre size;
Any problems encountered with fitting and/or using the specified wheel & tyre combination.
Regards.
Nigel A. Skeet
no1pony
no1pony is offline
PostPosted: Tue Nov 03, 2015 9:22 am    Post subject: Reply with quote
First wrote:
Man, That is a great look right there. Love that stance.
1966 Beetle Restoration almost done
1972 Ghia with the worst bumbers in the world.
78 Bay Window Project
NASkeet
NASkeet is offline
PostPosted: Tue Nov 03, 2015 9:35 am    Post subject: Mercedes wheels on a 1971~79 VW Type 2 Reply with quote
These are the Mercedes steel wheels and tyres, which Ralph & Lucas van den Houten (aka "Bursch" & "MadMax78") in The Netherlands, retro-fitted to their 1978 VW 2000 Type 2 ASI Riviera campervan, for their overland trek to Capetown, South Africa.
6.5Jx15 ET37 5x112 Mercedes wheels with Continental Cross Contact AT 225/70 R15 tyres. Barely fits, only rubs sway bar in front.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=649629
http://www.thesamba.com/vw/forum/album_page.php?pic_id=649630
The front suspension anti-roll bar, looks as though it is of the uprated variety, but I'm surprised it wasn't angled differently to give greater tyre clearance!
Regards.
Nigel A. Skeet
NASkeet
NASkeet is offline
PostPosted: Tue Jan 02, 2018 9:47 am    Post subject: Re: Mercedes rims on your bay, show me. Reply with quote
I finally got around to purchasing a set of four Mercedes 7J x 16 inch wheels [37 mm offset] of the following five double-spoke style, for my 1973 VW "1600" Type 2 Westfalia Continental campervan; originating from a 2002/03 Mercedes C-Class:
At a total cost of £80 + shipping, they were reasonably cheap, but whether I can find another two spares as cheaply, remains to be seen.
They are presently fitted with 205/55 R16 91V tyres, but I intend to substitute either 205/65 R16C or 215/65 R16C light-truck tyres, which are readily available here at competitive prices.
Regards.
Nigel A. Skeet
