Trav'ler Stove questions
Schwing
Schwing is offline
PostPosted: Mon Aug 07, 2017 7:36 pm    Post subject: Trav'ler Stove questions Reply with quote
Hey guys I recently picked up an original Westy Trav'ler stove for my 72 that was not equipped with one from the factory. My original sink was missing so I decided to modify it so I could install this stove/fridge combo. Plan is to make this unit removable since I have a family of four.
Has anyone ever hooked up their stove to a 1lb green bottle? If so, do I need a regulator or just a simple adaptor?
Thanks guys. Oh and some pics.
Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
williamM
williamM is offline
PostPosted: Mon Aug 07, 2017 7:47 pm    Post subject: Re: Trav'ler Stove questions Reply with quote
you will need a regulator
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
otiswesty
otiswesty is offline
PostPosted: Mon Aug 07, 2017 9:05 pm    Post subject: Re: Trav'ler Stove questions Reply with quote
The first time you turn it on without a regular is very interesting. Ask me how I know. Shocked
If you have any supply house with a fitting and regulator for the 1# bottle, you can get the threaded adaptor to the stove at Ace hardware that has a barbed house fitting.
1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy
Schwing
Schwing is offline
PostPosted: Tue Aug 08, 2017 3:30 am    Post subject: Re: Trav'ler Stove questions Reply with quote
Ok thanks for the advice fellas. I will try to run to the depot today to see what I can find, and update what I figure out here.
Shadetree Westy
vwwestyman
vwwestyman is offline
PostPosted: Tue Aug 08, 2017 6:09 am    Post subject: Re: Trav'ler Stove questions Reply with quote
You'll have better luck at a place like Ace Hardware (or other locally owned hardware store) than Home Depot finding what you need, and a much better chance finding someone working there who can help you put together the kit you need to hook up your small cylinder safely.
You'll need a regulator for the small bottle, hose from the regulator to the flexible metal line I see there, and an adapter connector between the two.
If possible, if I were you, I would see if you can remove the flexible metal line and hook up your new rubber line directly to where the metal line connected.
Dave Cook
1973 Wild Westerner
My Thing
danfromsyr
danfromsyr is offline
PostPosted: Tue Aug 08, 2017 7:21 am    Post subject: Re: Trav'ler Stove questions Reply with quote
farm & fleet or Tractor supply often has a nice propane fitting rack.
you need one of these threaded into a propane BBQ regulator/hose assembly
it will replace the plastic tank adapter, it can be tough to remove, the inside of the plastic will accept a socket, the outside of the regulator will accept a crescent wrench. unscrew the old and screw on the new. USE THREAD SEALANT.
and ditch the metal corrugated line.
the fitting on the stove is 3/8 flare
Abscate wrote:
Abscate
Abscate is offline
PostPosted: Tue Aug 08, 2017 7:25 am    Post subject: Re: Trav'ler Stove questions Reply with quote
Define "need" - do you mean if you wish to continue living?
Good on OP for researching this first.
.ssS!
williamM
williamM is offline
PostPosted: Fri Aug 11, 2017 2:04 pm    Post subject: Re: Trav'ler Stove questions Reply with quote
I always encourage independent thought and the chance to "Learn by doing"-- or not doing-- We studied Darwin in high school.
Don't step in any!
busdaddy
busdaddy is offline
PostPosted: Fri Aug 11, 2017 4:30 pm    Post subject: Re: Trav'ler Stove questions Reply with quote
Eyebrows are over rated, who needs them? Wink
Слава Україні!
williamM
williamM is offline
PostPosted: Sat Aug 12, 2017 6:05 am    Post subject: Re: Trav'ler Stove questions Reply with quote
Shocked Shocked Shocked Shocked Shocked Very Happy Does Blazecut make a hat???- like birthday party balloons
Don't step in any!
