Jalabert Samba Member
Joined: December 06, 2005 Posts: 631 Location: On the coast in NZ, somewhere...
Posted: Mon Aug 24, 2015 1:15 pm Post subject: Empi hex bar needle bearings... |
I know Empi get a lot of shit on here, and sometimes deservedly so....
I just emailed empi in the us to find out about replacing bushes on my 34ict linkage - got a reply back almost instantly with the part number I needed and also a suggestion to look at a needle bearing conversion kit - this one...
http://www.dansperformanceparts.com/empi-44-1127-hex-bar-linkage-needle-bearing-conversion-kit.html
1st off, props to empi for the customer service, and second - has anyone installed one of these? I think it might make a fair to middling linkage kit a lot better...it would certainly address one of the weaknesses with the kit - the means of securing the throttle cable being the other major.
Cheers,
Simon _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
'73 westy, 1700 type 4 with 34icts |
Tcash Samba Member
Posted: Mon Aug 24, 2015 1:28 pm Post subject: |
Have not used to needle bearing kit.
For the cable end.
Tcash wrote: |
For future reference. Cut the cable with a cable cutter, or tape the cable tight with electrical tape and cut with a 32 fine tooth hacksaw.
Solder the end and install it in the throttle cable end or extension. The one with the screw in it.
Wire cutter
Good Day
Tcash |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7549 Location: Santa Cruz
Posted: Mon Aug 24, 2015 1:32 pm Post subject: |
Anyone know if that roller kit would work with the CB linkage? _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Mon Aug 24, 2015 1:40 pm Post subject: |
Tcash wrote: |
For the cable end.
Tcash wrote: |
Wire cutter
Good Day
Tcash |
Yep, that's roughly what I do, but I still think it's a little shit. If you take a look at a decent bike derailleur they have a much better cable clamping system that means you don't have to cut the cable first. I'm thinking of hanging something like that - a notched square washer clamped by another washer - into the grub screw hole and seeing how that flies. You can then cut the cable end and put a nice crimp on it - no chance of an unravelled cable or cable fibres shredded by the grub screw...
Tcash Samba Member
Posted: Mon Aug 24, 2015 2:02 pm Post subject: |
stainless and shiny! _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
Brian Samba Moderator
Posted: Mon Aug 24, 2015 10:12 pm Post subject: |
Clatter wrote: |
Anyone know if that roller kit would work with the CB linkage? |
More than likely. HPMX Deluxe kits are full blown Weber IDF clones. Not Knock-offs, clones. I can see why you'd need them for longevity after your lubed nylon bushings wear out after 50k+ miles. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Tue Aug 25, 2015 12:04 pm Post subject: |
Not being a smart arse - genuine question. I thought nylon was self lubricating?
The cup size and threads in the bar ends for the CB performance linkage would have to be the same as for the empi one - don't know if that's the case? _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
Posted: Tue Aug 25, 2015 12:12 pm Post subject: |
When I got mine, it came with some grease to put in the cups.
Good question on the threads. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Tue Aug 25, 2015 12:20 pm Post subject: |
Been so long since mine went in I've forgotten... I think I'm up to about 35-40k on them, something like that. There's been a bit of lateral play in one side for a while and the cup's worn through - not sure if this has been accelerated after I double-sprung the return arms, but there's certainly more tension on the linkage than stock... _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
Posted: Tue Aug 25, 2015 12:22 pm Post subject: |
Lateral should be adjustable is it not? I haven't seen a CB bar in person. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Tue Aug 25, 2015 12:28 pm Post subject: |
Sorry - I should be clearer - fore and aft movement within the cup on one side where the cup's been wearing through. _________________ http://thickrubber.blogspot.com/ Writing, Surfing, and Exploring NZ's deep south by VW...
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Tue Feb 13, 2018 6:36 pm Post subject: Re: Empi hex bar needle bearings... |
The EMPI book says their linkage kits with the needle bearings fit Weber, Dellorto. I’d just get the whole kit. I just did a quick search and the whole kit is only $30 bucks more than just the needle bearing kit. |
