shifty6d Samba Member
Posted: Mon Aug 24, 2015 7:09 pm Post subject: What did I just buy?? |
Picked up a pile of VW parts yesterday. I was mainly interested in the exhaust and a pair of carbs in the lot, but it was one of those all or nothing deals. Anyway, it came with a long block that I'm trying to figure out, I just split the case and the crank is counterbalanced and 8 pinned but I don't know what the markings mean or the rods are, the case halves and rod ends have been clearanced so I'm assuming it's restroked.
I get that it's machined .020 but a 76 stroke, or?
Thanks for any help/input. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Mon Aug 24, 2015 7:22 pm Post subject: |
76mm stroke, reground .020 under mains with Rabbit rods, it was an old school way of creating a stroker cheaply _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Mon Aug 24, 2015 7:24 pm Post subject: |
I think it is a rabbit rod 76mm crank. Turned out to be not such a good idea. They tended to pound out the center main in short order. The crank also tended to crack and break.
Remove a rod and mic the journal to confirm. Shoud be in the 1.800 range. |
Posted: Mon Aug 24, 2015 8:03 pm Post subject: |
So it was a bad stroke length then? I thought 76mm didn't sound familiar. |
GTV Samba Member
Posted: Mon Aug 24, 2015 8:06 pm Post subject: |
shifty6d wrote: |
The problem is the tiny rod journals. _________________ EMPI Power Rules! |
Posted: Mon Aug 24, 2015 8:09 pm Post subject: |
The stroke length was not the problem but the small rod journal cut out most of the cranks overlap between the rod and main journal weakening the crank.
Limit it to 5k rpm if you want to use it and make sure it is not cracked.
Dan |
modok Samba Member
Posted: Mon Aug 24, 2015 8:19 pm Post subject: |
Wow, you guys are sharp!
yeah, rabbit rods. |
Posted: Mon Aug 24, 2015 8:48 pm Post subject: |
The case looks cut for bigger barrels too and it's Brazillian (single relief). Isn't starting to sound like a good choice for a builder.
These heads were in the deal too:
Oops upside down, sorry
The diameter of the head machining doesn't match the machined diameter of the case though. |
modok Samba Member
Posted: Mon Aug 24, 2015 10:39 pm Post subject: |
looks like eepco heads, cut for 94's
Really made in USA, unfortunately, there isn't anything particularly good about them. |
Howard 111 Samba Member
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Tue Aug 25, 2015 2:52 am Post subject: |
The heads look semi-hemi'd, too. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Tue Aug 25, 2015 4:48 am Post subject: |
It would make a good engine for a play Buggy or sandrail to goof around in. Put it all together cheaply as possible and keep it under 5000 RPM's and it will last a while playing in the sand. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Tue Aug 25, 2015 4:50 am Post subject: |
good for your boat as well |
Posted: Tue Aug 25, 2015 11:05 am Post subject: |
Thanks for the replies, I'm gonna end up passing these along. The exhaust and the Dellortos were was I was really after in the deal like I said. They're too much carb for the engine I just built and was hoping these items were a good start on a bigger one, oh well. |
