Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Oct 28, 2015 8:20 pm Post subject: My soon to be new 1970 vw transporter (restoration) |
It's been a little bit. I got some little things cleaned up. Patched up behind the passenger door. We build the B-pillar? The pillar between the passenger door and the sliding door. And put in a patch where the rear seat belt attaches on the drivers side. Here is a few thousand other words for you.
VWRESTOMODMAN Samba Member
Joined: January 17, 2014 Posts: 75 Location: California
Posted: Wed Oct 28, 2015 9:43 pm Post subject: |
Looks like every time you removed paint you got a big surprise which lead to more work. I think at this stage you are close to uncovering all the surprises. |
Posted: Thu Oct 29, 2015 5:57 am Post subject: My soon to be new 1970 vw transporter (restoration) |
VWRESTOMODMAN wrote: |
Yup... This started as I'm just gonna reinforce the middle section with some beams... Lol I hope I don't run into many more surprises, because my patience is starting to run low. |
Posted: Thu Oct 29, 2015 7:47 am Post subject: |
Well hang in there, as I always say to myself when I'm undertaking a big restoration challenge "it's all down hill from here". Here' s a few photos of one of my current projects to help keep you motivated, a '71 sport deluxe almost ready for paint. I even went so far as to media blast and powder coat the entire underside, engine bay, cargo area, and front cab. I had to replace a lot of sheet metal on this bus as well, the entire nose skin, front floor, cargo floors, slider track, and both rear corners half way up. So hang in there, it will be worth it in the end!
Last edited by VWRESTOMODMAN on Thu Oct 29, 2015 8:16 am; edited 1 time in total |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 776 Location: Milwaukee
Posted: Thu Oct 29, 2015 8:11 am Post subject: |
Do you have a very large oven? How do you powder coat the whole floor pan? _________________ 70 Sunroof Kombi
69 Tin Top
73 Thing
72 Baja |
Posted: Thu Oct 29, 2015 8:21 am Post subject: |
After I media blasted the entire thing I took it to a local powder coater who has a very large oven. After powder coating I stripped all the remaining original exterior paint to bare metal, then epoxy sealed the metal and primed it. |
Posted: Thu Oct 29, 2015 8:22 am Post subject: |
Posted: Thu Oct 29, 2015 11:46 am Post subject: Thank you |
Well hang in there, as I always say to myself when I'm undertaking a big restoration challenge "it's all down hill from here". Here' s a few photos of one of my current projects to help keep you motivated, a '71 sport deluxe almost ready for paint. I even went so far as to media blast and powder coat the entire underside, engine bay, cargo area, and front cab. I had to replace a lot of sheet metal on this bus as well, the entire nose skin, front floor, cargo floors, slider track, and both rear corners half way up. So hang in there, it will be worth it in the end! |
Thanks, I know it will be. This is my first ever restoration and it's taking a lot longer than I hoped. like I said, I didn't actually buy this expecting a restoration. Lol. But at least I only have to do tuning and gauge installation for the engine. And I may or may not put disc brakes up front.
Also my buddy helping me keeps losing focus that this is a daily driver build not a show queen. It's gonna be a little rough on the edges, and there will be quirks about it (the engine tin for example). But it'll work awesome when I'm done... Eventually. |
Posted: Thu Oct 29, 2015 11:57 am Post subject: Dogleg supplier |
Btw, did you replace your dogleg? If so where did you get yours? And was it any good? |
Posted: Thu Oct 29, 2015 2:50 pm Post subject: |
I did not have to replace my dog legs, they were in good shape. Klassic fab is most likely your best source. |
wcfvw69 Samba Purist
Posted: Thu Oct 29, 2015 8:08 pm Post subject: |
Wow.. I've never seen such large areas of a bus powder coated. That's awesome. Walk me thru this some more. The powder coat place blasted those areas with sand/media, then wiped it all down before applying the powder? They then baked it in a obviously large oven. What temp did they bake the powder at? I thought it was over 300 degrees?
Last question, with no filler or other things to hide imperfections in the metal, how does it look up close? _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Oct 29, 2015 8:30 pm Post subject: |
Hi Bill, first I burned all the undercoating off the underside, then I media blasted the metal. After that I blew off all the left over junk and took it to the powdercoater. They coated it and cooked it off at 400 degrees for 20 min, then a heat soak @350 for 45 min. It is awsome, I've done several like this. The finish is perfect, glossy and bullet proof. |
Posted: Thu Oct 29, 2015 8:36 pm Post subject: Cost |
Code: |
I don't think we have anyone around here doing that not on a non business level. But how much did that cost you? Is powder coating in general pretty costly? |
Posted: Thu Oct 29, 2015 8:47 pm Post subject: |
I am lucky in that I have a facility near me that caters to industrial sized items with a large oven. The.cost runs $800 to apply the powder and bake it. |
Posted: Thu Oct 29, 2015 9:26 pm Post subject: |
I bet it will be bullet proof. I didn't think that sheet metal could take those temperatures w/out warping or deforming. It also sounds like you had to totally remove all the seam sealer as well. _________________ Contact me at [email protected]
Posted: Thu Oct 29, 2015 9:53 pm Post subject: |
The key to avoiding the metal deforming like potato chips is to control the heat ramp rate slowly, and then after curing just turn the oven off and let it cool back to ambient over night. Yes, when I burned off the undercoating most of the seam sealer went with it witch is what you want otherwise you will end up with a big mess afterwards. I mask and reapply OEM style undercoating and seam sealer in selected areas in the wheel wells to protect it from road grime and rocks. |
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Sun Nov 08, 2015 7:59 pm Post subject: My soon to be new 1970 vw transporter (restoration) |
Sooo, this weekend my buddy helped me fit the passenger dogleg and we welded it mostly up. It still needs to be finalized and a couple small patches put in place. But that happens tomorrow, when I'll have more pictures as well! The time of metal work is coming to and end! Woohoo!!!
Also the other night, I think Friday, I patched up the passenger side rear wheel well. I'll have pictures of that tomorrow too.
Here is the dogleg in!
Posted: Tue Nov 10, 2015 7:18 am Post subject: Short night |
I did some welding up of the dogleg last night. I didn't finish the front connection yet. (It doesn't quite reach so patches, yes more of them, will be necessary.) Btw, I think the name of this bus is gonna be patches, at least a nickname. Anyways here are a few more pictures.
And a few of the bus as it stands currently.
Posted: Mon Nov 16, 2015 2:18 pm Post subject: Center floor supports |
I welded up the three center floor supports this weekend. I can carry just about anything that'll fit in my van assuming I can spread out the weight well.
not a great picture, but it's what I have atm.
