Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Jan 16, 2019 4:38 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
oh wow, I wasn't even looking at that. Good catch busdaddy, thanks. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Ry-dog Samba Member
Joined: May 31, 2003 Posts: 452 Location: Lunenburg, MA
Posted: Wed Jan 16, 2019 6:50 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Here is a good photo of a mexican doghouse fan shroud at the interface with the oil cooler. Note the area where the sheet metal is very close to/touching the side of the oil cooler (that is the section of the hoover bit that gets cut off). The other area where you see the two bolt/nuts (for attaching to the adapter) is where I saw a need for the 'partial' hoover bit.
_________________ '70 Westy
'14 Jeep Grand Cherokee EcoDiesel |
Posted: Wed Jan 16, 2019 6:59 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
I just checked and I don't think I have a Mexican doghouse fan shroud. Too bad. Although I cant find the part number or any stamping on my fan shroud. Though it does appear to be a repaint. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Ry-dog Samba Member
Posted: Wed Jan 16, 2019 7:01 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
My mexican fan shroud did not have any stampings. Only a VW decal that stated it was 'Made in Mexico'. _________________ '70 Westy
Posted: Mon Jan 28, 2019 7:53 am Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Welp, I had a little more time this weekend to work on Brutis.
Findings:
1: Oil cooler mount bolts were loose, and seals were covered in oil. I cleaned and tightened those up with some loc-tite. Hopefully this time they stay nice and tight.
2: I cleaned stuff up... took a while... still plenty of that to do.
3: Pulled plugs and found #3 was running lean, # 4 was a little rich, and 1-2 were looking maybe a smidge lean, but even and I'm pretty happy with those.
#1 is closest (right side of photo), # 4 is furthest (left side of photo)
Posted: Sun Feb 24, 2019 7:56 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
I got some time to work this weekend. First thing, I got a full Hoover but installed. I did need one. So asiab3, thank you. And my fan was messed up. I got a new one of those too. I opened up my alternator because I had to get my pulley off and I noticed it wasn't spinning freely, I found my bearing destroyed! Half the bearings were in about half with flat spots all over and the others were missing. I'll post a picture of that later this week if I can get a good picture. So my current theory is that the alternator bearing failed, seized, them the fan belt ripped up and gave in. So I also got another alternator. And the lesson learned here is that cheap alternators suck. Dont buy them. Lol
I'm also replacing the oil line to my oil filter with the proper line, which I recently found out was fuel vapor line
A picture of the Hoover bit:
Posted: Tue Feb 26, 2019 6:38 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
A picture of just how many bearings were toasted. About half were missing, and you can see the remnants of a bearing there and two of the bearings have completely flat spots of them.
(The rust is flash rust from sitting outside the last couple nights. Although that bearing was dry come to think of it... probably why it failed... hmm)
Posted: Sun Mar 31, 2019 4:29 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Progress was made today. I got my carbs put back on (I didnt get to upgrade the linkage in any way like I wanted to), fuel lines hooked up, valves adjusted (cycle exhaust was a little tight after losing the belt but nothing major), thermostat adjusted and reinstalled, lower cylinder tins reinstalled, front tin reinstalled and cover plates "fabricated" and installed, and installed and adjusted the fan belt. The only thing left to do outside of putting it back in the van is the rear main seal.
Pictures of the front "fabricated" tin plates. They're pretty emberrasingly bad. But they'll keep the air out.
Oh and It was pointed out to me that one of my oil oines was a fuel vapor line, so that got replaced. The lower oil line there is the new one.
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sun Mar 31, 2019 4:36 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Looking good!
That alternator bearing is amazing; I’m surprised it even rotated!
www.airschooled.com |
Posted: Sun Mar 31, 2019 7:02 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
asiab3 wrote: |
Looking good!
Robbie |
I think there was another bearing in there before i removed it or something because once it was out it was getting stuck all the time. I'm amazed it didnt seize together and just stop. But I'm glad it didnt, because she got me the 20 miles home! They will give their life! _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Mon Apr 08, 2019 7:18 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Its finally getting warm! And my engine is still on the floor! Its killing me. But the last weekend in April this thing will be all system go.
In the mean time, jack_o_trades hooked me up with the rear hatch torsion bar isolators. They're good quality. Seems to be very similar rubber, though my old one was pretty rock hard. He was very timely, with good communication as well. I believe he is selling them now. But here are some pictures.
The new ones:
And the old one(s) lol
dont act like you're not impressed.
Posted: Thu May 02, 2019 8:10 am Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Update time. Last weekend I had some time to get stuff done. Wheelie Pete came over and lend a hand as well. We popped off the flywheel to inspect for oil leaks and found that gallery plug was flopping around loose like a flag in the wind. So we drained the oil, used a torch to clean up the residual oil, cleaned up the face of the case and everything else around. And applied some high heat gasket maker goop to stop the leak. The jury is still out on if this fixed the leak coming from behind the flywheel.
Next we slapped the engine back in. Went it smooth, took about an hour or two to get it lined up, and get all the obnoxious bolts that I cant really reach behind the fan shroud. Plumbed it all up, and waited for the gasket maker to cure. So 48hrs later (12-24 was recommended, but its a little cold and my wife had the key. So I waited.) I went to start it up. … and again... and again... no luck. I've got no boom boom boom boom (one "boom" per cylinder). I did a very small amount of investigating. I checked for spark at the coil. Check. I checked for a crimped fuel line, looks alright. So I'm waiting to do more investigating when I get time and hopefully a helping hand to crank the engine with the key.
And obviously I had to add this crappy nighttime phone picture to prove it is indeed in the van.
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Sat May 04, 2019 2:11 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Might just need more cranking to get fuel built up again. Did you use Stabil over the winter? Fuel coming out of the accel. pump?
Mine started up nicely today after a few cranks. Yahoo! _________________ '71 Westy |
Posted: Tue May 07, 2019 7:47 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
ccpalmer wrote: |
Mine started up nicely today after a few cranks. Yahoo! |
I had cranked for a couple minutes straight. No luck. But it was just no gas. Threw some gas down the carbs and blead the system a little with the help of wheelie Pete and she fired right up. The improvements to the exhaust system helped a lot. She sounds nice. So after a new house clamp on my high pressure oil line to my filter, I was all set to go. We went for a drive down lake shore and she even started to idle alright (500rpm, but not fully warmed up). All with 7 month old gas. What a champ.
To do:
Put bumper back on
Wash
Clean out my tools from inside the van
Drive
Take a picture or two
I'll be at the vintage Volkswagen festival in ypsilanti this year on may 19th. I hope to see some of you out there. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Wed May 08, 2019 1:24 pm Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Spike0180 wrote: |
Threw some gas down the carbs and blead the system a little with the help of wheelie Pete and she fired right up. |
Spike0180 wrote: |
I'll be at the vintage Volkswagen festival in ypsilanti this year on may 19th. I hope to see some of you out there. |
I'm hoping to make it this year.. _________________ '71 Westy |
Posted: Mon May 13, 2019 6:29 am Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Spike0180 wrote: |
To do:
Put bumper back on
Wash
Drive
Completed this weekend:
Put bumper back on
"wash" (this was a very lazy wash that was basically a wipe off of the lower half)
I drove and put new fuel in.
And I picked up the back of the bus some.
In all: a lot of half assed jobs.
I did find that the idle didn't really improve, so I adjusted it and it still isnt quite right. So I sprayed the base of the intake where it meets the heads with some break cleaner and it sounded like a hit that thing with a shot of Nitro! lol So I might (aka 100% sure I do) have an intake leak. I'll get that fixed hopefully tonight, if not by Thursday. I still need to sign up for the ypsi car show. My van isn't really a car show kinda van, but whatever. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Mon May 13, 2019 8:07 am Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Every car is a show car if you’re proud of it! Especially since you’ve done so much work yourself!! _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Thu May 16, 2019 7:15 am Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
asiab3 wrote: |
Every car is a show car if you’re proud of it! Especially since you’ve done so much work yourself!! |
Aw shucks.
In other news! ... I have an intake leak. I believe it is coming from the metal gasket between the intake and the head. I tried about 4-5 times last night to get it to seal up without luck. So I called up Wheelie Pete and asked him for a gasket. I'm picking it up tonight after work. And after all my practice last night, I should have it in and ready for testing in about 5 minutes lol
If the gasket doesn't fix it, does anyone have any suggestions on what else would be causing this vacuum leak? My engine revs when I spray brake cleaner between the intake and cylinder tin, or if I spray behind the carb from the top. Not as much from the outside of the carb or the front. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
advCo Samba Member
Joined: May 27, 2017 Posts: 373 Location: Houston, TX
Posted: Thu May 16, 2019 10:07 am Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Spike0180 wrote: |
Cool, we're moving to Chicago this fall, hopefully the bus will be ready to make the trip next year _________________ "He pulled the mirrors off his Cadillac ‘cause he doesn’t like it looking like he looks back"
'68/'70 Ghia Coupe Project
'70 Westy Project - Champagne I Wannabe
A bunch of vintage Japanese motorcycles
"Much ingenuity with a little money is vastly more profitable and amusing than much money without ingenuity." -A. Bennett |
Posted: Thu May 16, 2019 10:26 am Post subject: Re: My soon to be new 1970 vw transporter (restoration) |
Spike0180 wrote: |
If the gasket doesn't fix it, does anyone have any suggestions on what else would be causing this vacuum leak? My engine revs when I spray brake cleaner between the intake and cylinder tin, or if I spray behind the carb from the top. Not as much from the outside of the carb or the front. |
Ahh, the hidden wonders of dual carbs.
New metal gaskets each time are usually necessary for manifold removal. The ridge around the perimeter crushes on first installation. I hate trying to get paper gaskets off the heads, usually they leave sticky bits behind. The metal gaskets DO require clean and flat surfaces. You can check the manifold base on a truly flat surface for light leaks, but the head is trickier to test. I've seen some aftermarket manifolds perfectly flat and some that required lapping with 200-400-600 grit plates.
Good luck!
