surfbus23 Samba Member
Posted: Thu Sep 05, 2019 10:31 am Post subject: High Oil Pressure |
Hi all,
Vehicle is a 79 bay bus with 2.0L and dual weber 40IDF carbs. I'm driving it to South America. The other day I was trying to go up the side of a mountain that I shouldn't have been. Well... that I couldn't.
I pushed it a bit. I.e. I was stuck on a 4x4 one-lane (maybe 20 degree incline) and a time or two I stalled out. I had to feather the clutch to get enough RPMs to get out of where I was. I did this a few times and started smelling something that I could best say smelled like a dead animal. I stopped and opened up the engine lid and there was smoke coming up from the front of the engine. I didn't see any oil burning. I was thinking maybe I was burning the clutch? I have oil temp, CHT and pressure sensors and nothing got crazy. At this time I was able to park the car and since I still wanted to go up I walked. The next day I was leaving and checked the oil and it was good.
Before this oil pressure at idle was right around 10psi when warm and now the oil pressure is around 20psi at warm idle. Any thoughts on what I may have done here. I think there is still a smell of a dead rodent. It's a bit challenging to say for sure. I'll get a better sense today, but I don't have Internet so I'm at a cafe and just typing what I know for sure.
Other than the idle PSI and maybe the smell (I thought I smelled it this morning but I didn't double check when I stopped because I was tired and hungry) it's running just fine and all the sensors above are fine.
Should I be concerned?
Thanks!
K
P.S. If anyone is interested in following the trip I'm on IG @outintonowhere
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Thu Sep 05, 2019 10:51 am Post subject: Re: High Oil Pressure |
A 20° incline.....did you lose oil pressure? For sure it sounds like some clutch burn. That is tbe dead rodent smell.
Ray |
Posted: Thu Sep 05, 2019 11:00 am Post subject: Re: High Oil Pressure |
raygreenwood wrote: |
Ray |
Ok. That's kind of what I was thinking with the smell. I suppose maybe it was still residual the next day because the clutch was in fact burnt.
Did not lose oil pressure. Neither the idiot light nor my warning light for my sensor came on. It was mostly just the smell that got me to stop... and that the "road" kept getting steeper and rougher. Or maybe it was the local driving by in the Jeep that couldn't recommend I attempt it in a kombi. |
SGKent Samba Member
Posted: Thu Sep 05, 2019 11:44 am Post subject: Re: High Oil Pressure |
don't do that sh_t. Late bus flywheels are cast, not forged, they glaze easy and you WILL destroy that clutch and pressure plate. It was not meant to be slipped like that. It can be a long walk or tow home if you rip the facing off the clutch disc. Most offroad vehicles have a transfer case and a compound low to avoid what you did in your bus. Make sure you still have the correct freeplay after that stunt. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Sep 05, 2019 12:00 pm Post subject: Re: High Oil Pressure |
SGKent wrote: |
don't do that sh_t. Late bus flywheels are cast, not forged, they glaze easy and you WILL destroy that clutch and pressure plate. It was not meant to be slipped like that. It can be a long walk or tow home if you rip the facing off the clutch disc. Most offroad vehicles have a transfer case and a compound low to avoid what you did in your bus. Make sure you still have the correct freeplay after that stunt. |
Yes. I won't do this anymore. To check the freeplay you'd have to drop the engine yes? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16926 Location: San Diego, California
Posted: Thu Sep 05, 2019 1:22 pm Post subject: Re: High Oil Pressure |
No, it’s how far down you push the clutch pedal before you feel resistance. You want about 3/4 inch of free play. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Thu Sep 05, 2019 1:41 pm Post subject: Re: High Oil Pressure |
On a steep incline with a side tilt you may have had some oil sucked down the valve guides. If this happens your engine will smoke like crazy out the exhaust. Oil could possible get by the rings in mass as well when the engine is at an extreme angle. |
SGKent Samba Member
Posted: Thu Sep 05, 2019 4:55 pm Post subject: Re: High Oil Pressure |
surfbus23 wrote: |
SGKent wrote: |
What Gary said. Here is a video on how to check it.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Sep 05, 2019 5:06 pm Post subject: Re: High Oil Pressure |
"Dead animal", yeah, I've never heard that description of the smell, but it's plausible for an untrained nose to link burning clutch or brake to that (depending on the animal you smelled).
Check that free play as already mentioned, but I'd be really laying awake at night if I didn't drop the engine and put in a fresh disc at the very least before heading off on a trip like you propose. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Sep 10, 2019 11:39 am Post subject: Re: High Oil Pressure |
Thanks all for the replies! Just got back to Internet.
Oil pressure was a false alarm on my part and is actually working fine. Everything is shifting fine and no slipping or anything and went from 0 - 8k feet and back down so seems to be ok. Everything there was brand new and put in a few thousand miles ago.
Still have some residual smell though. I'm taking a little road break so I'll have to try and be more diligent about figuring out what it is. Can't figure out what it is. Thanks for the free play video. I'll check when I get back to the bus. |
Posted: Tue Sep 10, 2019 11:44 am Post subject: Re: High Oil Pressure |
The smell is probably a burned clutch. I think it will fix itself _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue Sep 10, 2019 11:51 am Post subject: Re: High Oil Pressure |
aeromech wrote: |
The smell is probably a burned clutch. I think it will fix itself |
Word. It does seem that way. Always hard to tell on these subjective things but it does seem "less". It's still a bit nauseating if I open up the heater vents but not like it was.
I won't try and jam it straight up any more crazy mountainsides. |
Posted: Tue Sep 10, 2019 12:25 pm Post subject: Re: High Oil Pressure |
Maybe you got your heater ducts hot enough to burn some of the mouse turds buried in there, if not fry a dead mouse. Real mouse smells don't clear up all the readily. |
Posted: Tue Sep 10, 2019 12:26 pm Post subject: Re: High Oil Pressure |
Wildthings wrote: |
Hahaha. I hope not! It would have to be a new mouse as I redid those too before I left. |
