vwfye Samba Member
Posted: Wed Aug 26, 2015 12:49 pm Post subject: Type 3 fans and belt |
Anyone know how much hp they bleed vs how much the stock t1 fan and belt bleed? _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
KTPhil Samba Member
Posted: Wed Aug 26, 2015 1:05 pm Post subject: |
I can't quantify it but the belt is very lightly loaded on the Type 3 design, since it is only running the generator, not the fan. |
vwfye Samba Member
Posted: Wed Aug 26, 2015 1:13 pm Post subject: |
I figured the swing of the T3 fan also draws vs the T1 though... _________________ 64 No'back Speedster "Pearl"
KTPhil Samba Member
Posted: Wed Aug 26, 2015 1:24 pm Post subject: |
Type 3 fan probably takes a little more hp because it flows far more air. |
Yabbadubbadoo Samba Member
Posted: Wed Aug 26, 2015 10:10 pm Post subject: |
Type 3 fan rpm ratio is 1:1 with engine speed but the Type 1 spins the fan faster than engine rpm. That's gotta mean something in favor of the Type 3 don't you think?.
An engine builder reminded me of that when I was discussing welding the blades of the Type 3 fan. He said he's never done it to a type 3 because they don't spin as fast as a type 1 fan. I don't know how much merit there is to that observation but I'm sure he would have told me to weld it up if he'd spun the blades off a type 3 fan down the drag strip which he regularly build motors for. _________________ Sydney, Australia.
66 Type 3 Fastback |
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 479 Location: Australia
Posted: Wed Aug 26, 2015 11:15 pm Post subject: |
You have to remember that the Type 3 fan has a lot larger diameter, so the peripheral speed may in fact be as high as those attained on a Type 1 fan. |
daos Samba Member
Joined: January 01, 2017 Posts: 309 Location: Stockholm, SWE
Posted: Wed Nov 24, 2021 4:03 am Post subject: Re: Type 3 fans and belt |
don't forget the type 3 is driving two fans, not just one. outer fan draws air in (and runs the generator), inner fan pushes it out for engine cooling. |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Wed Nov 24, 2021 7:56 am Post subject: Re: Type 3 fans and belt |
daos wrote: |
lots of threads on this, technically it doesn't act as a fan, to not interupt flow and the draw from the main fain you can think of the outer fans blades as mainly directional vanes... it does not aid in flow other than minimizing obstruction. dont have a lot of time this morning otherwise i would grab some of those threads
I hope I didnt come across as snotty... that was not my intent. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
daos Samba Member
Posted: Wed Nov 24, 2021 10:56 am Post subject: Re: Type 3 fans and belt |
VWporscheGT3 wrote: |
daos wrote: |
you didn't.
however - the primary fan is basically a propeller, the blades are angled in order to draw air in. so it is doing work, it's drawing in air and air has mass, the fan has to move that mass. that equals load and has a parasitic effect, there's no way it's doing no work, otherwise it wouldn't be there. there is no need for it to direct air immediately in front of the second fan, that makes no sense. the air is 'directed' by the path it has to take - and it only has one possible path.
the second fan has vanes which move the air outward, i'd say it is not doing the main work of pulling the air in. naturally, it also uses a certain amount of power.
thanks for the tip about the threads, i'll look them up. didn't realise there were any. although - of course there are, there are threads on pretty much everything here.
daos Samba Member
Erik G wrote: |
6 year old thread! |
not any more |
Posted: Wed Nov 24, 2021 11:01 am Post subject: Re: Type 3 fans and belt |
daos wrote: |
daos wrote: |
you didn't.
the second fan has vanes (more like an impeller) which move the air outward, it is not doing the main work of pulling the air in. naturally, it also uses a certain amount of power.
thanks for the tip about the threads, i'll look them up. didn't realise there were any. although - of course there are, there are threads on pretty much everything here. |
I see your logic , but, if the main fan is drawing more air volume than the little fan can produce it negates the work load of the pulley "Fan" and then will only act as a ..for lack of a better term , a director of flow. which is the way it was explained in one of those threads..I will have to see if i can find that at lunch today.
gt1953 Samba Member
Posted: Wed Nov 24, 2021 9:21 pm Post subject: Re: Type 3 fans and belt |
The pulley fan, does it assist in drawing air in for the stock carb/fuel inj set up. Just wondering as it only makes a little sense. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
daos Samba Member
Posted: Thu Nov 25, 2021 7:10 am Post subject: Re: Type 3 fans and belt |
the air to carbs/injection is bled from the air ducts just before the main bellows. i would say the carbs/fi take what they need from the air the fans are drawing in, the rest continues to the fans. so technically, yes, the fans assist the intake air since without the fans little to no air would come in through the body louvres. vw clearly considered this and designed the system to move enough air to cover both intake and cooling.
don't have any volumetric data for the engine airflow, might be able to dig it up in my bentley over the weekend. |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Thu Nov 25, 2021 9:16 am Post subject: Re: Type 3 fans and belt |
Erik G wrote: |
Strange corpse to dig up and debate, for sure. |
