What color shift shaft would you like? |
Raw aluminum |
26% |
[ 18 ] |
Black |
65% |
[ 45 ] |
Brown |
8% |
[ 6 ] |
Other??? email me/post below |
0% |
[ 0 ] |
Total Votes : 69 |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6316 Location: Honolulu,Hawaii and France
Posted: Wed Oct 14, 2015 8:02 pm Post subject: |
rsfabparts wrote: |
I have noticed the comments about the angle of the shifter shaft. Initially I left the angle less than original because i did not like how much room had to be clear in the front cabin area to allow it to move freely. I usually have five children, two adults travelling for long distances, which means stuff usually ends up between the two front seats. I will increase the angle of the shifter for all orders leaving from this point on. For anyone who has purchased one, I will send a replacement shaft free of charge if you are not satisfied with the angle. Please email me if you wish to receive one, [email protected] |
Hi Ray,
I'll try to bend it myself under the hydraulic press, if I fail, I'll contact you to get one, this way it saves you some $$
You never read my last message on Facebook btw _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
rsfabparts Samba Member
Posted: Wed Oct 14, 2015 8:03 pm Post subject: |
Stock knobs are possible, adapters for 12mm and 14mm threaded knobs and aftermarket .610" knobs too. Angle is still up in the air, thinking just a little short of stock shifter. I want people's input on this for sure! |
Posted: Wed Oct 14, 2015 8:05 pm Post subject: |
ok guys help me...how do I show comment or segment of comment I am replying to. What am I missing? |
insyncro Banned
Posted: Wed Oct 14, 2015 8:11 pm Post subject: |
rsfabparts wrote: |
Use the quote key in the upper right hand corner of the post you want to quote.
You can snip it, but leave the beginning and end tags. |
Posted: Wed Oct 14, 2015 8:37 pm Post subject: |
insyncro wrote: |
Ah..I get it! |
Posted: Thu Oct 15, 2015 9:37 pm Post subject: |
Hi Guys!
so today I bent the shifter under the hydraulic press using 2 small jack stands and the round tube jaws of an old vise.
I've put a thick pile of rags on the jack stand and taped the jaws together then coated them with electrical sealing rubber tape.
I had to cut the top part off bc it was slipping off from the hydraulic ram
It's a little less bent than the original bc the shifter is longer and I was doing it conservatively. The shifter got a little nicked by the jaws although I had a thick rubber layer
It is now 210mm from the dash for a 180mm original (but original is shorter, so projecting it would be around 220 to 230mm for the same height as the RSFab shifter) and 360mm from the ignition key hole for a 330mm original.
It's much better, and however I swing my right knee out of the seat with the shifter at neutral, I can't touch it. I'm about 2" away, so it stills allows to move around easily, although I rarely get away from my seat when driving....
m_goerzen Samba Member
Joined: November 29, 2011 Posts: 21 Location: Chilliwack BC
Posted: Tue Oct 20, 2015 5:37 pm Post subject: |
Can anyone who has made the change to this shifter give some feedback on how it compares to OEM? |
Gusbang Samba Member
Joined: September 07, 2015 Posts: 4 Location: Worcestershire, UK
Posted: Wed Oct 21, 2015 12:13 pm Post subject: |
Any joy getting these over to the UK? |
Posted: Fri Oct 23, 2015 5:17 pm Post subject: |
Gusbang wrote: |
In process now, Ian Huggan is the man! |
goffoz Samba Member
Posted: Fri Oct 23, 2015 10:20 pm Post subject: |
m_goerzen wrote: |
ALIKA T3 wrote: |
Have you read any of the previous postings? Confused |
I think this is more of a driveability?
ie ...Is this shifter really an improvement, is it better How?
....not guesses
Real experience over time.
Looks like a great product... I want one, probably easier to source than OEM,
..But, How does it function, compared to stock?..should I give up my old stick, that reallly works great.
I never succummed to the short shift, or shift extension..so compared to a good stock stick
..Is it much better???? when you drive it.
common tell
....please |
Posted: Sat Oct 24, 2015 10:20 am Post subject: |
rsfabparts wrote: |
Gusbang wrote: |
Posted: Sat Oct 24, 2015 6:35 pm Post subject: |
goffoz wrote: |
m_goerzen wrote: |
ALIKA T3 wrote: |
....not guesses
common tell
....please |
Check this out it might help.
https://www.facebook.com/groups/154433611260033/permalink/873501946019859/ |
narendra.vw Samba Member
Joined: February 07, 2013 Posts: 440 Location: Bangalore India
Posted: Sat Oct 24, 2015 7:26 pm Post subject: |
Any Info on TD 5 speed shifter? Thanks. |
Posted: Sun Oct 25, 2015 9:36 am Post subject: |
narendra.vw wrote: |
In process right now..should have final prototype early next week! |
phatveedub Samba Member
Posted: Fri Jan 22, 2016 10:26 pm Post subject: Re: New CNC'd Vanagon Shifter |
Just got mine installed. Very pleased with the results. Easy to install. Took me two leisurely hours to remove the old shifter, install the new one and get it dialed in. Also replaced the shift fork tabs at the same time (thanks T3). Very robust design and solid shifting. Big improvement over stock. Here are a few pics of the finished product:
Two thumbs up! |
Posted: Fri Jan 22, 2016 11:12 pm Post subject: Re: New CNC'd Vanagon Shifter |
Bought a cheapo one on Amazon and modified it to fit. I think it was $7 with free shipping. |
Posted: Sat Jan 23, 2016 11:06 am Post subject: Re: New CNC'd Vanagon Shifter |
Any news on a 5sp shifter that will fit a petrol doka? |
designer Samba Member
Joined: November 05, 2009 Posts: 484 Location: Idaho-but just the tip
Posted: Sat Jan 23, 2016 12:01 pm Post subject: Re: New CNC'd Vanagon Shifter |
I had this extension on my OE shifter. It was great till it vibrated off and broke.
Don't know if it helps...
it is shown with the knob side up. was about a half inch longer, but broke there. nice bc i could swing it to where it felt comfortable to me. _________________ __________
87 Syncro Westy : 2.5l
"It is that annoying, accelerating downhill so I can make it up the next hill in the same gear. Foot to floor hoping I can get out of the way of other cars getting onto the highway." - somebody on here around 2013. |
