What color shift shaft would you like? |
Raw aluminum |
26% |
[ 18 ] |
Black |
65% |
[ 45 ] |
Brown |
8% |
[ 6 ] |
Other??? email me/post below |
0% |
[ 0 ] |
Total Votes : 69 |
Retsgard Samba Member
Posted: Sun Jan 31, 2016 5:54 am Post subject: Re: New CNC'd Vanagon Shifter |
Gusbang wrote: |
Any news on a 5sp shifter that will fit a petrol doka? |
I'm trying to get the same.
Should be identical to LHD 5sp just the opposite hand? |
Luckyphil Samba Member
Joined: March 07, 2011 Posts: 156 Location: Australia
Posted: Sat Mar 19, 2016 2:20 am Post subject: |
m_goerzen wrote: |
Can anyone who has made the change to this shifter give some feedback on how it compares to OEM? |
I finally got mine fitted today, bloody awesome. Mine is a 5 speed (not syncro) and the thing is so easy to use. The short shift ability is fantastic and the gear knob is right where you need it and can be set up how you like it by rotating the stick before locking off. This is one of the best mods I have ever done. RS Fab will be run off their feet with orders once word get around. Also this is proof that it can be used on both RHD & LHD as we are RHD down here is Australia. |
MaiTai Samba Member
Posted: Mon Jun 13, 2016 9:35 am Post subject: Re: New CNC'd Vanagon Shifter |
Is this still available for purchase? |
designer Samba Member
Joined: November 05, 2009 Posts: 484 Location: Idaho-but just the tip
Posted: Mon Jun 13, 2016 10:47 am Post subject: Re: New CNC'd Vanagon Shifter |
i called the dude that makes them last month to see if the bad press i read on here was valid and he was shipping and his answer was yes...
i just welded my broken shifter and didn't buy the cnc'd one.. _________________ __________
87 Syncro Westy : 2.5l
"It is that annoying, accelerating downhill so I can make it up the next hill in the same gear. Foot to floor hoping I can get out of the way of other cars getting onto the highway." - somebody on here around 2013. |
Birdcage Samba Member
Joined: November 06, 2013 Posts: 203 Location: Collins of fort
Posted: Mon Jun 13, 2016 8:26 pm Post subject: Re: New CNC'd Vanagon Shifter |
It's a great shifter hands down, much better than stock. I can't wait till the entire shift linkage front to back is available from RS-fab. _________________ @syncrostyle
@optoverland |
casey79westfalia Samba Member
Posted: Wed Jun 15, 2016 7:40 pm Post subject: Re: New CNC'd Vanagon Shifter |
Any eta on the complete shift rod front to back? I'm down for one. _________________ 66 Westfalia
87 Westfalia Syncro "Phoenix"
88 Double Cab
76 Porsche 914
2014 Audi Q7
2010 Tdi Sportwagen
Currently looking for 62 Double Cab, 66 Westfalia Parts!
(Rear seat and pedestal, bumpers, mirrors)
http://www.baycountrymotors.com
My 87 Syncro Westfalia 1.8t Restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=418933
"Do it the right way, or you'll pay for it" |
Honuak Samba Member
Posted: Mon Dec 26, 2016 9:52 pm Post subject: Re: New CNC'd Vanagon Shifter |
this might be the single best upgrade yet. My original shifter may have been worse than some but WOW! Changes the whole feel of the van.
Thank You RS FAB! |
jamin307 Samba Member
Joined: October 16, 2015 Posts: 82 Location: Denver, Colorado
Posted: Tue Dec 27, 2016 5:53 am Post subject: Re: New CNC'd Vanagon Shifter |
Honuak wrote: |
Thank You RS FAB! |
I second that. Mine arrived last week. It was a quick and easy install, maybe 30 minutes. Hit all 4 gears right away and very smooth. I already experienced a stick shifter breakage last summer while on a road trip through Utah. A repeated break is no longer a concern! |
shepherdsond Samba Member
Joined: April 25, 2005 Posts: 439 Location: Bellingham, WA
svswan Samba Member
Joined: February 13, 2013 Posts: 71 Location: Olympia WA
Posted: Wed Jan 04, 2017 11:07 pm Post subject: Re: New CNC'd Vanagon Shifter |
Read this thread and a few others, plus watched all the video's referenced. What I would like to know is *why* is the shifter better? I can see that it's beefier and has a better pivot. How does it make the shifts better? Does the square metal piece above the linkage attachment work better on the guides in the shift box? What makes it appear to 'snick' into gear compared to the stock shifter?
I have lubed up all the bushings in my linkage and bought the new guides but have not installed them yet. 1st and 2nd are a little finicky until that van is good and warm. I put Stalube 85/90 GL4 in the trans a few months back.
Before I take it apart to put in the shift guides I would love to understand what makes the Big Shot shift better so I can feel better about upgrading before I bother with the repair ;-} _________________ Hula - '91 Carat with '03 Subaru JDM WRX 2.0T
http://www.thesamba.com/vw/forum/viewtopic.php?p=7682086#7682086 |
Posted: Wed Jan 04, 2017 11:41 pm Post subject: Re: New CNC'd Vanagon Shifter |
I replaced my shifter (also the shifter ears and plate ' - thanks T3) because the shifter ball joint was broken so it seemed like a good time to upgrade.
Shifting is definitely better, less travel to get in gear, tighter, and the shifter itself is stiffer. Not so much stiring the pot to get in gear now.
Having said that it will not instantly correct all your shifting woes. I would not realy say that it "snicks" into gear. You still need a well adjusted and lubed system in good repair. I find that lubing the rear ball makes a huge difference, unfortunately it only stays lubed for a few days.
I like the new feel and the big black ball. I thought it was a worthwhile upgrade. _________________ 87 Syncro Hightop Camper
3 knobs + solid shaft
2.2 Phase II Subaru
Hi-Top build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=534517 |
svswan Samba Member
Posted: Fri Jan 06, 2017 1:53 pm Post subject: Re: New CNC'd Vanagon Shifter |
shepherdsond wrote: |
Shifting is definitely better, less travel to get in gear, tighter, and the shifter itself is stiffer. Not so much stiring the pot to get in gear now. |
Thanks Shepherdsond - did you have a short shift kit before? Sounds like you did not but just want to be sure. I appreciate the description of the way it feels.
I also would love to understand why it is better. I assume it acts just like the stock unit, only way better? Anyone? Sent Ray and email, will see how busy he is now ;-} _________________ Hula - '91 Carat with '03 Subaru JDM WRX 2.0T
Posted: Fri Jan 06, 2017 3:24 pm Post subject: Re: New CNC'd Vanagon Shifter |
I installed mine a few weeks ago. Being fully CNC machined - you no longer have to worry about the plastic components included in the stock shifter design. I have heard of other samba members (myself included) suffering from a snapped shifter. It's going to take some doing to break this one. |
svswan Samba Member
Posted: Sun Jan 08, 2017 6:19 pm Post subject: Re: New CNC'd Vanagon Shifter |
Great - I do like big metal ;-}
I'm mostly figured out that the Big Shot works just like the stock one, just stiffer and no fear of breaking or wearing plastic. My next question;
Is the Big Shot the same height and bend as the stock shifter?
I have not heard back from Ray yet. I'm hoping for the same bend as stock but 2-3" longer. If I remember correctly this thread was started to get feedback on angle and length but the website doesn't indicate what he chose. It does indicate that I missed the $249 price by not making up my mind earlier though... _________________ Hula - '91 Carat with '03 Subaru JDM WRX 2.0T
artacoma Samba Member
Joined: January 11, 2014 Posts: 121 Location: Victoria BC Canada
Posted: Mon Jan 09, 2017 8:08 am Post subject: Re: New CNC'd Vanagon Shifter |
I don't know about the height but the bend is similar and this shifter can be clocked , i.e. you can turn it and lock it down in any position. _________________ Cheers
Rik
86 Syncro Tintop
2.5 Subie
86 Doka
2.5 Subie |
Posted: Thu Jan 12, 2017 4:36 pm Post subject: Re: New CNC'd Vanagon Shifter |
To answer your earlier question svswan no I did not have a short shift kit before doing this. I imagine this achieves a similar outcome but more effectively.
As artacoma says you can adjust the position of the stick - this is the only tricky part of the installation. I believe the height of the balll is higher than stock also - like having an extension of 3" or so. It feels very good, more positive than the original and closer to hand. It does not look like stock though if that's important. _________________ 87 Syncro Hightop Camper
2.2 Phase II Subaru
svswan Samba Member
Posted: Thu Jan 12, 2017 9:34 pm Post subject: Re: New CNC'd Vanagon Shifter |
- like having an extension of 3" or so. |
I don't mind that it doesn't look like stock, just want that added height. Thanks for the input ;-} _________________ Hula - '91 Carat with '03 Subaru JDM WRX 2.0T
Gruppe B Samba Member
Posted: Sun May 21, 2017 5:04 pm Post subject: Re: New CNC'd Vanagon Shifter |
Finally installed the Bigshot shifter
Absolutely incredible difference to the stock shifter!
Easy installation and night and day difference. My stock shifter worked fine and nothing was broken but compared to the Bigshot is night and day.
The bigshot's reduced throw and weighted shift is so much smoother. The new grease I added to the shift fork was nice too
Absolutely incredible upgrade and one of the best upgrades I've made!
Thanks RSFab! |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Mon Feb 04, 2019 2:49 pm Post subject: Re: New CNC'd Vanagon Shifter |
Are they still making these kits? Looks like the RS Fab folks haven't been on the site in over 6 months. I've emailed them. Hope so! _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
Vnyd Dog Samba Member
