jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Fri Aug 28, 2015 2:24 pm Post subject: Peformance Shift Rod Coupler |
With China taking over our aftermarket parts, we get the reward for being cheap. Along side the road because our brand new part failed.
I replaced my stock stripped coupler with a Red Urethane Coupler. (had to get something asap to keep dd going). Lasted one week till it cracked in half. The quality of the Urethane as with any other material that is made in China suspect to braking, tearing, leaving us stranded.
Thankfully Joe Bence is making a nice Billet one for only $30!
http://www.jbevwstore.com/billet-shift-coupler-early.html
Just got mine yesterday, Thank you Joe for shipping it so quick! Now I can get my daily driver rolling again. Check out the picture below, for only $30 cant believe getting such a nice part made here in the States.
Jeff
_________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Dale M. Samba Member
Posted: Fri Aug 28, 2015 2:27 pm Post subject: |
I always though there was a "flex" in couplers for a reason.... Guess I was wrong in just using OEM donut couplers....
jpaull Samba Member
Posted: Fri Aug 28, 2015 2:45 pm Post subject: |
Dale M. wrote: |
Dale |
Since we are in the Performance engine and transmissions section, some of us need parts other then stock. Not saying everyone is wrong for keeping there stock one, just offering a example of quality choice for those who want more. Some people keep the stock rubber trans mounts and leave it at that. But if you got some power you need more.
This coupler is best used when you already have solid trans mounts, and also have the mid strap to avoid any nose cone lift. Those of us running some horsepower already have that stuff. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Posted: Sat Aug 29, 2015 8:31 am Post subject: |
I run (in my street buggy) about 110 hp in a 1380 pound buggy and about 120hp (chassis dynoed) in a 1365 lb auto cross built buggy and stock mounts and couplers always worked for me...
Joe Bence Samba Member
Joined: March 14, 2004 Posts: 501 Location: San Diego, CA
Posted: Sat Aug 29, 2015 10:54 am Post subject: |
I started making them because the quality of the stock ones available today is very poor. I'm sure the couplers of the past were good/better. I have had 3 of the stock ones break in one way or another in my car. So this was my permanent fix. And the aftermarket ones are worst than the stockers. |
vwsb74 Samba Member
Posted: Sun Aug 30, 2015 12:41 am Post subject: |
This will fit on a 74 ? _________________ 74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢 |
Posted: Sun Aug 30, 2015 1:06 am Post subject: |
NO |
raygreenwood Samba Member
Posted: Sun Aug 30, 2015 7:09 am Post subject: Re: Peformance Shift Rod Coupler |
jpaull wrote: |
Jeff
Actually its common and normal for the red urethane coupler to crack. It started at as an 80 durometer formula. ....pretty damn hard.
It will increase in hardness and reduce in flexibility by about 3%-5% per year ....without heat. With heat it can increase in hardness exponentially......like 30% per year. And.....it shrinks a certain amount.
All urethanes do this to some degree depending on formula.
Its not necessary bad materials........its bad design specifying the totally wrong material.
The only reason urethane was used for this part and many others that are similar.....is because any idiot can cast urethane In "0" cost molds made of anything from wood to plaster to sand to plastic to metal.
In reality this part should have had a metal core and been cast with a "real" high, durometer heat set rubber compound like Viton, Buna N, EPR or EPDM. But that would require a real mold and real injection molding or pressure molding equipment in the least.....and skill......and cost. Ray |
jpaull Samba Member
Posted: Mon Aug 31, 2015 10:19 am Post subject: |
I have not seen that one yet, that is beautiful! _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
scotth17 Samba Member
Joined: January 30, 2012 Posts: 335 Location: Bedford Texas
Posted: Sat Sep 05, 2015 2:12 pm Post subject: |
I got one of these for my buggy with an 091 mounted solid and it is an exceptionally nice piece! My shift rod is above the tunnel with the 091 so the coupler is visable and this one looks like jewelry. Works great. |
Ragman The Sambinator
Posted: Mon Dec 10, 2018 4:34 pm Post subject: Re: Peformance Shift Rod Coupler |
Raising an old thread here. Does anyone have more feedback on these billet rear shift couplers for early bugs? My stock one suffered stripped out threads today, so I'm just wondering if this $30 billet one is much better than the normal stock round ones.
I'm definitely not considering the red urethane ones. |
jpaull Samba Member
Posted: Mon Dec 10, 2018 4:51 pm Post subject: Re: Peformance Shift Rod Coupler |
I'm still using the Joe Bence Billet one. I also did the bronze shift rod bushing. Shifts awesome.
Its discouraging to get a brand new stock shift coupler and it strips out super easy, and yes, the red urethane ones crack very easily. Thankfully Joe Bence has a cool option.
If anyone hasn't checked out his site, take a look at some other cool stuff he has. I also got the Roller Throttle cable tube for the fan shroud, and the billet fan shroud spacers that take up the gap on wider stroker situations.
http://www.jbevw.com/products
Also discouraging is the quality of the plastic shift rod bushings, so the below bronze one is a nice upgrade:
http://www.ev4unow.com/VWShiftRodBushing.html
Posted: Mon Dec 10, 2018 5:06 pm Post subject: Re: Peformance Shift Rod Coupler |
Thanks for the update. Did you notice any increase in Noise/vibration etc from the billet coupler? I guess the stock one has rubber in middle. I'm wondering how much the billet coupler transfers transmission noises to the shifter. My bug is already loud, so it probably won't make much difference. |
Scott65Beetle Samba Member
Posted: Mon Dec 10, 2018 5:17 pm Post subject: Re: Peformance Shift Rod Coupler |
I had high hopes for that coupler.I tried it and it would not work for me.i was unable to shift through all the gears after many attempts of adjusting the shifter.Finally went back to a stock coupler and shifted easily.My only conclusion was that the coupler just didnt provide any flex.i was very bummed because this part looks like a great item.Just didnt work for me. The stock style from WW has been working fine with 2054cc behind it going on 3 years just fine. And BTW Ive always thought that the plastic bushing in the shift rod hanger was a pos from the start. I stay after it yearly with lube and no problems,its just a crappy design.Maybe the originals were better with better material but it does seem like a silicon bronze bushing from the start would have been the way to go. Every resto I do I replace the hanger first thing and put in a new plastic bushing and keep them lubed yearly with no failures but i realize its a poor design. |
laker Samba Member
Posted: Mon Dec 10, 2018 5:26 pm Post subject: |
Very nice!! |
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Mon Dec 10, 2018 5:37 pm Post subject: Re: Peformance Shift Rod Coupler |
The shift coupler is rubberized for a reason... To keep the rubber manufactures from going out of business... -Or maybe because it is a needed component to the design. _________________ If you would like to contact me, just email through one of my ads on here...
I don't use the P.M. service on here. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Tue Dec 11, 2018 9:28 am Post subject: Re: Peformance Shift Rod Coupler |
The rubberized shift coupler is to eliminate vibrations and deaden the sound. The solid billet shift coupler will make it louder inside the car. There is no reason to need a billet shift coupler other then to spend money on something that is not needed.
If you are having problems shifting you may need to grease the shifter and the shift rod bushing below the shifter. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
jpaull Samba Member
Posted: Tue Dec 11, 2018 11:25 am Post subject: Re: Peformance Shift Rod Coupler |
Scott65Beetle wrote: |
Regarding the Billet coupler not working, and the stock one working, I had the same issue at first. Since there is no "give" in the billet coupler, everything has to be aligned correct from the start. If your stock coupler works, and the billet doesn't, your driving your car with the shift rod location slightly off, but the rubber is giving it enough "give" to work.
In my situation, I couldn't get all the gears to engage and found out the dimple in the rod was off slightly. It took some time to find out where it "should be". But after putting the shift rod coupler set screw dimple on the correct spot on the rod it shifted perfect. Over the last 50 years, previous owners sometimes goober things up.
My other 60 also wouldn't work with the billet. Found out the shift rod was bent. Replaced the shift rod, then it shifted perfect with the billet.
Amazing what kind of sins can be covered up with the stock rubber couplers.
Driving with no slop in the shifter is night/day, will never go back to the rubber sloppy stock one and the cheezy plastic garbage that's available now for the shift rod bushing. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
