rfoutch Samba Member
Joined: November 04, 2003 Posts: 102 Location: Las Vegas, NV
Posted: Fri Feb 20, 2004 2:34 pm Post subject: Inspired by others.... |
I drew up some mock ups of the dash that I want to install.
Take a look and tell me which you prefer.
I am leaning towards # 3
I will make a hard mockup from fiber board, then do one in metal. Smoke lexan may be cool as well...
https://www.thesamba.com/vw/gallery/pix/146855.jpg
Thanks
RF |
fathing Samba Member
Joined: February 09, 2004 Posts: 110 Location: Switzerland
Posted: Fri Feb 20, 2004 4:33 pm Post subject: Are you sure you are not driving a Cessna? |
Is this Thing going to fly?! I kind of like No. 2. But 3 is also nice. Where are you going to put the Flap Handel?
I like it simple, a speedo (stock) with an autometer skin to match my monster tach. Other than that I consider to put a oil temp gauge in, as I think that this is the most important (missing) information. By the way, before I would put a Volt Meter in a car I'd mount a Amp Meter. This tells you more about your electrical system.
Greetings
Dominique |
Posted: Fri Feb 20, 2004 4:40 pm Post subject: |
nope wont fly, but need info, will be off road. I agree with the amp meter.
Thanks |
Posted: Fri Feb 20, 2004 8:33 pm Post subject: |
I just revised it, this is the one that I think that I will go with.
https://www.thesamba.com/vw/gallery/pix/146969.jpg
I found out some interesting things, if you look close at your dash, the speedo is not centered on the wheel. It is off center by more than a half inch.
I corrected that with this dash. The two center gauges (tach and speedo) are center in the wheel.
If anyone would like a full sized printed copy, or the original Visio file, just ask.
Enjoy, and thanks for the input.
Randy |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Sat Feb 21, 2004 6:11 am Post subject: |
The revision looks good- less cluttered. What gauges do you plan to run?
Tach, speedo, oil pressure, head temp, oil temp, ammeter, and clock would still leave you with one "blank". _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
Posted: Sat Feb 21, 2004 11:03 am Post subject: |
Tach, speedo, oil pressure, oil temp, head temp, amp meter, fuel, and air Fuel meter
Randy |
Posted: Sat Feb 21, 2004 11:58 am Post subject: |
Got it. i assumed you were going to be running a stock speedo, with integral fuel gauge. _________________ OG JHC
2% |
Posted: Sat Feb 21, 2004 12:55 pm Post subject: |
No, with all the other gauges I perfer tohave them all look the same.
It would be diificult to place to guages the size of the speedo in that dash.
Randy |
