bkwilson111 Samba Member
Joined: September 04, 2015 Posts: 2 Location: Porter, Texas
Posted: Fri Sep 04, 2015 9:07 pm Post subject: Problems with Rear hood release cable |
I just installed a new release cable with knob, cable tubing, latch, cable tubing, and the cable tube anchoring sleeve. However, when pulling the knob, the tube pulls through anchor tube keeping the cable from pulling. The tube should be secured to the anchoring sleeve instead of going through it. Is there any way to secure the plastic tube to the anchoring sleeve without it pulling through it. 1971 Ghia Convertible
Last edited by bkwilson111 on Sun Sep 06, 2015 10:05 am; edited 3 times in total |
motorhead364 Samba Member
Joined: November 04, 2008 Posts: 715 Location: Amarillo Texas
Posted: Sat Sep 05, 2015 7:20 am Post subject: |
So that you'll get a speedier response post the year and maybe some pics. _________________ 63 ghia coupe |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Sat Sep 05, 2015 7:26 pm Post subject: |
I think your best bet would to find a little washer that will fit in the latch sleeve to reduce the opening |
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 280 Location: Richmond, VA
Posted: Sat Jun 24, 2017 11:22 am Post subject: Re: Problems with Rear hood release cable |
bkwilson111 wrote: |
I'm sure you've figured it out by now, but for others who may be doing this in the future: the anchoring sleeve crimps onto the plastic tubing. You can use a wire crimp tool. Note that the wide part of the cable by the handle won't fit through the plastic tube so the plastic tube has to be pushed into the anchoring sleeve before it is crimped.
Starbucket Samba Member
Posted: Sat Jun 24, 2017 2:18 pm Post subject: Re: Problems with Rear hood release cable |
I don't think the cable in the engine compartment is adjusted right as the pull should only be about 1" so if the plastic sleeve is moving with the cable it shouldn't come out of the housing. It's always safest to adjust the cable with the motor out so you can get at the adjuster with a locked hood if it won't open. |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2876 Location: Auckland, New Zealand
Posted: Sat Jun 24, 2017 7:12 pm Post subject: Re: Problems with Rear hood release cable |
You may want to consider a security system to ensure you can open the rear hood if the cable release malfunctions or the cable snaps. What I did was to cut a slot in each of the bolts so that I can undo the latch from under the car using a screwdriver.
_________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
