mr. lang Samba Member
Posted: Tue Aug 16, 2016 6:29 am Post subject: Re: Input shaft seal always leaking |
This is from the 1969 workshop manual (probably also mentioned in one of the bentleys):
There was a oil return thread in front of the oil seal added to the new transmission casings. Therefore the grounded surface of the seal was streched about 18.5mm to the front on the shaft. A new transmission housing with the new oil return thread must be paired with the new shaft.
No date mentioned, when this happened.
To me your new one transaxle does look exactly like the 2D drawing in the workshop manual. You can even see the thread in the casing.
From my noob understanding this does almost work like the thread at the pulley. Getting oil past that does then mean excess pressure in the transmission -> ventilation not working ??? (I'm just guessing, no clue about transmissions) _________________ 1966 Bus | 1969 Bug | 1976 Passat LX two-door | 1984 Golf 2 C (daily driver)
There are three kinds of people: those who can count and those who can't
Und läuft ... |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Tue Jan 17, 2017 11:32 am Post subject: Re: Input shaft seal always leaking |
Hi
Did you ever resolve this issue? My transmissino leaks through the seal. I can see oil ooze between the seal and the shaft.
One thing puzzling me is that the input shaft looks to be about 20mm diameter (I could only get my Vernier gauge on the splines to measure), while the ID of seal is 21mm. It's a Topran 101 944 755 seal that says it's a replacement for 113 311 113A. I have an identical seal to replace it, but if I'm using the wrong seal or this make is just junk there's no point wasting the time.
Has anyone found a seal that reliably seals?
Thanks _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Sat May 27, 2017 9:21 am Post subject: Re: Input shaft seal always leaking |
Who.Me? wrote: |
Did you ever resolve this issue? |
Don't know if this could be causing lack of venting which would cause oil to leak. Don't really know how it actually works, either, but see the two little holes in the side cover gaskets? Photo by gears.
Those little holes are supposed to be installed up at the top as they are called vents. |
spud72uk Samba Member
Posted: Mon Dec 27, 2021 2:41 pm Post subject: Re: Input shaft seal always leaking |
Sorry I know that this is an old thread but it seems to be the best one I can find. Did you manage to stop the leak, I have a 5 rib bay box which is leaking badly when hot from the input shaft. Already replaced the seal with a topran seal and still leaks - thanks |
