Hood Fresh 1962 Euro Rag
Page: Previous  1, 2, 3 ... 11, 12, 13, 14  Next
thekera
thekera is offline
PostPosted: Wed Jan 24, 2018 2:47 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Canadian VW, Im glad you like the work.
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
1979 Mk1 early westy 2dr
2013 Mk6 2dr
ANYTHING AND EVERYTHING VW METAL FAB.
NOS PANELS: WANTED
GOT RUST?
thekera
thekera is offline
PostPosted: Wed Jan 24, 2018 11:23 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
63Ragtop NZ, thank you.
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
thekera
thekera is offline
PostPosted: Thu Feb 15, 2018 11:36 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
The next piece in the metal puzzle to work on is the decklid. I have always felt VW kind of robbed ragtop buyers from the louvered decklid, that was offered on convertibles. In my opinion ragtops should have came with a louvered lid.
Anyone who has been following the thread, I need your help to source some louvers. The louvers on I believe 68-70 decklids will work as they are the same size as the early decklid louvers. Also I would like to find a split/oval rain tray as I feel this was the best design VW made. If anyone has or can get my hands on these items PM me. I will show this conversion here.
So, the decklid was actually in pretty good shape. There is some metal bumping to be done under the latch tray but other than that not bad. I do want to take everything apart to re-spot weld especially the hinge latches as these are notorious for breaking and then remove all rust and paint all hidden areas with rust preventive paint.
WANTED: LOUVERS & SPLIT/OVAL RAIN TRAY PM ME
Little side note, picked up a much overdue and need tool.
Thanks and keep posted
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
karl h
karl h is offline
PostPosted: Fri Feb 16, 2018 1:07 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
late to the party, but very, very nice metal work!
61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
arctic alice (63 on irs): http://cal-look.no/lounge/index.php/topic,27456.0.html
86 Caravelle
04 new beetle vert
thekera
thekera is offline
PostPosted: Sun Feb 18, 2018 8:06 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Karl h, thank you for the compliment. I try and take pride in what I do on these VW’s. I truly admire how these machines were engineered and built.
Thanks and keep posted.
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
thekera
thekera is offline
PostPosted: Sun Feb 25, 2018 5:33 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Little update on the decklid. Still looking for some louvers if someone can help out? Just been going about doing some rust prevention and also re-attached bottom plate. This decklid was pretty straight so not much hammer and dolly work. Did run it real fast through the English wheel with the rubber wheel.
DETAIL:
NEED LOUVERS PM ME
Thank you and keep posted
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
thekera
thekera is offline
PostPosted: Fri Mar 02, 2018 2:00 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Taking a break from the decklid, I decided to finish off these little 1962 only bits.
I had sourced these awhile back from a samba member in Germany.
After sand blasting them they did need a little cleaning up. Made sure to weld through prime them. Then located them to the new pan using the OG pan I had sitting aside.
On side note, also welded in the pedal bracket.
Thanks keep posted
NEED LOUVERS/ GOT LOUVERS PM
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
bullibene
bullibene is offline
PostPosted: Sun Mar 04, 2018 5:06 pm    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Nice work! Nothing better than a spot welder Cool
Really good to see those heater outlets finding use again!
For the oval louvres check out the CSP website, they sell them for 136€ a pair
https://www.csp-shop.com/en/?func=detailcall&artnr=17917a
www.089garage.blogspot.com
Instagram: 089garage
thekera
thekera is offline
PostPosted: Mon Mar 05, 2018 7:49 pm    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
bullibene, thanks for the csp link.
Also, thanks again for the heat outlets. Im really happy this 1962 Rag is gonna be that much more correct to the year.
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
thekera
thekera is offline
PostPosted: Sat Mar 24, 2018 3:20 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
While I wait on some metal to complete the decklid, I thought I would get started on the doors. The bottoms are toast on the OG doors. I picked up the metal to repair both the lower inner and outer metal from a European dealer.
I have seen that some decide to glue the outer door skin to avoid warping. I plan to weld the outer door skin in. That being said warping will be a problem if not prevented, I made some tooling to keep the skins natural contour.
The passenger door also had some PO hackery:
I first started by removing the rusty metal. Then located both the inner and outer panels. Then blasted new metal clean and decided to weld the inner structure first.
Still need to grind my welds. Keep posted for the outer skin and thanks for checking out the thread.
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
67rustavenger Premium Member
67rustavenger is online now
PostPosted: Sat Mar 24, 2018 5:01 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
As always. Truly remarkable work your doing.
Thank you for sharing. Many here would have written that car off long ago.
You have risen to the challenge and are an inspiration to all.
Have a great weekend.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
thekera
thekera is offline
PostPosted: Mon Mar 26, 2018 2:59 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
67rustavenger, Thank you for enjoying the work. I was able to make some more progress over the weekend. Keep posted.
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
thekera
thekera is offline
PostPosted: Sun Apr 01, 2018 5:10 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Some more work on the door Fab. Im Happy with how it is coming along. The hinge rivets are from Mika. Almost time to weld the door skin panel.
Keep posted and thanks.
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
Nickgreen949
Nickgreen949 is offline
PostPosted: Sun Apr 15, 2018 4:59 pm    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Just tuning in. Love your build. I have 2 questions for you.
1. What are those little tabs that you’re using with the cleco clips? The copper/brass ones that you use to hold the 2 panels together for butt welding.
2. Early on in your build when you were doing the cross members and heater channels how did you connect the channel to the cross member?
In one of your photos it looks like you have the channel sitting on top of the cross member, like my photo above, and another looks like you have the HC bottom plate under the CM. In order to have the bottom plate under the CM the CM would need to be notched right?
Thanks for help!
thekera
thekera is offline
PostPosted: Mon Apr 16, 2018 3:10 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Nickgreen949, thanks for the great questions. For your first question the clips in the photo a friend and I made with his CNC. There is a hot rod shop outta Santa Rosa that sells them. The name slips my mind at the moment.
For your second question, you need to drill the first couple spot welds from the end of the heater channel bottom plate. The cross member then slips in between that seam and is welded.
Thank you, and keep watching the thread.
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
thekera
thekera is offline
PostPosted: Sat Apr 21, 2018 3:06 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Back to the door skin work. Defintly a tricky area to work.
After welding, grinded the weld. This is the most important part to get just right.
In the next photos you will notice shiny areas near the seam, his is where I leaded the seam. Sorry, no photos of the lead work but leading is a delicate process that needs full attention on the work.
Quick test fit, Im happy with how lines and seams are looking.
Thanks and keep posted!
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
dodgerodder
dodgerodder is offline
PostPosted: Sat Apr 21, 2018 4:15 pm    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Really enjoying your progress, you are getting those problem areas worked out nicely!!
Will be a great feeling knowing all those rust areas are good as new, & protected to live a long time.
I’m starting a 66 project thats body is real solid (California car), put still needs some areas worked. So this is inspiring, keep it up!
Dan
Tobias Bylund
Tobias Bylund is offline
PostPosted: Mon Apr 23, 2018 2:24 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Awesome work! I have been following this thread with interest as i have more or less the same repairs to do on my -59, and your thread is for sure a great inspiration!
Since you clearly have much greater skill with sheet metal than me, i have a question; i have been repairing the fender mountings/bolt holes on the rear of mine, and i made a patch with the correct weldnut, i tried to stay as far away from the bodyline/crease as possible when cutting out the rusted sheet metal, but when welding in the new patch it wants to suck the bodyline with it when the welds cool, even though i am making quick spotwelds (MIG) and jumping around to not introduce too much heat. And that area is impossible to get to from behind to dolly it back out, or planish welds as i go. I have tried to use a slide hammer to get it back out, but i am having limited success.
What is your best advise regarding these issues? Should i get it as close as possible and accept some distortion and lead/bondo the crease back to shape, it doesnt feel right though, or is there a better way to control distortion?
Thank you!
Sharp64
Sharp64 is offline
PostPosted: Mon Apr 23, 2018 3:49 am    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
I wish I had a portion of the skill people like you do.
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
thekera
thekera is offline
PostPosted: Mon Apr 23, 2018 7:53 pm    Post subject: Re: Hood Fresh 1962 Euro Rag Reply with quote
Tobias Bylund, distortion is always a problem with these VW’s and the gauge of metal. It sounds to me like your taking the usual precautions. It’s always hard with a panel you cannot access from the back. If you have a stud welder this can help, be careful and practice first as you don’t wanna volcano stretch areas either.
Play around with your heat and wire speed. This is vital. Also try hitting each spot with air after each spot. Sheet metal work is hard. Very hard, it’s an art and takes hours of practice.
Thank you for the great question and keep checking back.
1961 Type 1
1962 Euro ragtop
1963 Type 1
1966 Type 1
2013 Mk6 2dr
NOS PANELS: WANTED
GOT RUST?
Page 12 of 14
