unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
Posted: Tue Sep 15, 2015 4:17 am Post subject: |
Great write up! |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Tue Nov 17, 2015 5:51 pm Post subject: Re: 1986 Westy Subaru Swap - '95 EJ22 |
Just noticed your note about the clutch shudder/ chatter. This is often a problem on near any 002 or 091 transmission and comes from unevenly worn contact pads on the release fork where it touches the throw out bearing.
I read about this on the Vanagon list clear back about 1999 or so from the Van Cafe guy. (was originally called Vanagon Cafe till VW of A got wind of it!)
I check these every time I have one apart and almost always one is worn flat and unevenly. New they have a radius on them. Using a jig might be best, but I usually just recontour them with a Dremel or die grinder and stone and try to make them the same measurement with a calipers.
And my clutches engage like butter!
Can't think of his name right now. Peter, maybe? Van Cafe, Santa Cruz.
A few years back, the new replacement shafts were true junk. The originals must have been poorly heat treated, that nearly all wear unevenly. It would be nice to get a NEW better part.
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
northband Samba Member
Joined: August 19, 2013 Posts: 166 Location: Defiance
Posted: Tue Nov 17, 2015 6:00 pm Post subject: Re: 1986 Westy Subaru Swap - '95 EJ22 |
Awe man - I need to update this. I had clutch chatter my first few days driving the van around. Now it shifts and drives super smooth. I'm super impressed with the conversion.
Now I just need to change my master cylinder - foot kept slipping off the clutch then I realized it was covered in brake fluid! |
Posted: Tue Nov 17, 2015 6:13 pm Post subject: Re: 1986 Westy Subaru Swap - '95 EJ22 |
Much easier than working on the release fork! But checking the profile of those pads is still a good idea when it's apart. I can't tell you how many times I've read of someone having problems, replacing every part there and it still doesn't fix it.
I have NEVER IN MY LIFE resurfaced a flywheel and rarely replace a pressure plate unless there is finger damage.
BUT EVERY SINGLE RELEASE FORK NEEDED RE PROFILING.
Nice write up, BTW. I have a couple EJ22's just need to get the rest and do a conversion. They are beautiful motors.
Vanagons:
Norasdad Samba Member
Joined: May 06, 2016 Posts: 6 Location: Lakehurst, Ontario, Canada
Posted: Thu Nov 10, 2016 1:18 pm Post subject: Re: 1986 Westy Subaru Swap - '95 EJ22 |
Very nice work and write up, thanks for the info it all helps. |
tpjph Samba Member
Posted: Mon Oct 22, 2018 5:41 pm Post subject: Re: 1986 Westy Subaru Swap - '95 EJ22 |
About the tachometer
Replace the resistor according to the content.
The tachometer appears when the engine starts.
When the throttle is stepped on, the pointer moves quickly. Which side is the problem?
My engine is EJ25.
I am from Taiwan, so the English expression ability is not very good. |
oldskoolsteve Samba Member
Joined: July 01, 2007 Posts: 73 Location: Vancouver Island Canada
Posted: Wed Feb 13, 2019 3:44 pm Post subject: Re: 1986 Westy Subaru Swap - '95 EJ22 |
Looks good!
I'll be using this for help while I'm into mine. _________________ 63 Type 3 1500 notch
84 WESTY: Suby EJ22 powered
85 WESTY: needs engine and trans
Hoodride for life |
