Maxdog2 Samba Member
Joined: August 06, 2009 Posts: 206 Location: Grand Junction, Colorado
Posted: Fri Sep 11, 2015 6:08 pm Post subject: Velocity stack/air cleaner for Super Stock 34 PICT |
I understand the benefits of using the stock oil bath cleaner, but want something else. I purchased the Super Stock 34 PICT from aircooled.net and want an air cleaner with a velocity stack. From my searches this is apparently needed. I run K & N on my Harley and like their products. Has anyone adapted a velocity stack to an air filter?
This is an 1835, Engle 100, L3 heads, in a Bug.
Thanks in advance,
David |
Scott Novak Samba Member
Joined: October 12, 2004 Posts: 1586 Location: Minneapolis, Minnesota
Posted: Fri Sep 11, 2015 9:21 pm Post subject: |
Here is what you are looking for. An old school air cleaner base with a built in velocity stack for stock Solex carbs like the 34PICT. I used this with a K&N air filter element.
On a trip to the West Coast in 1976 someone gave me this air cleaner. I used it for many years until I installed a pair of Weber 40 IDFs
I just gave this air cleaner base away to another Samba member.
Scott Novak |
Posted: Fri Sep 11, 2015 9:34 pm Post subject: Re: Velocity stack/air cleaner for Super Stock 34 PICT |
the stock air filter housing has a 6" stack built into it. Go look.
Several Samba guys have gutted the oil bath and put a cone filter in them.
http://www.thesamba.com/vw/forum/viewtopic.php?t=424278
http://www.thesamba.com/vw/forum/viewtopic.php?t=518415
are a couple examples to model from.
Don't forget that a less restrictive filter will need more fuel (more main jet), now that's it's not choked. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
air-h2o-air Samba Member
Posted: Fri Sep 11, 2015 9:59 pm Post subject: |
and both are perfect examples of original air filters that were remote mounted from factory....that show the built in "velocity" stack that is claimed as needed....but isn't.
The claimed build in velocity stack as it is called is there for an air flow guide to get air to flow past the oiled filter media...so it is cleaned...nothing more. Folks have combined old hot rod beliefs of V stacks with stock bug air filters
The ghia and bus and 181 model were all designed incorrectly, if you abide by the bug/velocity stack theory supporters. |
bluebus86 Banned
Posted: Fri Sep 11, 2015 10:38 pm Post subject: |
air-h2o-air wrote: |
You mean that is not a "velocity tunnel" between the bus air cleaner and carb!!!! Golly I was going to lengthen it to get more power, I want to race!!! . _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
modok Samba Member
Joined: October 30, 2009 Posts: 26779 Location: Colorado Springs
Posted: Fri Sep 11, 2015 10:58 pm Post subject: |
If it was remote mounted then doesn't that count as the same thing as what the OP considers a velocity stack?
Lets call it a "low velocity stack", and yes, it has been found to perform better than putting a big filter directly on the carb |
Posted: Sat Sep 12, 2015 7:28 am Post subject: |
Thanks for the responses, I now have some ideas and options. |
Posted: Sat Sep 12, 2015 10:01 am Post subject: |
any tunnel immediately prior to the carb does the purpose of a stack. The stock beetle filter has it too, carefully look (so you don't dump oil all over yourself!).
I haven't seen it done yet on the beetle filters, but I'm sure it can be done. Just post how to pics on Samba!
The only issue I can think of is the beetle/SB filter top is not flat, so you'd have to fab a flat sealing plate that is pushed down from the top of the filter housing, to squeeze the cone filter tight against the plate and bottom. Maybe 4-10 tack welds and that's all that's needed! _________________ It's just advice, do whatever you want with it!
Posted: Sat Sep 12, 2015 11:25 am Post subject: |
Thanks John, I'm cleaning the oil batch system now. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7212 Location: Videbaek Denmark
Posted: Sat Sep 12, 2015 1:11 pm Post subject: |
Hello
I agree that the stock air filter becomes a restriction at some point. However, I have done some power tests on the Ghia and bus oil bath filters. It turns out that they do not become a restriction until about 77 hp. At 80 hp there is only 1 hp gained by running the snorkel alone. At 86 hp you can gain 4 hp by running the snorkel alone. These numbers are rather consistent whether you have a higher reving 16-1700 or a slower reving 1900 cc engine. At 90 hp that intake really becomes a challenge for the engine. At that point a free flow filter pays off very well.
X2 on the triangle cut out.
Interesting stack/filter arrangement for the 34 mm Solex. I have never seen that approach before, but I´m sure it can work well.
T |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Sat Sep 12, 2015 1:47 pm Post subject: |
Bill Fisher's book claims the 4-6" velocity stack (part of the stock design) contains the fuel fog and the car will run poorly without it, especially at high rpms. |
Posted: Sun Sep 13, 2015 10:20 am Post subject: |
Ok, as I dig further into my box of parts it appears the oil bath system is complete with the thermostat parts. The system is from a 72 Bug. A question I have is how does the system pull warm arm from the breastplate hose with an aftermarket exhaust? Is this possible? I assume the hose connects to a stock exhaust and draws the heat as needed when the thermostat opens. |
Posted: Sun Sep 13, 2015 2:39 pm Post subject: |
The hose is connected to a tube that is near the cylinders It's not actually connected to the exhaust or heat exchangers. You just need the stock parts and I believe it will still work with most aftermarket headers.
Scott Novak |
Posted: Sun Sep 13, 2015 2:44 pm Post subject: |
Thanks Scott. |
Posted: Sun Sep 13, 2015 2:59 pm Post subject: |
It's been awhile, but if I remember correctly the bracket for the tube is held in place by an exhaust nut and the tube goes through a hole in the sheet metal pieces that bolt to the rear of the cylinder head tin. I'm sure someone must have a photo.
Scott Novak |
Posted: Sun Sep 13, 2015 9:19 pm Post subject: |
Found my answer and pictures on the forum and will dig deeper into the pile of parts. Thanks again. |
