after fuel up runs lousy
Tim in alaska
Tim in alaska is offline
PostPosted: Sat Sep 12, 2015 7:35 pm    Post subject: after fuel up runs lousy Reply with quote
1975 fi bus all original.... I have this thing running well after alot of help from you folks but here is my problem. I pull in to gas up... put a little mystery marvel oil in before fueling and upon leaving it lurches and runs very rough.... Im thinking it cant be the marvel oil as has not had time to hit the fuel pump.... cap off or on makes no difference.... the only thing I can come up with is crud in tank that is stirred up by fueling and blocks the tank filter right away... if have changed the line filter . thanks in advance for your help.... after sitting overnight it runs ok. tim
old DKP driver
old DKP driver is offline
PostPosted: Sat Sep 12, 2015 7:48 pm    Post subject: runs rough Reply with quote
Sorry to hear this and Yes, I would pull the filter and dump the contents into
a glass jar or what ever you have to look at the gas after it sits a few minutes or more.
I don't know why you are using marvel mystery oil other than ambient temps. What are the temps today in your area?
But , it certainly is possible you have some bad gas too.
You may need to buy a bottle of "Heat" to help absorb water if this is the case after looking at the gas sample.
Good luck with this.
V.W.owner since 1967
Wildthings
Wildthings is offline
PostPosted: Sat Sep 12, 2015 9:09 pm    Post subject: Reply with quote
It sometimes helps to dilute any petroleum product you dump in the tank, for it may settle in the bottom of the tank and cause running problems until it has been pumped through the system a time or two.
Tom Powell
Tom Powell is offline
PostPosted: Sat Sep 12, 2015 10:22 pm    Post subject: Re: runs rough Reply with quote
old DKP driver wrote:
...you have to look at the gas after it sits a few minutes or more. ...
Swirl it in a glass jar and water and/or contaminants will be around the bottom of the jar. I've had 50/50 after a fill up that might have been diesel and gas.
Aloha
tp
1967250s
1967250s is offline
PostPosted: Sun Sep 13, 2015 8:32 am    Post subject: Reply with quote
Try filling up without the Marvel oil and see what happens, could be the oil settles while you are sitting? Might also try filling up somewhere else. What weight oil are you using(in the engine)?
BTW, VW engineers built these with cold weather in mind, being from Germany, so any aftermarket crap added has to be very carefully considered. Could be any of several other items on the engine, too.
'72 Elm Green Deluxe
